Re: Design View [message #479379 is a reply to message #479165] |
Mon, 10 August 2009 19:29 |
I think there is a misunderstanding here. There is no "Design View"
outside of the editor itself. If you are talking about seeing the views
on the Windows's task bar, well, those are supposed to be hidden. Some
people install windows managers that show all windows, even those that
were explicitly hidden!
If instead you are talking about them showing up on the white design
surface within the VE itself along side the main window, then that is
correct. They must show up there or you would not be able to customize them.
Srihari wrote:
> I am using VE to create a fairly simple application.
> I have a Main frame extending from JFrame. One of the menu item action
> event I am showing up an open dialog using JFileChooser.
> Now in the design view I am able to see the open dialog!! Not really
> sure why this is coming up. Does this always come.? I guess. Because I
> added an 'About' dialog to my application which gets instantiated when
> the menu item help -> About is clicked; even this is showing up in the
> main frame design view.
> I like to know is there a way to avoid these things coming up? It really
> looks odd.
> I have also sent an email to mailto:ve-dev-owner@eclipse.org. Thought of
> starting a discussion also on this.
> I have attached a screen shot for reference.
> Thank You
Rich Kulp
Re: Design View [message #479531 is a reply to message #479433] |
Tue, 11 August 2009 13:13 |
Dialogs can be customized just like any other window. Such as dropping
new components on them (such as a JTextField, etc). If the dialog was
not visible on the free form surface you wouldn't be able to do this.
Srihari wrote:
> Thank you for the reply.
> Yeah I am talking about the white screen in VE.
> I couldn't understand where you say "... then that is
> them."
> Regards.
Rich Kulp
Re: Design View [message #479599 is a reply to message #479549] |
Tue, 11 August 2009 16:37 |
No there isn't any way to turn it off.
What you are doing is a valid and good way. But others are treating the
dialogs as part of the application itself and contained within it, so
they treat them all together in the same editor.
Rich Kulp
Re: Design View [message #617404 is a reply to message #479433] |
> them."
> Regards.
Rich Kulp
Re: Design View [message #617406 is a reply to message #617405] |
Rich Kulp
FUDForum. Page generated in 0.04481 seconds
