Home » Eclipse Projects » Platform - User Assistance (UA) » Re: Help Viewer Error
Re: Help Viewer Error [message #593643] Thu, 08 November 2007 10:10
Jacek Pospychala is currently offline Jacek PospychalaFriend
Wojtek,
it's best to ask this question on eclipse.platform.ua newsgroup, which I
added to the
To:".
Wojtek Michalik wrote:
> Help -> Help Contents
> Opens browser window with title "Problems Viewing Page"
> with contents:
> Unable to connect
> Firefox can't establish a connection to the server at 127.0.0.1:59233.
> * The site could be temporarily unavailable or too busy. Try again
> in a few moments.
> * If you are unable to load any pages, check your computer's network
> connection.
> * If your computer or network is protected by a firewall or proxy,
> make sure that Firefox is permitted to access the Web.
> There are no problems viewing the same help from another user account.
> I use eclipse Eclipse Platform
> Version: 3.3.1.1
> Build id: M20071023-1652
> Linux with gtk.
> It was installed in /usr/local/eclipse directory
> This error does not appear when I set install directory access rights as
> drwxrwxrwx
> when directory access rights are drwxr-xr-x following exeption appears
> ENTRY org.eclipse.help.base 4 0 2007-11-04 10:56:35.881
> !MESSAGE An error occured while starting the help server
> !STACK 0
> java.lang.IllegalArgumentException: Bad temp directory: /usr/local/
> eclipse/configuration/org.eclipse.osgi/bundles/600/data/jett ywork/
> pid_2070971114
> at org.mortbay.http.HttpContext.setTempDirectory
> (HttpContext.java:975)
> at
> org.eclipse.equinox.http.jetty.internal.HttpServerManager.cr eateHttpContext
> (HttpServerManager.java:247)
> at
> org.eclipse.equinox.http.jetty.internal.HttpServerManager.up dated
> (HttpServerManager.java:103)
> at org.eclipse.equinox.http.jetty.internal.Activator.startServe r
> (Activator.java:208)
> at org.eclipse.equinox.http.jetty.JettyConfigurator.startServer
> (JettyConfigurator.java:60)
> at org.eclipse.help.internal.server.WebappManager.start
> (WebappManager.java:43)
> at
> org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning
> (BaseHelpSystem.java:187)
> at org.eclipse.help.internal.base.HelpDisplay.displayHelpURL
> (HelpDisplay.java:152)
> (HelpDisplay.java:42)
> at org.eclipse.help.ui.internal.DefaultHelpUI.displayHelp
> (DefaultHelpUI.java:125)
> at org.eclipse.ui.internal.help.WorkbenchHelpSystem.displayHelp
> (WorkbenchHelpSystem.java:833)
> at org.eclipse.ui.internal.actions.HelpContentsAction$1.run
> (HelpContentsAction.java:83)
> at org.eclipse.swt.custom.BusyIndicator.showWhile
> (BusyIndicator.java:67)
> at org.eclipse.ui.internal.actions.HelpContentsAction.run
> (HelpContentsAction.java:81)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection
> (ActionContributionItem.java:546)
> at org.eclipse.jface.action.ActionContributionItem.access$2
> (ActionContributionItem.java:490)
> at org.eclipse.jface.action.ActionContributionItem$5.handleEven t
> (ActionContributionItem.java:402)
> at org.eclipse.swt.widgets.EventTable.sendEvent
> (EventTable.java:66)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
> at org.eclipse.swt.widgets.Display.runDeferredEvents
> (Display.java:3319)
> at org.eclipse.swt.widgets.Display.readAndDispatch
> (Display.java:2971)
> at org.eclipse.ui.internal.Workbench.runEventLoop
> (Workbench.java:2389)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault
> (Realm.java:289)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
> (Workbench.java:461)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench
> (PlatformUI.java:149)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start
> (IDEApplication.java:106)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run
> (EclipseAppHandle.java:169)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication
> (EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start
> (EclipseAppLauncher.java:76)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run
> (EclipseStarter.java:363)
> (EclipseStarter.java:176)
> at sun.reflect.NativeMethodAccessorImpl.invoke
> (NativeMethodAccessorImpl.java:39)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke
> (DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:585)
> at org.eclipse.equinox.launcher.Main.invokeFramework
> (Main.java:508)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Previous Topic:Discussion Topic - what changes would you like to see in the Welcome experience
Next Topic:Help Viewer Error
Current Time: Thu Dec 26 17:58:49 GMT 2024
Powered by FUDForum. Page generated in 0.04195 seconds
