Home » Archived » XML Schema Definition (XSD) » How to create sample XML doc from XSD schema?
How to create sample XML doc from XSD schema? [message #604448] Fri, 22 January 2010 13:27 Go to next message
Ben StoverFriend
Assume I loaded a XSD schema file (with a lot of imported other XSD schema files).
How can I create in Eclipse a sample XML doc from this XSD schema with arbitrary generated sample dummy values but valid against its XSD schema?
Ben
Re: How to create sample XML doc from XSD schema? [message #604457 is a reply to message #604448] Fri, 22 January 2010 13:41 Go to previous message
Ben,
The XSD project doesn't provide support for producing sample instances.
I think WTP might provide something like that.
> schema files).
> Ben
Ed Merks
Previous Topic:How to create sample XML doc from XSD schema?
Next Topic:How to indent/reformat XML/XSD tags according to their hierarchy level?
Current Time: Wed Feb 05 12:55:33 GMT 2025
Powered by FUDForum. Page generated in 0.02595 seconds
