Home » Modeling » GMF (Graphical Modeling Framework) » No parser is registered for the "OCL" language
No parser is registered for the "OCL" language [message #60636] |
Tue, 10 October 2006 17:31 |
Originally posted by: leonardo.coelho.siliconstrategy.com.br
I´m developing an RCP app based on GMF.
I´ve created a GMF plugin with a especific diagram and some audit rules
based on OCL.
When I use it as a standard plugin in Eclipse it works fine. But, when I
try to use it in my own RCP app it crashes the Problem view.
I´ve used the contributionItemProvider to make my Validate Menu appears:
<extension id="ValidationContributionItemProvider" name="Validation"
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<contributionItemProvider checkPluginLoaded="true"
class="workflow.diagram.providers.Stw_clientValidationProvider ">
<Priority name="High"/>
<partContribution
id="workflow.diagram.part.Stw_clientDiagramEditorID">
<partMenuGroup menubarPath="/window/" id="validationGroup"/>
<partAction id="validateAction"
menubarPath="/window/validationGroup"/>
</partContribution>
</contributionItemProvider>
</extension>
(it is temporarily under the Window menu!)
Then, I run my app and click on the Validate Action. It appears a lot of
Info in my Diagram that say "IRJAXXX The constraint blablabla is
disabled. It will not be evaluated".
If I analyse the generated log I get this: No parser is registered for
the "OCL" language. Constraints expressed in this language will not be
evaluated.
What should I do to make it works? Isn´t it strange? I´ve supposed if it
was working in my gmf pure plugin and if I add it to my RCP app, all
these stuff would be working fine... Should I repeat (in my stand alone
app) some of the extensions that already exists in my gmf pure plugin?
Thx!
Leonardo Coelho
Re: No parser is registered for the "OCL" language [message #60637 is a reply to message #60636] |
Tue, 10 October 2006 18:11 |
Updating my doubt: I´ve already added org.eclipse.emf.validation plugins
to the dependency of my App and it has solved part of the problem.
Now it´s working a little bit better: it shows the exact problem and
when I click on the error, it focuses the node that concerns to it.
However, it still logging a error. And the figures in the problem view
are not shown.
It appears to be a common problem not related to GMF... if anyone knows
it, I´d appreciate the help.
Thx!
leo
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.jface.util.Assert$AssertionFailedException: null argument;
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:150)
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:126)
at
org.eclipse.jface.resource.ResourceManager.createImage(Resou rceManager.java:93)
at
org.eclipse.ui.views.markers.internal.FieldSeverityAndMessag e.getImage(FieldSeverityAndMessage.java:65)
at
org.eclipse.ui.views.markers.internal.TableViewLabelProvider .getColumnImage(TableViewLabelProvider.java:49)
at org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:310)
at
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:95)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
at
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:840)
at
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:465)
at
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1955)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:744)
at
org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren( AbstractTreeViewer.java:2427)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh Struct(AbstractTreeViewer.java:1640)
at
org.eclipse.jface.viewers.TreeViewer.internalRefreshStruct(T reeViewer.java:955)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1616)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1571)
at
org.eclipse.jface.viewers.StructuredViewer$8.run(StructuredV iewer.java:1415)
at
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1323)
at
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1413)
at
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1370)
at
org.eclipse.ui.views.markers.internal.MarkerView$UpdateJob.r unInUIThread(MarkerView.java:222)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:94)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at br.com.siliconstrategy.stw.admin.ui.StwAdminApp.run(StwAdmin App.java:18)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Leonardo Coelho escreveu:
> based on OCL.
> <partContribution
> </partContribution>
> </extension>
> evaluated.
> Thx!
Leonardo Coelho
Re: No parser is registered for the "OCL" language [message #60643 is a reply to message #60637] |
Tue, 10 October 2006 20:14 |
Well... i´ve solved it but i must recognize it was a bit awful...
I´d like to hear from you if it is the best way to deal with this issue...
I´ve found out that there was a problem loading the images of the
Problem view. Look at this line of the stack trace:
at
Then, in a intensive work gogling any help, i´ve found this link:
http://www.eclipsezone.com/forums/thread.jspa?messageID=9188 4470&%2313890;&
In this link, we are lead to create an alternative to load any icon
related to internal ide resources.
So, i´ve changed my Advisor to load specific images of the Problem View.
private void declareWorkbenchImage(Bundle ideBundle, String
symbolicName, String path, boolean shared) {
ImageDescriptor desc = Activator.getImageDescriptor(path);
getWorkbenchConfigurer().declareImage(symbolicName, desc, shared);
Now it is working fine. And i must recognize: even better, ´cause now I
can add any icon I want.
But, an important question: is it the best way to do? I´m really not
sure about this.
leo
> are not shown.
> Thx!
> leo
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Regards
>> Hi,
>> rules based on OCL.
>> I try to use it in my own RCP app it crashes the Problem view.
>> <partContribution
>> </partContribution>
>> </extension>
>> of Info in my Diagram that say "IRJAXXX The constraint blablabla is
>> evaluated.
>> it was working in my gmf pure plugin and if I add it to my RCP app,
>> all these stuff would be working fine... Should I repeat (in my stand
>> alone app) some of the extensions that already exists in my gmf pure
>> plugin?
>> Thx!
Leonardo Coelho
Re: No parser is registered for the "OCL" language [message #60902 is a reply to message #60649] |
Wed, 11 October 2006 14:28 |
Yes, you´re sure, Artem!!
Thx anyway!
leo
Artem Tikhomirov escreveu:
> Well, it's definitely better to ask this question in RCP newsgroup ;), as
> there's nothing to deal with GMF
> "Leonardo Coelho" <leonardo.coelho@siliconstrategy.com.br> wrote in message
> news:egguqg$4mf$1@utils.eclipse.org...
>> I´ve found out that there was a problem loading the images of the Problem
>> at
>> But, an important question: is it the best way to do? I´m really not sure
>> about this.
>> Regards,
>> leo
>>> Now it´s working a little bit better: it shows the exact problem and when
>>> are not shown.
>>> Thx!
>>> leo
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>> Regards
>>>> Hi,
>>>> based on OCL.
>>>> <partContribution
>>>> </partContribution>
>>>> </extension>
>>>> evaluated.
>>>> Thx!
>> Leonardo Coelho
Leonardo Coelho
Current Time: Sat Jul 27 16:41:59 GMT 2024
Powered by FUDForum. Page generated in 0.03692 seconds
