Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Identifier for my objects
[Teneo] Identifier for my objects [message #86983] |
Thu, 21 June 2007 09:43 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: gonzalinlinWITHOUT_THIS.tiscali.es
Hi Martin!
I've designed my model using EMF, and then generated my hibernate.hbm.xml
mapping file using Teneo. This is for a web application.
Here is an excerpt:
<!-- Generated by Teneo on Mon May 07 19:41:00 CEST 2007 -->
<hibernate-mapping>
<class entity-name="Factura" abstract="false" lazy="false"
discriminator-value="Factura" table="`factura`">
<meta attribute="eclassName">Factura</meta>
<meta attribute="epackage">http://productoexpediente.factura</meta>
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
So Teneo creates an id called "e_id", but I haven't any id in my classes.
My question is: Must all my objects extend a class (for example:
"AbstractObject") with an attribute "id"?
If I execute the method findAll() in the DAO, How can I retrieve the
attributes of a particular instance returned by findAll()? I suppose I need
the id of that instance, so how can I get that id to retrieve the other
attributes?
Thank you again!
With regards,
Gonzalo
Re: [Teneo] Identifier for my objects [message #86998 is a reply to message #86983] |
Thu, 21 June 2007 10:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Martin Taal![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mtaal%40springsite.com) Messages: 5468 Registered: July 2009 |
Hi Gonzalo,
The synthetic id is automatically added by Teneo to every type which does not have an explicit id
property (i.e. annotated with the @id property). In general it is better/easier to have an explicit
id property.
You can add an id efeature to each eclass to solve this.
Or as you suggest you can create an (abstract) super type which has an id feature. All types will
then inherit from this abstract superclass. As a default Teneo will create a table for this abstract
super class also. If you don't want that then you need to set the @MappedSuperclass annotation in
the abstract supertype.
If you choose to add an id efeature to each type then it can be an idea to define a separate
edatatype for the id. The @id annotation can then be set in this edatatype. Probably the id is an
auto-increment long (or something similar), in this case you should also add the @GeneratedValue
annotation to the id edatatype/efeature.
Note that the above also applies to the version concept. It is better in general to have an explicit
version efeature also in your model. Although it is not to nice to have such an explicit 'low-level'
concept in the business model it is required when you (de-)serialize your objects.
gr. Martin
Gonzalo wrote:
> Hi Martin!
> Here is an excerpt:
> <hibernate-mapping>
> attributes?
> Thank you again!
> With regards,
> Gonzalo
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Identifier for my objects [message #88268 is a reply to message #86998] |
Thu, 05 July 2007 14:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: FIRSTNAME.LASTNAME.sphere.ae
We tried that, but got ...
org.hibernate.id.IdentifierGenerationException: this id generator
generates long, integer, short
.... when saving something.
Our annotation.xml looks like this
<edatatype name="IdentifierType">
<generated-value />
<id />
</edatatype>
the generated mapping XML:
<id name="id" type="to.IdentifierType">
<column not-null="true" unique="true" name="`id`"/>
<generator class="native"/>
</id>
Hibernate expect to see "long" in the type-attribute... but we're ran
out of ideas how to get from our EDataType to long...
Thanks in advance,
Tom.
Martin Taal wrote:
> Hi Gonzalo,
> does not have an explicit id property (i.e. annotated with the @id
> property). In general it is better/easier to have an explicit id property.
> id feature. All types will then inherit from this abstract superclass.
> As a default Teneo will create a table for this abstract super class
> annotation in the abstract supertype.
> to define a separate edatatype for the id. The @id annotation can then
> be set in this edatatype. Probably the id is an auto-increment long (or
> general to have an explicit version efeature also in your model.
> Although it is not to nice to have such an explicit 'low-level' concept
> gr. Martin
> Gonzalo wrote:
>> Hi Martin!
>> hibernate.hbm.xml mapping file using Teneo. This is for a web
>> application.
>> Here is an excerpt:
>> <hibernate-mapping>
>> need the id of that instance, so how can I get that id to retrieve the
>> other attributes?
>> Thank you again!
>> With regards,
>> Gonzalo
Re: [Teneo] Identifier for my objects [message #88298 is a reply to message #88268] |
Thu, 05 July 2007 16:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
How does the ecore for this eDataType look like?
Does it have an instance class name set? You can try java.lang.Long or long.
gr. Martin
Thomas Kuhn wrote:
> <generated-value />
> <id />
> </edatatype>
> </id>
> Thanks in advance,
> Tom.
> Martin Taal wrote:
>> Hi Gonzalo,
>> property.
>> @MappedSuperclass annotation in the abstract supertype.
>> idea to define a separate edatatype for the id. The @id annotation can
>> then be set in this edatatype. Probably the id is an auto-increment
>> @GeneratedValue annotation to the id edatatype/efeature.
>> in general to have an explicit version efeature also in your model.
>> your objects.
>> gr. Martin
>> Gonzalo wrote:
>>> Hi Martin!
>>> application.
>>> Here is an excerpt:
>>> <hibernate-mapping>
>>> classes.
>>> I need the id of that instance, so how can I get that id to retrieve
>>> the other attributes?
>>> Thank you again!
>>> With regards,
>>> Gonzalo
The Netherlands
Re: [Teneo] Identifier for my objects [message #88314 is a reply to message #88298] |
Thu, 05 July 2007 16:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I forgot to mention that after changing the ecore you have to re-generate your java code to get the
ecore change into the runtime ecore model.
gr. Martin
> long.
> gr. Martin
> Thomas Kuhn wrote:
>> Hi,
>> <generated-value />
>> <id />
>> </edatatype>
>> </id>
>> Thanks in advance,
>> Tom.
>> Martin Taal wrote:
>>> Hi Gonzalo,
>>> property.
>>> an id feature. All types will then inherit from this abstract
>>> also add the @GeneratedValue annotation to the id edatatype/efeature.
>>> your objects.
>>> gr. Martin
>>> Gonzalo wrote:
>>>> Hi Martin!
>>>> application.
>>>> Here is an excerpt:
>>>> <hibernate-mapping>
>>>> classes.
>>>> Thank you again!
>>>> With regards,
>>>> Gonzalo
The Netherlands
Re: [Teneo] Identifier for my objects [message #88508 is a reply to message #88314] |
Fri, 06 July 2007 17:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I changed the instance class name to Long, now it works.
Thanks a lot!
Tom
> re-generate your java code to get the ecore change into the runtime
> ecore model.
> gr. Martin
>> long.
>> gr. Martin
Re: [Teneo] Identifier for my objects [message #607031 is a reply to message #86983] |
Thu, 21 June 2007 10:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Gonzalo,
id property.
gr. Martin
Gonzalo wrote:
> Hi Martin!
> Here is an excerpt:
> <hibernate-mapping>
> attributes?
> Thank you again!
> With regards,
> Gonzalo
The Netherlands
Re: [Teneo] Identifier for my objects [message #608649 is a reply to message #86998] |
Thu, 05 July 2007 14:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thomas Kuhn![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=eclipse_bugzilla%40thomaskuhn.ch) Messages: 9 Registered: July 2009 |
<generated-value />
<id />
</edatatype>
</id>
Thanks in advance,
Tom.
Martin Taal wrote:
> Hi Gonzalo,
> gr. Martin
> Gonzalo wrote:
>> Hi Martin!
>> application.
>> Here is an excerpt:
>> <hibernate-mapping>
>> other attributes?
>> Thank you again!
>> With regards,
>> Gonzalo
Re: [Teneo] Identifier for my objects [message #608651 is a reply to message #88268] |
Thu, 05 July 2007 16:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
gr. Martin
Thomas Kuhn wrote:
> <generated-value />
> <id />
> </edatatype>
> </id>
> Thanks in advance,
> Tom.
> Martin Taal wrote:
>> Hi Gonzalo,
>> property.
>> your objects.
>> gr. Martin
>> Gonzalo wrote:
>>> Hi Martin!
>>> application.
>>> Here is an excerpt:
>>> <hibernate-mapping>
>>> classes.
>>> Thank you again!
>>> With regards,
>>> Gonzalo
The Netherlands
Re: [Teneo] Identifier for my objects [message #608652 is a reply to message #88298] |
Thu, 05 July 2007 16:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
gr. Martin
> long.
> gr. Martin
> Thomas Kuhn wrote:
>> Hi,
>> <generated-value />
>> <id />
>> </edatatype>
>> </id>
>> Thanks in advance,
>> Tom.
>> Martin Taal wrote:
>>> Hi Gonzalo,
>>> property.
>>> your objects.
>>> gr. Martin
>>> Gonzalo wrote:
>>>> Hi Martin!
>>>> application.
>>>> Here is an excerpt:
>>>> <hibernate-mapping>
>>>> classes.
>>>> Thank you again!
>>>> With regards,
>>>> Gonzalo
The Netherlands
Current Time: Sat Jul 27 14:08:04 GMT 2024
Powered by FUDForum. Page generated in 0.05548 seconds
