Home » Archived » XML Schema Definition (XSD) » How to copy XSDSchema object
How to copy XSDSchema object [message #77985] Wed, 01 July 2009 16:06 Go to next message
Hello
What I'm trying to achieve is create a class extending XSDSchema and put
some convenience functions in it. I want to have my own interface to
XSDSchema object. This part is done, but I have a hard time loading
content into such object.
Normaly I would do:
XSDParser xsdParser1 = new XSDParser(null);
xsdParser1.parse(uri);
XSDSchema schm = xsdParser1.getSchema();
But since I want to pack that schema into my own object how should I do
this?
I tried extending XSDParser to return my object when getSchema() is
called, but it just doesn't work - it returns empty XSDSchema.
It would suffice to copy one schema to another, since my object is
XSDSchema object on steroids ;-)
Do you have any ideas about this kind of problem?
Marcin
Re: How to copy XSDSchema object [message #78002 is a reply to message #77985] Thu, 02 July 2009 06:56 Go to previous messageGo to next message
Marcin,
Comments below.
Marcin Cylke wrote:
> Hello
> put some convenience functions in it.
That sounds like a bad idea.
> I want to have my own interface to XSDSchema object. This part is
> done, but I have a hard time loading content into such object.
> Normaly I would do:
You should load schemas using an XSDResourceImpl, not this way.
> do this?
You should not want to do that. It's a bad idea and you already see
why. You can't ensure that the rest of the framework will create
instances of your derived class.
Even the XML Schema specification makes the schema definition final, so
again, it's a really bad idea.
Yes, avoid it completely. Put your convenience functions in a
convenient separate class.
> Marcin
Re: How to copy XSDSchema object [message #78018 is a reply to message #78002] Thu, 02 July 2009 08:59 Go to previous message
Ok, thanks for your answer, I'll rework that class.
Marcin
Re: How to copy XSDSchema object [message #604264 is a reply to message #77985] Thu, 02 July 2009 06:56 Go to previous message
Marcin,
Comments below.
Marcin Cylke wrote:
> Hello
> Normaly I would do:
> do this?
> Marcin
Re: How to copy XSDSchema object [message #604270 is a reply to message #78002] Thu, 02 July 2009 08:59 Go to previous message
Marcin
Previous Topic:How to copy XSDSchema object
Next Topic:XSDSimpleTypeDefinition::facetContents not sortable?
Current Time: Fri Oct 31 19:33:01 EDT 2025
Powered by FUDForum. Page generated in 0.06014 seconds
