Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » WrongPrimayKeyException and MissingColoumnExceptions while using elver with jpox
WrongPrimayKeyException and MissingColoumnExceptions while using elver with jpox [message #49988] |
Wed, 13 September 2006 17:31 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: varunkumarm.gmail.com
Iam getting both of these exceptions when i tried running the tutorial
after setting the connection for my database.
I may not be using the other features like resources but i want the schema
to be created first.
The line
PersistenceManager pm = jpoxDataStore.getPersistenceManager(); is shown as
error first and so i changed it to
PersistenceManager pm = jpoxDataStore.getPMF().getPersistenceManager();
I dont think there is nothing wrong with it.
This is stacktrace that is printed.
org.jpox.store.exceptions.WrongPrimaryKeyException: Expected primary key
for table JPOX_TABLES CONSTRAINT JPOX_TABLES_PK PRIMARY KEY () not found
in existing keys CONSTRAINT PRIMARY PRIMARY KEY (CLASS_NAME)
at
org.jpox.store.rdbms.table.TableImpl.validatePrimaryKey(Tabl eImpl.java:284)
at org.jpox.store.rdbms.table.TableImpl.validate(TableImpl.java :186)
at
org.jpox.store.rdbms.SchemaAutoStarter.<init>(SchemaAutoStarter.java:93)
at
org.jpox.store.rdbms.RDBMSManager.initialiseSchema(RDBMSMana ger.java:450)
at org.jpox.store.rdbms.RDBMSManager.<init>(RDBMSManager.java:237)
at
org.jpox.store.rdbms.RDBMSManagerFactory.getStoreManager(RDB MSManagerFactory.java:59)
at
org.jpox.AbstractPersistenceManager.<init>(AbstractPersistenceManager.java:221)
at org.jpox.PersistenceManagerImpl.<init>(PersistenceManagerImpl.java:34)
at
org.jpox.PersistenceManagerFactoryImpl.getPersistenceManager (PersistenceManagerFactoryImpl.java:887)
at
org.jpox.PersistenceManagerFactoryImpl.getPersistenceManager (PersistenceManagerFactoryImpl.java:862)
at
org.elver.store.jpox.emf.JpoxDataStore.createSchema(JpoxData Store.java:377)
at
org.elver.store.jpox.emf.JpoxDataStore.initialize(JpoxDataSt ore.java:186)
at org.eclipse.example.library.Tutorial1.main(Tutorial1.java:74 )
Exception in thread "main"
org.jpox.store.exceptions.MissingColumnException: Required columns missing
from table "LIBRARY" : `NAME`, LIBRARY_ID. Perhaps your MetaData is
incorrect, or you havent enabled "org.jpox.autoCreateColumns".
at
org.jpox.store.rdbms.table.TableImpl.validateColumns(TableIm pl.java:259)
at org.jpox.store.rdbms.table.TableImpl.validate(TableImpl.java :183)
at
org.jpox.store.rdbms.RDBMSManager$ClassAdder.addClassTablesA ndValidate(RDBMSManager.java:2462)
at
org.jpox.store.rdbms.RDBMSManager$ClassAdder.run(RDBMSManage r.java:2003)
at
org.jpox.store.rdbms.RDBMSManager$MgmtTransaction.execute(RD BMSManager.java:1859)
at org.jpox.store.rdbms.RDBMSManager.addClasses(RDBMSManager.ja va:553)
at
org.elver.store.jpox.emf.JpoxDataStore.createSchema(JpoxData Store.java:380)
at
Re: WrongPrimayKeyException and MissingColoumnExceptions while using elver with [message #50127 is a reply to message #50077] |
Thu, 14 September 2006 10:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Here are the contents of the log after added the .properties file.
I did create a database with the name mylibrary;
I just want the schema to be created for further uses.Is there any other
way around.
0 [main] INFO org.elver.store.jpox.emf.JpoxHelper - Registering a
jpox resource factory for all uri's with jpox as the protocol/extension
jpox resource factory for all uri's with ejdo as the protocol/extension
jpox resource dao factory for all uri's with jpoxdao as the
protocol/extension
EListMapping, EListWrapper at the jpox manager for handling elists
FeatureMapMapping, FeatureMapWrapper at the jpox manager for handling
FeatureMap
EObjectMapping at the jpox manager for handling EObjects/AnyType
XMLCalendarMapping at the jpox manager for handling EObjects/AnyType
XMLDurationMapping at the jpox manager for handling EObjects/AnyType
131 [main] DEBUG JPOX.MetaData - resolveEntity(-//Java Persistent
Objects//DTD JPOX Types Metadata 1.0//EN,
http://www.jpox.org/dtd/jpoxtypes_1_0.dtd)
org.jpox.types.UserTypesEntityResolver.getLocalInputSource("/org/jpox/jpoxtypes_1_0.dtd ")
411 [main] DEBUG JPOX.General - Adding support for Java type boolean
(default-persistent=true, DFG=true, default-embedded=true)
411 [main] DEBUG JPOX.General - Adding support for Java type byte
421 [main] DEBUG JPOX.General - Adding support for Java type char
421 [main] DEBUG JPOX.General - Adding support for Java type short
421 [main] DEBUG JPOX.General - Adding support for Java type int
421 [main] DEBUG JPOX.General - Adding support for Java type long
421 [main] DEBUG JPOX.General - Adding support for Java type float
431 [main] DEBUG JPOX.General - Adding support for Java type double
java.lang.Boolean (default-persistent=true, DFG=true,
java.lang.Byte (default-persistent=true, DFG=true, default-embedded=true)
java.lang.Character (default-persistent=true, DFG=true,
java.lang.Short (default-persistent=true, DFG=true, default-embedded=true)
java.lang.Integer (default-persistent=true, DFG=true,
java.lang.Long (default-persistent=true, DFG=true, default-embedded=true)
java.lang.Float (default-persistent=true, DFG=true, default-embedded=true)
java.lang.Double (default-persistent=true, DFG=true, default-embedded=true)
java.math.BigDecimal (default-persistent=true, DFG=true,
java.math.BigInteger (default-persistent=true, DFG=true,
java.util.Date (default-persistent=true, DFG=true, default-embedded=true)
441 [main] DEBUG JPOX.General - Adding support for Java type
java.util.Locale (default-persistent=true, DFG=false,
java.util.TimeZone (default-persistent=false, DFG=false,
default-embedded=false)
java.util.Calendar (default-persistent=false, DFG=false,
java.sql.Date (default-persistent=false, DFG=false, default-embedded=false)
java.sql.Time (default-persistent=false, DFG=false, default-embedded=false)
451 [main] DEBUG JPOX.General - Adding support for Java type
java.sql.Timestamp (default-persistent=false, DFG=false,
java.lang.String (default-persistent=true, DFG=true, default-embedded=true)
java.awt.Color (default-persistent=false, DFG=false,
java.awt.Point (default-persistent=false, DFG=false,
java.lang.Number (default-persistent=true, DFG=true, default-embedded=true)
java.lang.Object (default-persistent=false, DFG=false,
java.net.URL (default-persistent=false, DFG=false, default-embedded=false)
501 [main] DEBUG JPOX.General - Adding support for Java type [Z
(default-persistent=true, DFG=false, default-embedded=true)
501 [main] DEBUG JPOX.General - Adding support for Java type [B
501 [main] DEBUG JPOX.General - Adding support for Java type [C
501 [main] DEBUG JPOX.General - Adding support for Java type [D
501 [main] DEBUG JPOX.General - Adding support for Java type [F
551 [main] DEBUG JPOX.General - Adding support for Java type [I
551 [main] DEBUG JPOX.General - Adding support for Java type [J
551 [main] DEBUG JPOX.General - Adding support for Java type [S
[Ljava.lang.Boolean; (default-persistent=true, DFG=false,
[Ljava.lang.Byte; (default-persistent=true, DFG=false,
[Ljava.lang.Character; (default-persistent=true, DFG=false,
[Ljava.lang.Double; (default-persistent=true, DFG=false,
[Ljava.lang.Float; (default-persistent=true, DFG=false,
[Ljava.lang.Integer; (default-persistent=true, DFG=false,
[Ljava.lang.Long; (default-persistent=true, DFG=false,
[Ljava.lang.Short; (default-persistent=true, DFG=false,
[Ljava.lang.String; (default-persistent=true, DFG=false,
[Ljava.lang.Number; (default-persistent=true, DFG=false,
[Ljava.util.Date; (default-persistent=true, DFG=false,
[Ljava.util.Locale; (default-persistent=true, DFG=false,
[Ljava.math.BigInteger; (default-persistent=true, DFG=false,
[Ljava.math.BigDecimal; (default-persistent=true, DFG=false,
561 [main] DEBUG JPOX.General - Adding support for Java type
java.util.ArrayList (default-persistent=true, DFG=false,
java.util.Collection (default-persistent=true, DFG=false,
java.util.HashMap (default-persistent=true, DFG=false,
java.util.HashSet (default-persistent=true, DFG=false,
581 [main] DEBUG JPOX.General - Adding support for Java type
java.util.Hashtable (default-persistent=true, DFG=false,
java.util.LinkedList (default-persistent=true, DFG=false,
java.util.List (default-persistent=true, DFG=false, default-embedded=false)
591 [main] DEBUG JPOX.General - Adding support for Java type
java.util.Map (default-persistent=true, DFG=false, default-embedded=false)
java.util.Set (default-persistent=true, DFG=false, default-embedded=false)
java.util.SortedMap (default-persistent=false, DFG=false,
java.util.SortedSet (default-persistent=false, DFG=false,
java.util.Stack (default-persistent=false, DFG=false,
601 [main] DEBUG JPOX.General - Adding support for Java type
java.util.TreeMap (default-persistent=true, DFG=false,
java.util.TreeSet (default-persistent=true, DFG=false,
java.util.Vector (default-persistent=true, DFG=false,
java.util.Properties (default-persistent=false, DFG=false,
org.jpox.store.OID (default-persistent=false, DFG=false,
org.jpox.sco.ArrayList (default-persistent=true, DFG=false,
org.jpox.sco.Collection (default-persistent=true, DFG=false,
org.jpox.sco.HashMap (default-persistent=true, DFG=false,
611 [main] DEBUG JPOX.General - Adding support for Java type
org.jpox.sco.HashSet (default-persistent=true, DFG=false,
org.jpox.sco.Hashtable (default-persistent=true, DFG=false,
org.jpox.sco.LinkedList (default-persistent=true, DFG=false,
org.jpox.sco.List (default-persistent=true, DFG=false,
org.jpox.sco.Map (default-persistent=true, DFG=false,
org.jpox.sco.Set (default-persistent=true, DFG=false,
org.jpox.sco.SortedMap (default-persistent=false, DFG=false,
812 [main] DEBUG JPOX.General - Adding support for Java type
org.jpox.sco.SortedSet (default-persistent=false, DFG=false,
org.jpox.sco.Stack (default-persistent=false, DFG=false,
org.jpox.sco.TreeMap (default-persistent=true, DFG=false,
822 [main] DEBUG JPOX.General - Adding support for Java type
org.jpox.sco.TreeSet (default-persistent=true, DFG=false,
org.jpox.sco.Vector (default-persistent=true, DFG=false,
org.jpox.sco.Properties (default-persistent=false, DFG=false,
java.util.BitSet (default-persistent=false, DFG=false,
java.util.GregorianCalendar (default-persistent=false, DFG=false,
java.util.Currency (default-persistent=true, DFG=false,
java.util.LinkedHashSet (default-persistent=true, DFG=false,
852 [main] DEBUG JPOX.General - Adding support for Java type
java.util.LinkedHashMap (default-persistent=true, DFG=false,
org.jpox.sco.LinkedHashSet (default-persistent=true, DFG=false,
org.jpox.sco.LinkedHashMap (default-persistent=true, DFG=false,
java.net.URI (default-persistent=false, DFG=false, default-embedded=false)
1022 [main] DEBUG JPOX.General - Adding support for Java type
org.eclipse.emf.common.util.EList (default-persistent=true, DFG=false,
1052 [main] DEBUG JPOX.General - Adding support for Java type
org.eclipse.emf.ecore.util.FeatureMap (default-persistent=true, DFG=false,
org.eclipse.emf.ecore.EObject (default-persistent=true, DFG=true,
1102 [main] DEBUG JPOX.General - Adding support for Java type
org.eclipse.emf.ecore.xml.type.internal.XMLCalendar
org.eclipse.emf.ecore.xml.type.internal.XMLDuration
1182 [main] DEBUG org.elver.store.jpox.emf.JpoxDataStore - Option
updateschema: true
1603 [main] DEBUG org.elver.store.ERuntime - Determining concrete classes
for package library
1613 [main] DEBUG org.elver.store.jpox.emf.JpoxDataStore - Registering
enum type mapper/wrapper for eclass:
org.eclipse.example.library.BookCategory
1623 [main] DEBUG JPOX.General - Adding support for Java type
org.eclipse.example.library.BookCategory (default-persistent=true,
1623 [main] DEBUG org.elver.store.util.StoreUtil - >>>> Building or
descriptor file List
1623 [main] DEBUG org.elver.store.util.StoreUtil - Try path: ;package.jdo
/org/eclipse/example/library/package.jdo
/org/eclipse/example/package.jdo
/org/eclipse/package.jdo
/org/package.jdo
1623 [main] DEBUG org.elver.store.util.StoreUtil - Try path: /package.jdo
1623 [main] DEBUG org.elver.store.util.StoreUtil - !!Found!!
/org/eclipse/example/library/impl/package.jdo
/org/eclipse/emf/ecore/impl/package.jdo
/org/eclipse/emf/ecore/package.jdo
/org/eclipse/emf/package.jdo
1643 [main] DEBUG JPOX.MetaData - resolveEntity(, file:/javax/jdo/jdo.dtd)
org.jpox.metadata.JDOEntityResolver.getLocalInputSource("/org/jpox/jdo_2_0.dtd ")
1753 [main] DEBUG org.elver.store.jpox.emf.JpoxDataStore - Updating
database schema
1863 [main] INFO JPOX.JDO - PersistenceManagerFactory - Vendor: JPOX
Version: 1.1.0-rc-1
1863 [main] INFO JPOX.JDO - PersistenceManagerFactory initialised for
datastore URL=jdbc:odbc:mylibrary driver=sun.jdbc.odbc.JdbcOdbcDriver
userName=root
1863 [main] DEBUG JPOX.JDO - ================ PMF Configuration
1863 [main] DEBUG JPOX.JDO - JDO Standard Options : singlethreaded,
retainValues, nontransactionalRead
1863 [main] DEBUG JPOX.JDO - Persistence Options : reachability-at-commit
1863 [main] DEBUG JPOX.JDO - Schema : AutoCreate(Schema,Columns),
Validate(Tables,Columns,Constraints), CheckTableViewExistence,
foreignKeyCreateMode=AUTO
1863 [main] DEBUG JPOX.JDO - Schema Identifiers : catalog=null,
schema=null
1863 [main] DEBUG JPOX.JDO - MetaData : File Suffixes (JDO = jdo, ORM =
orm, JDOQUERY = jdoquery), ORM Mapping name=(none)
1863 [main] DEBUG JPOX.JDO - Datastore Connection Pooling : None
1863 [main] DEBUG JPOX.JDO - Types Control : stringDefaultLength=255,
dateTimezone=UTC
1863 [main] DEBUG JPOX.JDO - Initialisation : mechanism=SchemaTable,
mode=Quiet
1863 [main] DEBUG JPOX.JDO - Transactions : pessimistic,
isolationLevel=2, isolationLevel(POID)=2, transactionAttribute(POID)=New
1883 [main] DEBUG JPOX.JDO - Cache : Level1
(org.elver.store.jpox.emf.cache.EMFWeakRefCache), Collections/Maps
1883 [main] DEBUG JPOX.JDO - Queries : fetchSize=0,
fetchDirection=forward, resultSetType=forward-only,
resultSetConcurrency=read-only
2023 [main] DEBUG JPOX.JDO - Persistence Manager
"org.jpox.PersistenceManagerImpl@bd928a" opened for datastore ""
2634 [main] DEBUG JPOX.RDBMS.SCHEMA - Database adapter allows catalogs to
be used in table definitions
2634 [main] INFO JPOX.RDBMS - RDBMS Adapter initialised : MySQLAdapter :
MySQL version=5.0.18-nt, major=5, minor=0, revision=18
Identifier Names : UPPERCASE
Driver name=JDBC-ODBC Bridge (myodbc3.dll), version=2.0001 (03.51.11),
major=2, minor=1
Identifier Max Lengths : Table=64 Column=64 Constraint=64 Index=64
Delimeters=`
Identifier Support in DDL : catalog=true schema=false
2794 [main] DEBUG JPOX.MetaData - resolveEntity(-//Java Persistent
Objects//DTD JPOX Datastore Mapping 1.0//EN,
http://www.jpox.org/dtd/datastoremappings_1_0.dtd)
org.jpox.store.mapping.DatastoreMappingEntityResolver.getLoc alInputSource( "/org/jpox/datastoremapping_1_0.dtd")
2955 [main] DEBUG JPOX.RDBMS - Column "DELETEME1158230050512.UNUSED"
added to internal representation of table.
2955 [main] INFO JPOX.RDBMS - Creating table DELETEME1158230050512
2965 [main] DEBUG JPOX.RDBMS.DDL - CREATE TABLE DELETEME1158230050512
UNUSED integer NOT NULL
3145 [main] DEBUG JPOX.RDBMS.DDL - Execution Time = 180 ms
3516 [main] INFO JPOX.RDBMS - Dropping table DELETEME1158230050512
3516 [main] DEBUG JPOX.RDBMS.DDL - DROP TABLE DELETEME1158230050512
3636 [main] DEBUG JPOX.RDBMS.DDL - Execution Time = 120 ms
3636 [main] INFO JPOX.RDBMS.SCHEMA - Initialising Catalog "mylibrary",
Schema "" using "SchemaTable" auto-start option
3646 [main] DEBUG JPOX.RDBMS - Column "JPOX_TABLES.CLASS_NAME" added to
3646 [main] DEBUG JPOX.RDBMS - Column "JPOX_TABLES.`TABLE_NAME`" added to
3646 [main] DEBUG JPOX.RDBMS - Column "JPOX_TABLES.`TYPE`" added to
3646 [main] DEBUG JPOX.RDBMS - Column "JPOX_TABLES.OWNER" added to
3646 [main] DEBUG JPOX.RDBMS - Column "JPOX_TABLES.VERSION" added to
3666 [main] INFO JPOX.RDBMS - Creating table JPOX_TABLES
3666 [main] DEBUG JPOX.RDBMS.DDL - CREATE TABLE JPOX_TABLES
CLASS_NAME VARCHAR(128) BINARY NOT NULL UNIQUE,
`TABLE_NAME` VARCHAR(128) BINARY NOT NULL,
`TYPE` VARCHAR(4) BINARY NOT NULL,
OWNER VARCHAR(2) BINARY NOT NULL,
VERSION VARCHAR(20) BINARY NOT NULL
3806 [main] DEBUG JPOX.RDBMS.DDL - Execution Time = 140 ms
3806 [main] DEBUG JPOX.RDBMS - Validating table : JPOX_TABLES
5148 [main] DEBUG JPOX.RDBMS.SCHEMA - Column info retrieved for table
"JPOX_TABLES" : 5 columns found
at
at
at
at
at
org.jpox.AbstractPersistenceManager.<init>(AbstractPersistenceManager.java:221)5328
[main] ERROR JPOX.RDBMS.SCHEMA - Failed to validate SchemaTable for
Schema "". Either it doesnt exist, or doesnt validate
at
at
at
at
5338 [main] DEBUG JPOX.RDBMS.SCHEMA -
5338 [main] DEBUG JPOX.RDBMS.SCHEMA - Dropping JPOX_TABLES and recreating
as new
5338 [main] INFO JPOX.RDBMS - Dropping table JPOX_TABLES
5338 [main] DEBUG JPOX.RDBMS.DDL - DROP TABLE JPOX_TABLES
5418 [main] DEBUG JPOX.RDBMS.DDL - Execution Time = 80 ms
5448 [main] INFO JPOX.RDBMS - Creating table JPOX_TABLES
5448 [main] DEBUG JPOX.RDBMS.DDL - CREATE TABLE JPOX_TABLES
5609 [main] DEBUG JPOX.RDBMS.DDL - Execution Time = 161 ms
5609 [main] DEBUG JPOX.RDBMS - Validating table : JPOX_TABLES
6860 [main] DEBUG JPOX.RDBMS.SCHEMA - Column info retrieved for table
7041 [main] ERROR JPOX.RDBMS.SCHEMA - Failed to validate SchemaTable for
7041 [main] DEBUG JPOX.RDBMS.SCHEMA -
7061 [main] DEBUG JPOX.RDBMS.SQL - SELECT
CLASS_NAME,`TABLE_NAME`,`TYPE`,OWNER,VERSION FROM JPOX_TABLES ORDER BY
`TABLE_NAME`
7061 [main] DEBUG JPOX.RDBMS.SQL - Execution Time = 0 ms
7061 [main] INFO JPOX.RDBMS.SCHEMA - Catalog "mylibrary", Schema ""
initialised - managing 0 classes
7171 [main] DEBUG JPOX.Cache - Level 1 Cache of type
"org.elver.store.jpox.emf.cache.EMFWeakRefCache" initialised
7241 [main] DEBUG JPOX.MetaData - Registering class "java.lang.Character"
as not having MetaData.
"org.jpox.sco.Collection" as not having MetaData.
"java.util.LinkedList" as not having MetaData.
7241 [main] DEBUG JPOX.MetaData - Registering class "[Ljava.lang.Float;"
7241 [main] DEBUG JPOX.MetaData - Registering class "boolean" as not
having MetaData.
7241 [main] DEBUG JPOX.MetaData - Registering class "char" as not having
MetaData.
7241 [main] DEBUG JPOX.MetaData - Registering class "java.util.SortedMap"
"java.util.GregorianCalendar" as not having MetaData.
"org.jpox.sco.TreeMap" as not having MetaData.
7241 [main] DEBUG JPOX.MetaData - Registering class "java.util.TreeMap"
7241 [main] DEBUG JPOX.MetaData - Registering class "org.jpox.sco.Map" as
7241 [main] DEBUG JPOX.MetaData - Registering class "[Ljava.lang.String;"
"java.util.LinkedHashMap" as not having MetaData.
"org.jpox.sco.SortedSet" as not having MetaData.
"org.jpox.sco.SortedMap" as not having MetaData.
"[Ljava.math.BigInteger;" as not having MetaData.
7241 [main] DEBUG JPOX.MetaData - Registering class "java.net.URL" as not
having MetaData.
7241 [main] DEBUG JPOX.MetaData - Registering class "[Ljava.lang.Number;"
7241 [main] DEBUG JPOX.MetaData - Registering class "java.sql.Date" as
7241 [main] DEBUG JPOX.MetaData - Registering class "[Z" as not having
MetaData.
7241 [main] DEBUG JPOX.MetaData - Registering class "java.sql.Timestamp"
7241 [main] DEBUG JPOX.MetaData - Registering class "long" as not having
MetaData.
7241 [main] DEBUG JPOX.MetaData - Registering class "org.jpox.sco.List"
"java.util.Collection" as not having MetaData.
7241 [main] DEBUG JPOX.MetaData - Registering class "java.lang.Integer"
7241 [main] DEBUG JPOX.MetaData - Registering class "java.util.ArrayList"
7251 [main] DEBUG JPOX.MetaData - Registering class
"org.jpox.sco.HashMap" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.awt.Point" as
"[Ljava.lang.Character;" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "[B" as not having
MetaData.
"org.eclipse.emf.common.util.EList" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "org.jpox.sco.Stack"
7251 [main] DEBUG JPOX.MetaData - Registering class "[Ljava.util.Locale;"
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.TimeZone"
7251 [main] DEBUG JPOX.MetaData - Registering class "[C" as not having
MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "double" as not
having MetaData.
"org.jpox.sco.LinkedHashSet" as not having MetaData.
"org.jpox.sco.HashSet" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.lang.Number" as
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.Stack" as
7251 [main] DEBUG JPOX.MetaData - Registering class "java.lang.Float" as
"[Ljava.lang.Boolean;" as not having MetaData.
"org.jpox.sco.TreeSet" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.lang.String" as
7251 [main] DEBUG JPOX.MetaData - Registering class "java.lang.Short" as
"org.eclipse.emf.ecore.xml.type.internal.XMLCalendar" as not having
MetaData.
"java.math.BigDecimal" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.HashMap"
7251 [main] DEBUG JPOX.MetaData - Registering class "java.net.URI" as not
having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "int" as not having
MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.lang.Long" as
"org.eclipse.emf.ecore.EObject" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.Set" as
7251 [main] DEBUG JPOX.MetaData - Registering class "[I" as not having
MetaData.
"org.eclipse.emf.ecore.util.FeatureMap" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.Locale" as
"[Ljava.lang.Integer;" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "org.jpox.sco.Set" as
7251 [main] DEBUG JPOX.MetaData - Registering class "[Ljava.lang.Byte;"
7251 [main] DEBUG JPOX.MetaData - Registering class "java.lang.Object" as
"org.jpox.sco.Properties" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "[Ljava.lang.Double;"
7251 [main] DEBUG JPOX.MetaData - Registering class "org.jpox.store.OID"
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.TreeSet"
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.Hashtable"
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.BitSet" as
7251 [main] DEBUG JPOX.MetaData - Registering class "[J" as not having
MetaData.
"org.eclipse.emf.ecore.xml.type.internal.XMLDuration" as not having
MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "float" as not having
MetaData.
"java.util.Properties" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.Date" as
7251 [main] DEBUG JPOX.MetaData - Registering class "[Ljava.lang.Long;"
"org.eclipse.example.library.BookCategory" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.lang.Double" as
"org.jpox.sco.LinkedHashMap" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "short" as not having
MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "org.jpox.sco.Vector"
"org.jpox.sco.ArrayList" as not having MetaData.
"org.jpox.sco.Hashtable" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "[Ljava.util.Date;"
7251 [main] DEBUG JPOX.MetaData - Registering class "byte" as not having
MetaData.
"java.math.BigInteger" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "[Ljava.lang.Short;"
7251 [main] DEBUG JPOX.MetaData - Registering class "java.awt.Color" as
7251 [main] DEBUG JPOX.MetaData - Registering class "[S" as not having
MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.sql.Time" as
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.Calendar"
7251 [main] DEBUG JPOX.MetaData - Registering class "java.lang.Byte" as
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.List" as
7251 [main] DEBUG JPOX.MetaData - Registering class "java.lang.Boolean"
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.Vector" as
"org.jpox.sco.LinkedList" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.SortedSet"
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.Map" as
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.Currency"
"java.util.LinkedHashSet" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "java.util.HashSet"
7251 [main] DEBUG JPOX.MetaData - Registering class "[F" as not having
MetaData.
"[Ljava.math.BigDecimal;" as not having MetaData.
7251 [main] DEBUG JPOX.MetaData - Registering class "[D" as not having
MetaData.
7371 [main] INFO JPOX.MetaData - Parsing MetaData from file
"/F:/workspaces/EMFTests/Library/bin/package.jdo"
7381 [main] DEBUG JPOX.MetaData - resolveEntity(, file:/javax/jdo/jdo.dtd)
7391 [main] DEBUG JPOX.MetaData - Starting parse of element "jdo (stack
size=1) Attributes[]"
7391 [main] DEBUG JPOX.MetaData - Starting parse of element "package
(stack size=1) Attributes[name="org.eclipse.example.library.impl"]"
7391 [main] DEBUG JPOX.MetaData - Starting parse of element "class (stack
size=2) Attributes[name="org.eclipse.example.library.impl.BookImpl"
,requires-extent="true" ,persistence-modifier="persistence-capable"
,detachable="true" ,table="book" ,identity-type="datastore"]"
7401 [main] DEBUG JPOX.MetaData - Starting parse of element "implements
(stack size=3) Attributes[name="org.eclipse.example.library.Book"]"
7401 [main] DEBUG JPOX.MetaData - Ending parse of element "implements
(stack size=4"
(stack size=3) Attributes[name="org.eclipse.emf.ecore.EObject"]"
7541 [main] DEBUG JPOX.MetaData - Ending parse of element "implements
(stack size=4"
7541 [main] DEBUG JPOX.MetaData - Starting parse of element "implements
(stack size=3) Attributes[name="org.eclipse.emf.common.notify.Notifier"]"
(stack size=4"
7541 [main] DEBUG JPOX.MetaData - Starting parse of element "inheritance
(stack size=3) Attributes[strategy="new-table"]"
7541 [main] DEBUG JPOX.MetaData - Ending parse of element "inheritance
(stack size=4"
7541 [main] DEBUG JPOX.MetaData - Starting parse of element "field (stack
size=3) Attributes[name="title" ,persistence-modifier="persistent"
,null-value="none" ,primary-key="false"]"
7551 [main] DEBUG JPOX.MetaData - Starting parse of element "unique
(stack size=4) Attributes[deferred="false"]"
7551 [main] DEBUG JPOX.MetaData - Ending parse of element "unique (stack
size=5"
7551 [main] DEBUG JPOX.MetaData - Ending parse of element "field (stack
size=4"
7551 [main] DEBUG JPOX.MetaData - Starting parse of element "field (stack
size=3) Attributes[name="pages" ,persistence-modifier="persistent"
size=5"
7561 [main] DEBUG JPOX.MetaData - Ending parse of element "field (stack
size=4"
7561 [main] DEBUG JPOX.MetaData - Starting parse of element "field (stack
size=3) Attributes[name="category" ,persistence-modifier="persistent"
,null-value="none" ,embedded="true" ,primary-key="false"]"
7561 [main] DEBUG JPOX.MetaData - Starting parse of element "unique
7561 [main] DEBUG JPOX.MetaData - Ending parse of element "unique (stack
size=5"
size=4"
size=3) Attributes[name="author" ,persistence-modifier="persistent"
,delete-action="restrict" ,null-value="none" ,primary-key="false"]"
7561 [main] DEBUG JPOX.MetaData - Starting parse of element "foreign-key
(stack size=4) Attributes[delete-action="restrict"
,update-action="restrict"]"
7561 [main] DEBUG JPOX.MetaData - Starting parse of element "column
(stack size=5) Attributes[name="author_id" ,allows-null="true"]"
7561 [main] DEBUG JPOX.MetaData - Ending parse of element "column (stack
size=6"
7561 [main] DEBUG JPOX.MetaData - Ending parse of element "foreign-key
(stack size=5"
7561 [main] DEBUG JPOX.MetaData - Starting parse of element "extension
(stack size=4) Attributes[vendor-name="jpox" ,key="implementation-classes"
,value="org.eclipse.example.library.impl.WriterImpl"]"
7561 [main] DEBUG JPOX.MetaData - Ending parse of element "extension
(stack size=4"
size=4"
7561 [main] DEBUG JPOX.MetaData - Ending parse of element "class (stack
size=3"
7561 [main] DEBUG JPOX.MetaData - Starting parse of element "class (stack
size=2) Attributes[name="org.eclipse.example.library.impl.LibraryImpl "
,detachable="true" ,table="library" ,identity-type="datastore"]"
7561 [main] DEBUG JPOX.MetaData - Starting parse of element "implements
(stack size=3) Attributes[name="org.eclipse.example.library.Library"]"
7561 [main] DEBUG JPOX.MetaData - Ending parse of element "implements
(stack size=4"
(stack size=4"
7571 [main] DEBUG JPOX.MetaData - Starting parse of element "implements
7571 [main] DEBUG JPOX.MetaData - Ending parse of element "implements
(stack size=4"
7571 [main] DEBUG JPOX.MetaData - Starting parse of element "inheritance
7571 [main] DEBUG JPOX.MetaData - Ending parse of element "inheritance
(stack size=4"
7571 [main] DEBUG JPOX.MetaData - Starting parse of element "field (stack
size=3) Attributes[name="name" ,persistence-modifier="persistent"
7571 [main] DEBUG JPOX.MetaData - Starting parse of element "unique
7571 [main] DEBUG JPOX.MetaData - Ending parse of element "unique (stack
size=5"
7571 [main] DEBUG JPOX.MetaData - Ending parse of element "field (stack
size=4"
size=3) Attributes[name="writers" ,persistence-modifier="persistent"
,delete-action="restrict" ,primary-key="false" ,null-value="none"]"
7571 [main] DEBUG JPOX.MetaData - Starting parse of element "collection
(stack size=4)
Attributes[element-type="org.eclipse.example.library.impl.WriterImpl "
,dependent-element="true"]"
7571 [main] DEBUG JPOX.MetaData - Starting parse of element "extension
(stack size=5) Attributes[vendor-name="jpox" ,key="cache-lazy-loading"
,value="true"]"
7571 [main] DEBUG JPOX.MetaData - Ending parse of element "extension
(stack size=5"
7571 [main] DEBUG JPOX.MetaData - Ending parse of element "collection
(stack size=5"
7571 [main] DEBUG JPOX.MetaData - Starting parse of element "order (stack
size=4) Attributes[column="LIBRARY_WRITERS_IDX"]"
7571 [main] DEBUG JPOX.MetaData - Ending parse of element "order (stack
size=5"
7581 [main] DEBUG JPOX.MetaData - Starting parse of element "column
(stack size=4) Attributes[name="writers_id" ,allows-null="true"]"
7581 [main] DEBUG JPOX.MetaData - Ending parse of element "column (stack
size=5"
7581 [main] DEBUG JPOX.MetaData - Starting parse of element "foreign-key
(stack size=4) Attributes[delete-action="cascade"
,update-action="cascade"]"
7581 [main] DEBUG JPOX.MetaData - Ending parse of element "foreign-key
(stack size=5"
7581 [main] DEBUG JPOX.MetaData - Ending parse of element "field (stack
size=4"
7581 [main] DEBUG JPOX.MetaData - Starting parse of element "field (stack
size=3) Attributes[name="books" ,persistence-modifier="persistent"
7581 [main] DEBUG JPOX.MetaData - Starting parse of element "collection
(stack size=4)
Attributes[element-type="org.eclipse.example.library.impl.BookImpl "
7581 [main] DEBUG JPOX.MetaData - Starting parse of element "extension
,value="true"]"
7581 [main] DEBUG JPOX.MetaData - Ending parse of element "extension
(stack size=5"
7581 [main] DEBUG JPOX.MetaData - Ending parse of element "collection
(stack size=5"
7581 [main] DEBUG JPOX.MetaData - Starting parse of element "order (stack
size=4) Attributes[column="LIBRARY_BOOKS_IDX"]"
7581 [main] DEBUG JPOX.MetaData - Ending parse of element "order (stack
size=5"
(stack size=4) Attributes[name="books_id" ,allows-null="true"]"
size=5"
(stack size=5"
size=4"
7581 [main] DEBUG JPOX.MetaData - Ending parse of element "class (stack
size=3"
7581 [main] DEBUG JPOX.MetaData - Starting parse of element "class (stack
size=2) Attributes[name="org.eclipse.example.library.impl.WriterImpl "
,detachable="true" ,table="writer" ,identity-type="datastore"]"
7782 [main] DEBUG JPOX.MetaData - Starting parse of element "implements
(stack size=3) Attributes[name="org.eclipse.example.library.Writer"]"
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "implements
(stack size=4"
(stack size=4"
(stack size=4"
7782 [main] DEBUG JPOX.MetaData - Starting parse of element "inheritance
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "inheritance
(stack size=4"
7782 [main] DEBUG JPOX.MetaData - Starting parse of element "field (stack
7782 [main] DEBUG JPOX.MetaData - Starting parse of element "unique
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "unique (stack
size=5"
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "field (stack
size=4"
,mapped-by="author" ,delete-action="restrict" ,primary-key="false"
7782 [main] DEBUG JPOX.MetaData - Starting parse of element "collection
(stack size=4)
,dependent-element="false"]"
7782 [main] DEBUG JPOX.MetaData - Starting parse of element "extension
,value="true"]"
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "extension
(stack size=5"
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "collection
(stack size=5"
7782 [main] DEBUG JPOX.MetaData - Starting parse of element "order (stack
size=4) Attributes[column="WRITER_BOOKS_IDX"]"
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "order (stack
size=5"
7782 [main] DEBUG JPOX.MetaData - Starting parse of element "column
(stack size=4) Attributes[name="author_id" ,allows-null="true"]"
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "column (stack
size=5"
7782 [main] DEBUG JPOX.MetaData - Starting parse of element "foreign-key
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "foreign-key
(stack size=5"
size=4"
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "class (stack
size=3"
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "package (stack
size=2"
7782 [main] DEBUG JPOX.MetaData - Ending parse of element "jdo (stack
size=1"
7782 [main] DEBUG JPOX.MetaData - Populating Meta-Data for class
org.eclipse.example.library.impl.BookImpl.
7792 [main] DEBUG JPOX.MetaData - MetaData of type "orm" for class
"org.eclipse.example.library.impl.BookImpl" not found
7802 [main] DEBUG JPOX.MetaData - MetaData of type "jdo" for class
"org.eclipse.emf.ecore.impl.EObjectImpl" not found
7832 [main] DEBUG JPOX.MetaData - Registering class
"org.eclipse.emf.ecore.impl.EObjectImpl" as not having MetaData.
7932 [main] DEBUG JPOX.MetaData - MetaData of type "jdo" for class
"org.eclipse.emf.ecore.impl.BasicEObjectImpl" not found
7932 [main] DEBUG JPOX.MetaData - Registering class
"org.eclipse.emf.ecore.impl.BasicEObjectImpl" as not having MetaData.
7962 [main] DEBUG JPOX.MetaData - MetaData of type "jdo" for class
"org.eclipse.emf.common.notify.impl.BasicNotifierImpl" not found
7972 [main] DEBUG JPOX.MetaData - Registering class
"org.eclipse.emf.common.notify.impl.BasicNotifierImpl" as not having
MetaData.
7972 [main] DEBUG JPOX.MetaData - Populating Meta-Data for class
org.eclipse.example.library.impl.LibraryImpl.
7972 [main] DEBUG JPOX.MetaData - MetaData of type "orm" for class
"org.eclipse.example.library.impl.LibraryImpl" not found
org.eclipse.example.library.impl.WriterImpl.
"org.eclipse.example.library.impl.WriterImpl" not found
7972 [main] DEBUG JPOX.MetaData - MetaData of type "jdo" for class
"org.eclipse.example.library.impl.BookImpl" will use
file:/F:/workspaces/EMFTests/Library/bin/package.jdo
7972 [main] DEBUG JPOX.MetaData - Initialising Meta-Data for class
8092 [main] INFO JPOX.RDBMS.SCHEMA - Managing Persistence of Class :
org.eclipse.example.library.impl.BookImpl [Table : BOOK,
InheritanceStrategy : new-table]
8092 [main] DEBUG JPOX.RDBMS.SQL - INSERT IGNORE INTO JPOX_TABLES
(CLASS_NAME,`TABLE_NAME`,`TYPE`,OWNER,VERSION) VALUES (?,?,?,?,?)
8182 [main] DEBUG JPOX.RDBMS.SQL - Execution Time = 90 ms
8182 [main] DEBUG JPOX.RDBMS - Column "BOOK.BOOK_ID" added to internal
8182 [main] INFO JPOX.RDBMS.SCHEMA - Managing Persistence of Class :
org.eclipse.example.library.impl.WriterImpl [Table : WRITER,
8202 [main] DEBUG JPOX.RDBMS.SQL - INSERT IGNORE INTO JPOX_TABLES
8272 [main] DEBUG JPOX.RDBMS.SQL - Execution Time = 70 ms
8272 [main] DEBUG JPOX.RDBMS - Column "WRITER.WRITER_ID" added to
8272 [main] INFO JPOX.RDBMS.SCHEMA - Managing Persistence of Class :
org.eclipse.example.library.impl.LibraryImpl [Table : LIBRARY,
8272 [main] DEBUG JPOX.RDBMS.SQL - INSERT IGNORE INTO JPOX_TABLES
8342 [main] DEBUG JPOX.RDBMS.SQL - Execution Time = 70 ms
8342 [main] DEBUG JPOX.RDBMS - Column "LIBRARY.LIBRARY_ID" added to
8453 [main] DEBUG JPOX.RDBMS - Table LIBRARY will manage the persistence
of the fields for class org.eclipse.example.library.impl.LibraryImpl
(inheritance strategy="new-table")
8463 [main] DEBUG JPOX.RDBMS - Field
[org.eclipse.example.library.impl.LibraryImpl.books] -> Column(s) [[none]]
8463 [main] DEBUG JPOX.RDBMS - Column "LIBRARY.`NAME`" added to internal
[org.eclipse.example.library.impl.LibraryImpl.name] -> Column(s)
[LIBRARY.`NAME`]
[org.eclipse.example.library.impl.LibraryImpl.writers] -> Column(s)
[[none]]
8463 [main] DEBUG JPOX.RDBMS - Table BOOK will manage the persistence of
the fields for class org.eclipse.example.library.impl.BookImpl
8483 [main] DEBUG JPOX.RDBMS - Column
"BOOK.AUTHOR_WRITER_IMPL_WRITER_ID_EID" added to internal representation
of table.
8483 [main] INFO JPOX.RDBMS - Added column for type "class
org.eclipse.example.library.impl.WriterImpl" for field "author" (field
declared as reference type - interface/Object)
8483 [main] DEBUG JPOX.RDBMS - Field
[org.eclipse.example.library.impl.BookImpl.author] -> Column(s)
[BOOK.AUTHOR_WRITER_IMPL_WRITER_ID_EID]
8483 [main] DEBUG JPOX.RDBMS - Column "BOOK.CATEGORY" added to internal
[org.eclipse.example.library.impl.BookImpl.category] -> Column(s)
[BOOK.CATEGORY]
8483 [main] DEBUG JPOX.RDBMS - Column "BOOK.PAGES" added to internal
[org.eclipse.example.library.impl.BookImpl.pages] -> Column(s) [BOOK.PAGES]
8483 [main] DEBUG JPOX.RDBMS - Column "BOOK.TITLE" added to internal
[org.eclipse.example.library.impl.BookImpl.title] -> Column(s) [BOOK.TITLE]
8483 [main] DEBUG JPOX.RDBMS - Table WRITER will manage the persistence
of the fields for class org.eclipse.example.library.impl.WriterImpl
[org.eclipse.example.library.impl.WriterImpl.books] -> Column(s) [[none]]
8483 [main] DEBUG JPOX.RDBMS - Column "BOOK.BOOKS_LIBRARY_ID_OID" added
8493 [main] DEBUG JPOX.RDBMS - Column "BOOK.LIBRARY_BOOKS_IDX" added to
8493 [main] DEBUG JPOX.RDBMS - Column "BOOK.AUTHOR_INTEGER_IDX" added to
8493 [main] DEBUG JPOX.RDBMS - Column "WRITER.`NAME`" added to internal
8493 [main] DEBUG JPOX.RDBMS - Field
[org.eclipse.example.library.impl.WriterImpl.name] -> Column(s)
[WRITER.`NAME`]
8493 [main] DEBUG JPOX.RDBMS - Column "WRITER.WRITERS_LIBRARY_ID_OID"
8493 [main] DEBUG JPOX.RDBMS - Column "WRITER.LIBRARY_WRITERS_IDX" added
8623 [main] DEBUG JPOX.RDBMS.SCHEMA - Column info loaded for Catalog
"mylibrary", Schema "", 0 tables, time = 0 ms
8623 [main] INFO JPOX.RDBMS.SCHEMA - No
Re: WrongPrimayKeyException and MissingColoumnExceptions while using elver with [message #50175 is a reply to message #50127] |
Thu, 14 September 2006 11:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Martin Taal![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mtaal%40springsite.com) Messages: 5468 Registered: July 2009 |
No, there is no other way (except doing it manually), the problem already occurs when jpox creates
the tables it needs itself (so not teneo/elver).
Creating the database should just work through jpox, the Teneo testcases create about 70 databases
with jpox in one run and this works fine.
A few remarks (in priority order):
Looking at the log it seems that you use a jdcb-odbc bridge driver:
Identifier Names : UPPERCASE Driver name=JDBC-ODBC Bridge (myodbc3.dll), version=2.0001 (03.51.11),
major=2, minor=1
If so can you try the latest official mysql jdbc driver from mysql.com?
Does the JPOX_TABLES table exist in the database?
Does the user you use to connect with the database have rights to create tables?
Can you try to work directly with the database (through a sql navigator or the mysql prompt) using
this same user and then create a table using the CREATE Table syntax found in the log, for example:
gr. Martin
> way around.
> protocol/extension
> FeatureMap
> updateschema: true
> classes for package library
> /org/package.jdo
> database schema
> Version: 1.1.0-rc-1
> userName=root
> schema=null
> dateTimezone=UTC
> mode=Quiet
> (org.elver.store.jpox.emf.cache.EMFWeakRefCache), Collections/Maps 1883
> [main] DEBUG JPOX.JDO - Queries : fetchSize=0, fetchDirection=forward,
> resultSetType=forward-only, resultSetConcurrency=read-only
> to be used in table definitions
> : MySQL version=5.0.18-nt, major=5, minor=0, revision=18
> version=2.0001 (03.51.11), major=2, minor=1
> Delimeters=`
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> recreating as new
> for Schema "". Either it doesnt exist, or doesnt validate
> `TABLE_NAME`
> "java.lang.Character" as not having MetaData.
> "[Ljava.lang.Float;" as not having MetaData.
> having MetaData.
> having MetaData.
> "java.util.SortedMap" as not having MetaData.
> "[Ljava.lang.String;" as not having MetaData.
> "[Ljava.lang.Number;" as not having MetaData.
> MetaData.
> "java.sql.Timestamp" as not having MetaData.
> having MetaData.
> "java.util.ArrayList" as not having MetaData.
> MetaData.
> "org.jpox.sco.Stack" as not having MetaData.
> "[Ljava.util.Locale;" as not having MetaData.
> "java.util.TimeZone" as not having MetaData.
> MetaData.
> having MetaData.
> MetaData.
> MetaData.
> MetaData.
> "[Ljava.lang.Double;" as not having MetaData.
> "org.jpox.store.OID" as not having MetaData.
> "java.util.Hashtable" as not having MetaData.
> MetaData.
> MetaData.
> having MetaData.
> having MetaData.
> "org.jpox.sco.Vector" as not having MetaData.
> having MetaData.
> "[Ljava.lang.Short;" as not having MetaData.
> MetaData.
> "java.util.Calendar" as not having MetaData.
> "java.util.SortedSet" as not having MetaData.
> "java.util.Currency" as not having MetaData.
> MetaData.
> MetaData.
> (stack size=2)
> (stack size=4"
> (stack size=4"
> (stack size=4"
> "inheritance (stack size=3) Attributes[strategy="new-table"]"
> (stack size=4"
> (stack size=3) Attributes[name="title"
> ,persistence-modifier="persistent" ,null-value="none"
> (stack size=5"
> size=4"
> (stack size=3) Attributes[name="pages"
> (stack size=5"
> size=4"
> (stack size=3) Attributes[name="category"
> ,persistence-modifier="persistent" ,null-value="none" ,embedded="true"
> (stack size=5"
> size=4"
> (stack size=3) Attributes[name="author"
> ,persistence-modifier="persistent" ,delete-action="restrict"
> "foreign-key (stack size=4) Attributes[delete-action="restrict"
> (stack size=6"
> (stack size=5"
> (stack size=4"
> size=4"
> size=3"
> (stack size=2)
> (stack size=4"
> (stack size=4"
> (stack size=4"
> (stack size=4"
> (stack size=3) Attributes[name="name" ,persistence-modifier="persistent"
> (stack size=5"
> size=4"
> (stack size=3) Attributes[name="writers"
> (stack size=4)
> ,value="true"]"
> (stack size=5"
> (stack size=5"
> (stack size=4) Attributes[column="LIBRARY_WRITERS_IDX"]"
> size=5"
> (stack size=5"
> "foreign-key (stack size=4) Attributes[delete-action="cascade"
> (stack size=5"
> size=4"
> (stack size=3) Attributes[name="books"
> (stack size=4)
> ,value="true"]"
> (stack size=5"
> (stack size=5"
> (stack size=4) Attributes[column="LIBRARY_BOOKS_IDX"]"
> size=5"
> (stack size=5"
> (stack size=5"
> size=4"
> size=3"
> (stack size=2)
> (stack size=4"
> (stack size=4"
> (stack size=4"
> (stack size=4"
> (stack size=5"
> size=4"
> ,persistence-modifier="persistent" ,mapped-by="author"
> (stack size=4)
> ,value="true"]"
> (stack size=5"
> (stack size=5"
> (stack size=4) Attributes[column="WRITER_BOOKS_IDX"]"
> size=5"
> (stack size=5"
> (stack size=5"
> size=4"
> size=3"
> (stack size=2"
> size=1"
> MetaData.
Re: WrongPrimayKeyException and MissingColoumnExceptions while using elver with [message #590944 is a reply to message #50077] |
Thu, 14 September 2006 10:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
way around.
protocol/extension
FeatureMap
updateschema: true
for package library
/org/package.jdo
database schema
Version: 1.1.0-rc-1
userName=root
schema=null
dateTimezone=UTC
mode=Quiet
major=2, minor=1
Delimeters=`
at
at
at
at
at
at
at
at
at
as new
`TABLE_NAME`
having MetaData.
MetaData.
having MetaData.
MetaData.
MetaData.
MetaData.
MetaData.
having MetaData.
MetaData.
having MetaData.
MetaData.
MetaData.
MetaData.
MetaData.
MetaData.
MetaData.
MetaData.
MetaData.
MetaData.
MetaData.
(stack size=4"
(stack size=4"
(stack size=4"
(stack size=4"
size=5"
size=4"
size=5"
size=4"
size=5"
size=4"
size=6"
(stack size=5"
(stack size=4"
size=4"
size=3"
(stack size=4"
(stack size=4"
(stack size=4"
(stack size=4"
size=5"
size=4"
(stack size=4)
,value="true"]"
(stack size=5"
(stack size=5"
size=5"
size=5"
(stack size=5"
size=4"
(stack size=4)
,value="true"]"
(stack size=5"
(stack size=5"
size=5"
size=5"
(stack size=5"
size=4"
size=3"
(stack size=4"
(stack size=4"
(stack size=4"
(stack size=4"
size=5"
size=4"
(stack size=4)
,value="true"]"
(stack size=5"
(stack size=5"
size=5"
size=5"
(stack size=5"
size=4"
size=3"
size=2"
size=1"
MetaData.
[LIBRARY.`NAME`]
[[none]]
of table.
[BOOK.CATEGORY]
[WRITER.`NAME`]
Re: WrongPrimayKeyException and MissingColoumnExceptions while using elver with [message #590963 is a reply to message #50127] |
Thu, 14 September 2006 11:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
major=2, minor=1
gr. Martin
> way around.
> protocol/extension
> FeatureMap
> updateschema: true
> /org/package.jdo
> database schema
> Version: 1.1.0-rc-1
> userName=root
> schema=null
> dateTimezone=UTC
> mode=Quiet
> Delimeters=`
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> recreating as new
> `TABLE_NAME`
> having MetaData.
> having MetaData.
> MetaData.
> having MetaData.
> MetaData.
> MetaData.
> having MetaData.
> MetaData.
> MetaData.
> MetaData.
> MetaData.
> MetaData.
> having MetaData.
> having MetaData.
> having MetaData.
> MetaData.
> MetaData.
> MetaData.
> (stack size=2)
> (stack size=4"
> (stack size=4"
> (stack size=4"
> (stack size=4"
> (stack size=5"
> size=4"
> (stack size=5"
> size=4"
> (stack size=5"
> size=4"
> (stack size=6"
> (stack size=5"
> (stack size=4"
> size=4"
> size=3"
> (stack size=2)
> (stack size=4"
> (stack size=4"
> (stack size=4"
> (stack size=4"
> (stack size=5"
> size=4"
> (stack size=4)
> ,value="true"]"
> (stack size=5"
> (stack size=5"
> size=5"
> (stack size=5"
> (stack size=5"
> size=4"
> (stack size=4)
> ,value="true"]"
> (stack size=5"
> (stack size=5"
> size=5"
> (stack size=5"
> (stack size=5"
> size=4"
> size=3"
> (stack size=2)
> (stack size=4"
> (stack size=4"
> (stack size=4"
> (stack size=4"
> (stack size=5"
> size=4"
> (stack size=4)
> ,value="true"]"
> (stack size=5"
> (stack size=5"
> size=5"
> (stack size=5"
> (stack size=5"
> size=4"
> size=3"
> (stack size=2"
> size=1"
> MetaData.
Current Time: Sun Sep 01 09:13:58 GMT 2024
Powered by FUDForum. Page generated in 0.05291 seconds
