problems loading xml schema with targetNamespace [message #64618] |
Wed, 19 October 2005 08:37 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Enrique![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ennims%40surfeu.de) Messages: 44 Registered: July 2009 |
Member |
I would like would like to load an XML model with a XML schema which is
defined
below. I am using Eclipse 3.1 and EMF 2.1 (I am not using RSA anymore)
<xsd:schema xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns="http://www.com.mydb/db"
targetNamespace="http://www.com.mydb/db">
<xsd:complexType name="tableType">
<xsd:attribute name="name" type="xsd:string" use="required"/>
</xsd:complexType>
<xsd:complexType name="dataBaseType">
<xsd:sequence>
<xsd:element maxOccurs="unbounded" name="table" type="tableType"/>
</xsd:sequence>
</xsd:complexType>
<xsd:element name="dataBase" type="dataBaseType"/>
</xsd:schema>
My XML file looks like this:
<dataBase name="db12"/>
So, without defining a targetNamespace in the XML schema it works fine.
But with the mentioned targetNamespace "http://www.com.mydb/db" I get a
PackageNotFoundException which is displayed at the bottom...
I guess this comes from the logical URI of the targetNamespace, which
Parser hasn`t the physical URI for, right?
IŽve read something about a URIConverter, which you can use for mapping
logical URIs tu physical URIs.
So IŽve tried the following Java Code:
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).
put("*", new DbResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
URI uri =
URI.createURI("file:/C:/eclipse/workspace/DbPlugin/samples/load/db.xml ");
URI uri1, uri2;
URIConverter converter = resourceSet.getURIConverter();
Map map = converter.getURIMap();
map.put(uri1 = URI.createURI("http://www.com.mydb/db"),
uri2 =
URI.createURI("platform:/resource/DbPlugin/src/xmlSchema/dbSchema.xsd "));
DbResourceImpl resource = (DbResourceImpl) resourceSet.getResource(uri,
true);
I still get the same exception. What still I need to do?
Thanks in advance.
*** THE EXCEPTION:
Exception in thread "main" Wrapped exception
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri
'null' not found.
(file:/C:/eclipse/workspace/DbPlugin/samples/load/db.xml, 2, 23)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:724)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:765)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:462)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:449)
at
org.eclipse.emf.ecore.xmi.impl.SAXWrapper.startElement(SAXWr apper.java:73)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown
Source)
at org.apache.xerces.impl.dtd.XMLDTDValidator.startElement(Unkn own Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentScannerImpl$ContentDispatc her.scanRootElementHook(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:140)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:169)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:988)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:832)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:349)
at app.Main.main(Main.java:31)
Wrapped by
Wrapped exception
'null' not found.
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
at
at
at
at
at
Wrapped by
org.eclipse.emf.common.util.WrappedException: Package with uri 'null' not
found. (file:/C:/eclipse/workspace/DbPlugin/samples/load/db.xml, 2, 23)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:268)
at
Re: problems loading xml schema with targetNamespace [message #64642 is a reply to message #64618] |
Wed, 19 October 2005 11:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------060608020102090909070506
Enrique,
Have you looked closely at the generated *Example.java in the generated
*.tests plugin? That example provides a working example of what things
you need to register when running standalone.
Note that to conform to your schema your instance should look like:
<dataBase xmlns="http://www.com.mydb/db" name="db12"/>
or
<prefix:dataBase xmlns:prefix="http://www.com.mydb/db" name="db12"/>
Enrique wrote:
> is defined below. I am using Eclipse 3.1 and EMF 2.1 (I am not using
> RSA anymore)
> </xsd:complexType>
> <xsd:sequence>
> type="tableType"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> a PackageNotFoundException which is displayed at the bottom...
> I
Re: problems loading xml schema with targetNamespace [message #597012 is a reply to message #64618] |
Wed, 19 October 2005 11:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33188 Registered: July 2009 |
Enrique,
or
Enrique wrote:
> RSA anymore)
> </xsd:complexType>
> <xsd:sequence>
> type="tableType"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> I
Ed Merks
FUDForum. Page generated in 0.04875 seconds
