Using EMF Compare together with svn [message #99063] |
Fri, 12 October 2007 14:54 |
Originally posted by: firstname.name.gmail.com
First of all I would like to great people working on the EMF Compare plugin. It
is really nice, and the way of separating the match model from the diff model is
elegant.
For one of my project, I would like to retrieve the delta model from a local
model with one of its subversioned version. So far, I have been able to do some
basic svn manipulations (add, commit, delete) with the subclipse plugin. Now, I
want to get the diff model.
I looked the extensions done in the org.eclipse.emf.compare.diff plugin and some
others from the org.eclipse.compare. But I am lost.
Could some people give me some hints (and api to use) to get a diff between a
local model and one of its revision.
thanks a lot!
F. Lagarde
Re: Using EMF Compare together with svn [message #99136 is a reply to message #99078] |
Sun, 14 October 2007 17:53 |
In the last post, on 10/12 about 10h, "laurent" (laurent Goubet) wrote:
thanks for your prompt answer.
laurent> We are currently using org.eclipse.compare's framework for
laurent> SVN/CVS comparisons, we do not fetch ourselves the repository
laurent> copy of our model.
maybe I was not clear enough. It is exactly what I want to do. I don't really
care to fetch my self or not the model. All what I want is to get a EMF diff of
models through APIs. How do you trigger the compare framework to get the diff?
laurent> I think you should ask this to the people of compare on the
laurent> platform newsgroup.
thanks for that, I well check news in compare's newsgroup (does it exist?).
thanks
F. Lagarde
Re: Using EMF Compare together with svn [message #99151 is a reply to message #99136] |
Mon, 15 October 2007 07:07 |
hey,
anyway i didn't provide enough details to make clear my problem. I found my
answer among the subclipse svn api, one of them makes possible to retrieve a
previous version of any resource.. So i can retrieve the model, and then I hope
that I may call the emf diff.
thanks'
F. Lagarde
Re: Using EMF Compare together with svn [message #610006 is a reply to message #99078] |
thanks
F. Lagarde
Re: Using EMF Compare together with svn [message #610008 is a reply to message #99136] |
hey,
thanks'
F. Lagarde
FUDForum. Page generated in 0.03972 seconds
