Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [TENEO] Issues when loading models from an already existing Teneo database or deleting them
[TENEO] Issues when loading models from an already existing Teneo database or deleting them [message #98150] |
Mon, 01 October 2007 15:48 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
I'm using Teneo in order to provide a database-based implementation of
the AM3 model repository generic interface (see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/AM3 /plugins/org.eclipse.gmt.am3.core/src/org/eclipse/gmt/am3/co re/storage/?root=Technology_Project).
I don't (or at least I don't seem to) have problems when adding,
retrieving or deleting metamodels (i.e. EPackages) into/from the repository.
However, I'm facing some issues when trying to do the same thing with
terminal models conforming to loaded metamodels (i.e. EObjects which are
instances of EClasses contained in previously loaded EPackages). For
both issues, I have already checked that the models stored into the EMF
resources are correct.
1) When calling
" this.getHibernateDataStoreSession().delete(res.getContents() .get(0)); "
with "res" the EMF resource storing the terminal model, the following
exception is raised:
org.eclipse.gmt.am3.core.storage.RepositoryException:
org.hibernate.NonUniqueObjectException: a different object with the same
identifier value was already associated with the session: [Deb#2]
at
org.eclipse.gmt.am3.repository.teneo.TeneoRepository.removeM odel(TeneoRepository.java:487)
at
org.eclipse.gmt.am3.repository.teneo.testrepository.main(tes trepository.java:178)
Caused by: org.hibernate.NonUniqueObjectException: a different object
with the same identifier value was already associated with the session:
[Deb#2]
at
org.hibernate.engine.StatefulPersistenceContext.checkUniquen ess(StatefulPersistenceContext.java:556)
at
org.hibernate.event.def.DefaultDeleteEventListener.onDelete( DefaultDeleteEventListener.java:88)
at
org.hibernate.event.def.DefaultDeleteEventListener.onDelete( DefaultDeleteEventListener.java:49)
at org.hibernate.impl.SessionImpl.fireDelete(SessionImpl.java:7 66)
at org.hibernate.impl.SessionImpl.delete(SessionImpl.java:744)
at
org.eclipse.emf.teneo.hibernate.HbSessionWrapper.delete(HbSe ssionWrapper.java:156)
As a consequence, the EObjects composing the model are still stored into
the database. Maybe this issue is one of the causes of the next problem
but I'm not sure of that!
2) When working on a database which has been previously created (by
another session) and trying to add a new terminal model (which conforms
to an already stored metamodel), from
" this.getHibernateDataStoreSession().saveOrUpdate(res.getCont ents().get(0)); "
I got:
java.lang.IllegalArgumentException: No annotated model element present
for: Deb for type EClass has its epackage been registered with Teneo?
at
org.eclipse.gmt.am3.repository.teneo.TeneoRepository.addMode l(TeneoRepository.java:413)
at
org.eclipse.gmt.am3.repository.teneo.TeneoRepository.updateM odel(TeneoRepository.java:439)
at
org.eclipse.gmt.am3.repository.teneo.TeneoRepository.updateM odel(TeneoRepository.java:464)
at
org.eclipse.gmt.am3.repository.teneo.testrepository.main(tes trepository.java:127)
Caused by: java.lang.IllegalArgumentException: No annotated model
element present for: Deb for type EClass has its epackage been
at
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.checkAnnotatedPresent(PAnnotatedModelImpl.java:337)
at
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.getPAnnotated(PAnnotatedModelImpl.java:279)
at
org.eclipse.emf.teneo.mapping.strategy.impl.EntityResolvingN ameStrategy.toEntityName(EntityResolvingNameStrategy.java:84 )
at
org.eclipse.emf.teneo.hibernate.EMFInterceptor.getEntityName (EMFInterceptor.java:75)
at org.hibernate.impl.SessionImpl.guessEntityName(SessionImpl.j ava:1765)
at org.hibernate.impl.SessionImpl.getEntityPersister(SessionImp l.java:1338)
at org.hibernate.engine.ForeignKeys.isTransient(ForeignKeys.jav a:180)
at
org.hibernate.event.def.AbstractSaveEventListener.getEntityS tate(AbstractSaveEventListener.java:487)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:84)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:70)
at org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl. java:507)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :499)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :495)
at
org.eclipse.emf.teneo.hibernate.HbSessionWrapper.saveOrUpdat e(HbSessionWrapper.java:151)
What is strange is that I'm succeeding in retrieving the corresponding
metamodel (i.e. EPackages)...
Does anybody have ideas about where do these problems come from and how
to solve them?
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [TENEO] Issues when loading models from an already existing Teneo database or deleting them [message #98211 is a reply to message #98150] |
Mon, 01 October 2007 21:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Martin Taal![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mtaal%40springsite.com) Messages: 5468 Registered: July 2009 |
Hi Hugo,
1) this can occur if you have a type which has an id which you assign 'manually' (not generated by
the db). If two different instances of the same type have the same id then this error occurs.
2) Using an example, what I understand is that you store an EPackage P1 with an eClass C1 in the db
and then try to store an eobject which has this eclass c1 in the same db?
Did you pass P1 as an epackage to the hibernatedatastore (hbdatastore.setEPackages(...))?
gr. Martin
Hugo Bruneliere wrote:
> repository.
> 1) When calling
> at
> at
> [Deb#2]
> at
> at
> at
> at
> I got:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> to solve them?
> Best regards,
> Hugo
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TENEO] Issues when loading models from an already existing Teneo database or deleting them [message #98328 is a reply to message #98211] |
Tue, 02 October 2007 15:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Martin,
Thanks for your answers, they helped me finding where my problems came
from ;-)
Hugo
Martin Taal a écrit :
> Hi Hugo,
> 'manually' (not generated by the db). If two different instances of the
> with an eClass C1 in the db and then try to store an eobject which has
> gr. Martin
>> Hi,
>> repository.
>> are instances of EClasses contained in previously loaded EPackages).
>> For both issues, I have already checked that the models stored into
>> the EMF resources are correct.
>> 1) When calling
>> same identifier value was already associated with the session: [Deb#2]
>> at
>> at
>> session: [Deb#2]
>> at
>> at
>> at
>> at
>> into the database. Maybe this issue is one of the causes of the next
>> problem but I'm not sure of that!
>> conforms to an already stored metamodel), from
>> I got:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> how to solve them?
>> Best regards,
>> Hugo
Re: [TENEO] Issues when loading models from an already existing Teneo database o [message #100452 is a reply to message #98150] |
Wed, 31 October 2007 18:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mduduzi.keswa.isizwe.com
I have been trying to figure out a way to store ecore metamodel in a
database instead of the file based approach. I'm currently prototyping
using storing EObjects into a database using Teneo-Hibernate interface.
Will this (mentioned in this post) plugin/tool allow me to do such? Is
this part of Teneo-Hibernate interface. I'd appreciate it if I can be
pointed to an example or a detailed explanation on how to go about doing
this - at least to get started.
-Mdu
Re: [TENEO] Issues when loading models from an already existing Teneo database o [message #100465 is a reply to message #100452] |
Wed, 31 October 2007 18:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Mdu,
If you mean Teneo as the tool/plugin then Teneo should get pretty far in persisting ecore models
itself. I have only tried it for demo purposes and small testcases.
Here is part of a test case I have used to re-produce an issue someone had persisting ecore models.
I copied and pasted it and reformatted is it may not be syntactically correct but you get the meaning:
HbDataStore hbds = HbHelper.INSTANCE.createRegisterDataStore("test");
final Properties props = new Properties();
// here set your hibernate properties (jdbc url, etc.)
// hbds.setHibernateProperties(props);
// here set your teneo properties for example:
// props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, "JOINED");
// props.put(PersistenceOptions.JOIN_TABLE_NAMING_STRATEGY, "ejb3");
// props.put(PersistenceOptions.JOIN_TABLE_FOR_NON_CONTAINED_AS SOCIATIONS, "true");
// hbds.setPersistenceProperties(props);
// sets the epackages stored in this datastore
hbds.setEPackages(new EPackage[] { EcorePackage.eINSTANCE, XMLTypePackage.eINSTANCE });
// create the db/tables
hbds.initialize();
// now store some epackages
Session s = hbds.getSessionFactory().openSession();
s.beginTransaction();
// the epacks list contains the EPackages you want to persist
for (EPackage epack : epacks) {
s.save(epack);
s.getTransaction().commit();
// now for test purposes read them back and put them in an array
final List l = s.createQuery("select e from ecore.EPackage e").list();
final EPackage[] newEpacks = new EPackage[l.size()];
int i = 0;
for (Object o : l) {
final EPackage epack = (EPackage) o;
newEpacks[i++] = epack;
gr. Martin
Mdu Keswa wrote:
> -Mdu
The Netherlands
Re: [TENEO] Issues when loading models from an already existing Teneo database o [message #100478 is a reply to message #100465] |
Thu, 01 November 2007 10:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Martin,
Brilliant! This is a great start for me. Maybe I have missed a
Teneo-Hibernate cookbook somewhere. Basically, ultimately I want to be
able to support at least the following use cases with help of
Teneo-Hibernate:
1. Start with annotized java interfaces to generate Ecore metamodel.
2. Store generated Ecore metamodel in a database (via Hibernate).
3. Load a metamodel from a database in 2. to generate objects to be stored
in the database.
4. Using a web based(Ajax) Editor and via Eclipse Editor modify metamodel
in 2.
4.1. Support for 'Entity Editor' so that end user with proper roles can
add attributes and maybe relationships to an existing entity/metamodel
5. Support to develop a web based (Ajax) Form Builder driven by querying
an existing Ecore metamodel from the database.
6. Support for Audit Trails whenever an object/entity (EObject) incurs
C.R.U.D. (Create,Read,Update,Delete) events
Maybe it's because Christmas is almost here but the aforemonetioned list
is actually a wish list. And in no way I expect Teneo-Hibernate to give me
all of this; but at least provide some launch pad.
Thanks again,
-Mdu
Re: [TENEO] Issues when loading models from an already existing Teneo database o [message #100490 is a reply to message #100478] |
Thu, 01 November 2007 10:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Mdu,
Teneo will do the ecore to db part for you. The only thing which can be tricky is that after
changing your model you have to update the database schema. You can do this through Teneo by
creating a new HbDataStore with the changed model. The db schema will then be updated. One thing to
note is that hibernate does not support all db update actions (mainly that new indexes are not added
to an existing table, but it will create new tables/columns when it notices that these are missing).
Also often updating the db schema can only be done if the database is locked (so no access to the db
for other users). I am not sure if this is an issue in your case.
For an ajax web editor for ecore there is an interesting link here:
http://wiki.eclipse.org/JFace_Data_Binding/GWT
See also several posts on the EMF newsgroup (search for posts with GWT in the subject).
I am myself working on a (ecore-)model-driven web form generator. But this is targeted at business
data oriented apps. This means that I do not intend to support all the flexibilities of an ecore
model (which are mainly reflected in featuremaps). So what I am doing will probably not support
editing the ecore model itself.
gr. Martin
Mdu Keswa wrote:
> Martin,
> Teneo-Hibernate:
> stored in the database.
> metamodel in 2.
> me all of this; but at least provide some launch pad.
> Thanks again,
> -Mdu
The Netherlands
Re: [TENEO] Issues when loading models from an already existing Teneo database or deleting them [message #609865 is a reply to message #98150] |
Mon, 01 October 2007 21:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Hugo,
gr. Martin
> repository.
> 1) When calling
> at
> at
> [Deb#2]
> at
> at
> at
> at
> I got:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> to solve them?
> Best regards,
> Hugo
The Netherlands
Re: [TENEO] Issues when loading models from an already existing Teneo database or deleting them [message #609873 is a reply to message #98211] |
Tue, 02 October 2007 15:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hugo Bruneliere![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=hugo.bruneliere%40imt-atlantique.fr) Messages: 674 Registered: July 2009 |
Hi Martin,
from ;-)
Hugo
> Hi Hugo,
> gr. Martin
>> Hi,
>> repository.
>> 1) When calling
>> at
>> at
>> session: [Deb#2]
>> at
>> at
>> at
>> at
>> I got:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> how to solve them?
>> Best regards,
>> Hugo
Hugo Bruneliere, PhD
NaoMod team (IMT Atlantique & LS2N-CNRS)
Nantes - France
Re: [TENEO] Issues when loading models from an already existing Teneo database o [message #610185 is a reply to message #98150] |
Wed, 31 October 2007 18:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
-Mdu
Re: [TENEO] Issues when loading models from an already existing Teneo database o [message #610186 is a reply to message #100452] |
Wed, 31 October 2007 18:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Mdu,
hbds.initialize();
s.save(epack);
int i = 0;
gr. Martin
Mdu Keswa wrote:
> -Mdu
The Netherlands
Re: [TENEO] Issues when loading models from an already existing Teneo database o [message #610188 is a reply to message #100465] |
Thu, 01 November 2007 10:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Martin,
Teneo-Hibernate:
in the database.
in 2.
Thanks again,
-Mdu
Re: [TENEO] Issues when loading models from an already existing Teneo database o [message #610190 is a reply to message #100478] |
Hi Mdu,
gr. Martin
Mdu Keswa wrote:
> Martin,
> Teneo-Hibernate:
> metamodel in 2.
> Thanks again,
> -Mdu
The Netherlands
Current Time: Sat Jul 27 12:38:07 GMT 2024
Powered by FUDForum. Page generated in 0.04207 seconds
