Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] LazyInitializationException
[Teneo] LazyInitializationException [message #97955] Fri, 28 September 2007 07:33 Go to next message
I am trying to handle LazyInitializationException in teneo 0.8.
http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg03083.html
I am trying according to steps mentioned in above post (which were for
0.7.5) but didn't work.
I think I may not be doing it right for 0.8.
If I override & synchronize delegateSize() method in my class (which
extends HibernatePersistableEList)
protected synchronized int delegateSize()
return super.delegateSize();
I
then it works but makes the loading very very slow.
If I don't override this method and just do above steps then I still get
error:
org.hibernate.LazyInitializationException: illegal access to loading
collection
at
org.hibernate.collection.AbstractPersistentCollection.initia lize(AbstractPersistentCollection.java:341)
at
org.hibernate.collection.AbstractPersistentCollection.read(A bstractPersistentCollection.java:86)
at
org.hibernate.collection.AbstractPersistentCollection.readSi ze(AbstractPersistentCollection.java:109)
at org.hibernate.collection.PersistentList.size(PersistentList. java:91)
at
org.eclipse.emf.common.util.DelegatingEList.delegateSize(Del egatingEList.java:231)
at
org.eclipse.emf.teneo.mapping.elist.PersistableEList.delegat eSize(PersistableEList.java:434)
at
org.eclipse.emf.common.util.DelegatingEList.size(DelegatingE List.java:222)
at
org.eclipse.emf.common.util.DelegatingEList$EIterator.hasNex t(DelegatingEList.java:1048)
Any suggestions?
Thanks.
Re: [Teneo] LazyInitializationException [message #97985 is a reply to message #97955] Fri, 28 September 2007 11:07 Go to previous messageGo to next message
Can you post the complete stacktrace?
gr. Martin
PC wrote:
> @Override
> I
> error:
> collection
> at
> at
> at
> at
> at
> at
> at
> Any suggestions?
> Thanks.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] LazyInitializationException [message #98000 is a reply to message #97985] Fri, 28 September 2007 11:13 Go to previous messageGo to next message
Hi Martin,
Here it is:
collection
at
at
at
at
at
at
at
at
com.pilz.pas.platform.iface.model.impl.DepthFirstVisitorImpl .visitDeviceInterface(DepthFirstVisitorImpl.java:81)
at
com.pilz.pas.platform.iface.model.impl.DeviceInterfaceImpl.a pply(DeviceInterfaceImpl.java:282)
at
com.pilz.pas.platform.iface.model.impl.DepthFirstVisitorImpl .visitRoot(DepthFirstVisitorImpl.java:246)
at com.pilz.pas.platform.iface.model.impl.RootImpl.apply(RootIm pl.java:178)
at
com.pilz.pas.platform.runtime.logic.internal.BuildManager.st artBuild(BuildManager.java:96)
at
com.pilz.pas.platform.gui.internal.jobs.DownloadBinariesJob. run(DownloadBinariesJob.java:85)
Thanks.
- Parvez
Martin Taal wrote:
> gr. Martin
> PC wrote:
>> Hi,
>> for 0.7.5) but didn't work.
>> @Override
>> I
>> get error:
>> collection
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Any suggestions?
>> Thanks.
Re: [Teneo] LazyInitializationException [message #98028 is a reply to message #98000] Sun, 30 September 2007 01:09 Go to previous message
Hi Parvez,
Looking at the old post you refer to. The lazyinitializationexception occurs because you have
multi-threaded access to one list (correct?).
If this is the case then this exception (in this case) can only be prevented by synchronizing the
access to the list (at least when it is initializing).
After the list has been initialized then the size method should be very quick. So I do not
understand why synchronizing this method makes the system very slow. Can you check what takes so
much time there (is the cpu 100%, are there multiple threads waiting for this method, is the size
method called many times?)?
gr. Martin
PC wrote:
> Hi Martin,
> Here it is:
> collection
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Thanks.
> - Parvez
> Martin Taal wrote:
>> Hi,
>> gr. Martin
>> PC wrote:
>>> Hi,
>>> @Override
>>> I
>>> get error:
>>> collection
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Any suggestions?
>>> Thanks.
The Netherlands
Re: [Teneo] LazyInitializationException [message #609850 is a reply to message #97955] Fri, 28 September 2007 11:07 Go to previous message
gr. Martin
PC wrote:
> @Override
> I
> error:
> collection
> at
> at
> at
> at
> at
> at
> at
> Any suggestions?
> Thanks.
The Netherlands
Re: [Teneo] LazyInitializationException [message #609851 is a reply to message #97985] Fri, 28 September 2007 11:13 Go to previous message
Hi Martin,
Here it is:
collection
at
at
at
at
at
at
at
at
at
at
at
at
Thanks.
- Parvez
Martin Taal wrote:
> gr. Martin
> PC wrote:
>> Hi,
>> @Override
>> I
>> get error:
>> collection
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Any suggestions?
>> Thanks.
Re: [Teneo] LazyInitializationException [message #609853 is a reply to message #98000] Sun, 30 September 2007 01:09 Go to previous message
Hi Parvez,
gr. Martin
PC wrote:
> Hi Martin,
> Here it is:
> collection
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks.
> - Parvez
> Martin Taal wrote:
>> Hi,
>> gr. Martin
>> PC wrote:
>>> Hi,
>>> @Override
>>> I
>>> get error:
>>> collection
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Any suggestions?
>>> Thanks.
The Netherlands
Previous Topic:still problems with emft updates
Next Topic:[CDO][0.8.0] Connector.UserID not pass properly to the server
Current Time: Wed Sep 17 16:22:21 EDT 2025
Powered by FUDForum. Page generated in 0.04110 seconds
