Re: Agent Controller on Linux [message #59845 is a reply to message #59821] |
Thu, 23 March 2006 19:33 |
Randy D. Smith Messages: 394 Registered: July 2009 |
You're not giving me a lot to go on here... help me understand your set-up.
Since we started talking about getting an AC up, I presume we're dealing
with two different systems. One is your workbench side, with your
Eclipse and TPTP installed on it, and the other is some tartget system
with the AC... or do you have Eclipse installed there as well? If
Eclipse on both places... you did install the TPTP plugins in both
places, right?
This problem you're seeing is on a system where TPTP *was* there and now
it's not? That would be rather strange... the only time I can recall
seeing things such as that were resolved by either (1) reinstallation
(ugh, let's not go there), (2) removal of a workspace that is somehow
corrupting things for us (okay, better than (1) but not necessarily
desirable), and (3) just trying "eclipse -clean" start-up option. So try
(3) first. When it comes up, go to the Help => About Eclipse SDK =>
Plug-in Details, and scroll down to the T's ... if TPTP is not there
then cue the Twilight Zone music and pick your poison, (1) or (2). If
they are there, but you still can't get the TPTP Perspective from Window
=> Open Perspective => Other... (Profiling and Logging is not on the
list), can you screen-shot the Plug-in Details with the TPTPs showing so
I can see which versions of which plugins we're dealing with??
RDS
Lisa Davis wrote:
> Thanks for the heads-up Randy. I had forgotten about all of that. Now
> though, I'm having a strange problem of Eclipse not seeing any of the
> TPTP stuff. When I try to open the Profiling & Logging perspective, the
> option just isn't there because Eclipse is not seeing the plugins for
> some reason. Any ideas on what I've done wrong with that?
> Thanks again!
> Lisa
FUDForum. Page generated in 0.03190 seconds
