Extension Problem [message #71206] |
Wed, 10 November 2004 22:20 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: fgdsfg.dfsfs.com
I'm currently working on two plugins: an extention of the VE palette and a
project creation from a library. It works well but I have few questions.
-Is it possible to add code when a property is changed. For example, I have
created an EnhancedJButton and when the visible property is changed, I would
like to add a few lines of code in addition to the "setVisible(false)".
-Is it possible to modify the default syntax highlight of the Java editor of
VE. (like "foo" to be highlighted like a keyword.)
-When a project of my plugin is created, a visual class is automaticly
created and openend in VE. I would like the VE`s editor View to show the
design view "maximized" and the second part (the java editor)to be
"minimized". Is it possible?
thanks in advance for your help
Daniel Godbout
Re: Extension Problem [message #71481 is a reply to message #71270] |
Thu, 11 November 2004 21:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Joe,
> Generally not - the properties come from introspection where get and set
> method pairs are combined. If the extra lines were inserted would they
> need to be remove if the property were unset or set to "true" ?
Yes they would, and new lines would be added.
> What are the extra lines you want to insert ? I'm curious to know more
> about what the scenario is to see whether it's a general one or
> something that maybe can be done in another way.
It would be to add a new method (and it's body) and call it. I think it can
be done in an other way, but I was wondering if it could be done that way.
> Not right now. What you can do is change the VE show the editors are
> shown as tabs instead of with a separator - this is done using the
> Visual Editor preferences. Is this enough ?
Yes, that's great, but is there a way to force it so it shows that way even
if user's preferences aren't that way?
Also, i noticed that if I create a TextField and i change it's field name to
"Name", I get an error because the method getName() already exist (I know
this is normal, but I was wondering if it's possible to deny users to set
the property to that value or to name the method an other name.)
Thanks a lot
Daniel Godbout
Re: Extension Problem [message #603004 is a reply to message #71270] |
Hi Joe,
Thanks a lot
Daniel Godbout
FUDForum. Page generated in 0.03017 seconds
