Home » Eclipse Projects » Plugin Development Environment (PDE) » Exported RCP application no longer starts
Exported RCP application no longer starts [message #40479] |
Fri, 16 January 2009 15:34 |
Rich Scott Messages: 63 Registered: July 2009 |
Member |
I have an existing RCP application which in the past I have been able to
export both manually using the export wizard on the product editor and
using a headless buckminster export. I have not tried the export for a
while, and now the export completes, and the new directory appears to
contain all of the required plugins and features. However when I try to
run the application, the splash screen appears and then a error dialog.
The log file indicates a runtime error "No application id has been found"
with a lot of message like "Bundle update@plugins/org.test..........jar
was not resolved" (the full log is at the bottom of this post).
The product depends upon a single feature. That feature includes our
plugins and all the required eclipse plugins along with the
org.eclipse.rcp feature.
Any ideas as to the problem? I haven't been able to find the significance
of the "update@plugins" in each fo the detailed messages but it seems like
it might be significant.
I am running 3.4.1 Build M20080911-1700 with both the IDE and target
plaforms brought up to date on Jan 14, 2009.
The feature.xml used in the product that was exported is:
<feature
id="org.test.testproduct.feature"
label="Test Product"
version="0.0.14"
provider-name="testing"
plugin="org.test.testproduct">
<description>
The Chemistry Explorer feature is the basic framework for the CAS
Research Chemistry Explorer prototype. This prototype is for internal CAS
use only.
</description>
<copyright>
(c) 2008. All Rights Reserved.
</copyright>
<license>
%license
</license>
<url>
<update label="Update Site" url="http://test/repository"/>
</url>
<includes
id="org.eclipse.rcp"
version="0.0.0"/>
<requires>
<import plugin="org.eclipse.core.runtime"/>
<import plugin="org.test.rcp.logback" version="0.9.8"
match="greaterOrEqual"/>
<import plugin="org.test.util.graphics" version="0.0.1"
<import plugin="org.test.util.graphics.swt" version="1.0.0"
<import plugin="org.eclipse.core.runtime" version="3.4.0"
<import plugin="org.eclipse.ui" version="3.4.0"
<import plugin="com.thoughtworks.xstream" version="1.3.0"
<import plugin="net.miginfocom.miglayout" version="3.5.1"
<import plugin="org.jdom" version="1.1.0" match="greaterOrEqual"/>
<import plugin="org.eclipse.nebula.widgets.pshelf" version="1.0.0"
<import plugin="org.test.util.authhttptransport" version="1.0.0"
<import plugin="org.test.util.gen" version="1.0.0"
<import plugin="org.test.util.xml" version="1.0.0"
<import plugin="org.test.util.swt" version="0.0.1"
<import plugin="org.openscience.cdk" version="1.1.0"
<import plugin="org.test.structure" version="1.0.0"
<import plugin="org.eclipse.draw2d" version="3.4.0"
<import plugin="org.test.testproduct.core" version="0.0.1"
<import plugin="net.openastexviewer" version="3.0.0"
<import plugin="org.jmol" version="1.0.0" match="greaterOrEqual"/>
<import plugin="org.eclipse.swt"/>
<import plugin="org.eclipse.swt" version="3.4.0"
<import plugin="org.test.util.servlet" version="1.0.0"
<import plugin="org.test.util.dafretrieval" version="1.0.0"
<import plugin="org.eclipse.jface" version="3.4.0"
<import plugin="org.test.structure.display.swt" version="1.0.0"
<import plugin="org.eclipse.nebula.widgets.grid" version="1.0.0"
<import plugin="org.eclipse.nebula.jface.gridviewer" version="1.0.0"
<import plugin="org.apache.commons.httpclient"/>
<import plugin="org.eclipse.ui" version="3.4.1"
<import plugin="org.test.testproduct.storage.dbms" version="0.0.1"
<import plugin="com.mysql.connectorj" version="0.0.1"
<import plugin="org.eclipse.jface" version="3.4.1"
<import plugin="org.eclipse.equinox.common"/>
<import plugin="org.eclipse.equinox.registry"/>
<import plugin="org.eclipse.ecf"/>
<import plugin="org.eclipse.core.jobs"/>
<import plugin="org.eclipse.core.runtime" version="3.1.0"
match="compatible"/>
<import plugin="org.eclipse.core.expressions" version="3.3.0"
<import plugin="org.eclipse.swt" version="3.4.0" match="compatible"/>
<import plugin="org.eclipse.core.commands" version="3.4.0"
<import plugin="org.eclipse.equinox.common" version="3.2.0"
<import plugin="org.eclipse.core.databinding" version="1.0.0"
<import plugin="org.eclipse.swt" version="3.2.0" match="compatible"/>
<import plugin="org.eclipse.jface" version="3.2.0"
<import plugin="com.ibm.icu"/>
<import plugin="org.eclipse.help" version="3.2.0"
<import plugin="org.eclipse.swt" version="3.3.0" match="compatible"/>
<import plugin="org.eclipse.core.expressions" version="3.2.0"
<import plugin="org.eclipse.jface.databinding" version="1.1.0"
<import plugin="org.eclipse.osgi" version="3.2.0"
<import plugin="org.sat4j.core" version="2.0.0"
<import plugin="org.sat4j.pb" version="2.0.0"
<import plugin="org.eclipse.osgi" version="3.4.0"
<import plugin="org.eclipse.equinox.registry" version="3.4.0"
<import plugin="org.eclipse.equinox.preferences"/>
<import plugin="org.eclipse.ecf" version="1.2.0"
<import plugin="org.eclipse.ecf.filetransfer" version="2.0.0"
<import plugin="org.eclipse.core.jobs" version="3.2.0"
<import plugin="org.eclipse.equinox.app"/>
<import plugin="org.eclipse.equinox.common" version="3.4.0"
<import plugin="org.eclipse.equinox.simpleconfigurator"/>
<import plugin="org.eclipse.equinox.security.ui" version="1.0.0"
<import plugin="org.eclipse.equinox.common" version="3.3.0"
<import plugin="org.eclipse.equinox.security" version="1.0.0"
<import plugin="org.eclipse.equinox.preferences" version="3.2.200"
<import plugin="org.eclipse.core.runtime" version="3.2.0"
<import plugin="org.eclipse.ui.workbench" version="3.4.0"
<import plugin="org.eclipse.core.expressions" version="3.4.0"
</requires>
<plugin
id="org.test.rcp.logging"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.rcp.logback"
download-size="0"
install-size="0"
version="0.0.0"/>
<plugin
id="org.test.testproduct.help"
download-size="0"
install-size="0"
version="0.0.0"/>
<plugin
id="com.thoughtworks.xstream"
download-size="0"
install-size="0"
version="0.0.0"/>
<plugin
id="org.test.testproduct.core"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.jdom"
download-size="0"
install-size="0"
version="0.0.0"/>
<plugin
id="org.test.structure"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.structure.display.swt"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.util.gen"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.util.xml"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.openscience.cdk"
download-size="0"
install-size="0"
version="0.0.0"/>
<plugin
id="net.openastexviewer"
download-size="0"
install-size="0"
version="0.0.0"/>
<plugin
id="org.test.testproduct.openastexviewer"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.testproduct.jmolviewer"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.jmol"
download-size="0"
install-size="0"
version="0.0.0"/>
<plugin
id="org.test.testproduct"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="net.miginfocom.miglayout"
download-size="0"
install-size="0"
version="0.0.0"/>
<plugin
id="org.eclipse.nebula.widgets.pshelf"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.structure.dafretrieval"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.util.graphics"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.util.graphics.swt"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.testproduct.casprovider"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.testproduct.localprovider"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.util.authhttptransport"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.nebula.widgets.grid"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.nebula.jface.gridviewer"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.testproduct.storage.dbms"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.testproduct.storage.filesystem"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.testproduct.storage.mysql"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.util.swt"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.test.util.dafretrieval"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.ecf.filetransfer"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.ecf.provider.filetransfer"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.exemplarysetup"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.touchpoint.eclipse"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.touchpoint.natives"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.ui.sdk"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.osgi.services"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.ecf.identity"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.osgi"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.help"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.jface"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.jface.databinding"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.ui.workbench"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.update.configurator"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.draw2d"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.ui.forms"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.core"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.director"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.engine"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.garbagecollector"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.metadata"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.metadata.repository"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.frameworkadmin"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.artifact.repository"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.jarprocessor"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.metadata.generator"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.ui"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.p2.updatechecker"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.sat4j.core"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.sat4j.pb"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.simpleconfigurator.manipulator"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.frameworkadmin.equinox"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.equinox.launcher"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.core.net"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.eclipse.ui"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
<plugin
id="org.apache.derby.core"
download-size="0"
install-size="0"
version="0.0.0"/>
<plugin
id="org.eclipse.equinox.security"
download-size="0"
install-size="0"
version="0.0.0"
unpack="false"/>
</feature>
The log file created when the application is started is:
!SESSION 2009-01-16 10:12:35.242
eclipse.buildId=unknown
java.version=1.6.0_06
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.update.configurator 4 0 2009-01-16 10:12:36.039
!MESSAGE
D:\eclipse.build\testProduct\configuration\org.eclipse.updat e\last.config.stamp
(Access is denied)
!ENTRY org.eclipse.equinox.app 0 0 2009-01-16 10:12:36.180
!MESSAGE Product org.test.testproduct.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2009-01-16 10:12:36.211
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
at
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
!ENTRY org.eclipse.osgi 2 0 2009-01-16 10:12:36.242
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-01-16 10:12:36.242
!MESSAGE Bundle update@plugins/org.test.testproduct.storage.dbms_0.0.1.jar
was not resolved.
!SUBENTRY 2 org.test.testproduct.storage.dbms 2 0 2009-01-16 10:12:36.242
!MESSAGE Missing required bundle org.test.util.gen_1.0.0.
!MESSAGE Bundle update@plugins/org.test.structure_1.0.0.jar was not
resolved.
!SUBENTRY 2 org.test.structure 2 0 2009-01-16 10:12:36.242
!MESSAGE Missing required bundle org.test.util.xml_1.0.0.
!MESSAGE Bundle
update@plugins/org.test.testproduct.storage.filesystem_0.0.1.jar was not
resolved.
!SUBENTRY 2 org.test.testproduct.storage.filesystem 2 0 2009-01-16
10:12:36.242
!MESSAGE Bundle
update@plugins/org.eclipse.equinox.p2.ui_1.0.1.R34x_v20080909.jar was not
resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.ui 2 0 2009-01-16 10:12:36.242
org.eclipse.equinox.security.ui_[1.0.0,2.0.0).
!MESSAGE Bundle update@plugins/org.test.util.graphics.swt_1.0.0.jar was
not resolved.
!SUBENTRY 2 org.test.util.graphics.swt 2 0 2009-01-16 10:12:36.242
!MESSAGE Bundle update@plugins/org.test.testproduct.casprovider_0.0.1.jar
was not resolved.
!SUBENTRY 2 org.test.testproduct.casprovider 2 0 2009-01-16 10:12:36.242
!MESSAGE Bundle update@plugins/org.test.util.graphics_0.0.1.jar was not
resolved.
!SUBENTRY 2 org.test.util.graphics 2 0 2009-01-16 10:12:36.242
!MESSAGE Bundle update@plugins/org.test.testproduct.core_0.0.1.jar was not
resolved.
!SUBENTRY 2 org.test.testproduct.core 2 0 2009-01-16 10:12:36.242
!MESSAGE Bundle
update@plugins/org.test.testproduct.storage.mysql_0.0.1.jar was not
resolved.
!SUBENTRY 2 org.test.testproduct.storage.mysql 2 0 2009-01-16 10:12:36.242
!MESSAGE Missing required bundle com.mysql.connectorj_0.0.1.
!MESSAGE Bundle
update@plugins /org.eclipse.ecf.provider.filetransfer_2.0.0.v20080611-1715. jar
was not resolved.
!SUBENTRY 2 org.eclipse.ecf.provider.filetransfer 2 0 2009-01-16
10:12:36.242
!MESSAGE Missing required bundle org.eclipse.ecf_0.0.0.
!MESSAGE Bundle
update@plugins /org.eclipse.equinox.p2.metadata.repository_1.0.0.v20080604. jar
was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.metadata.repository 2 0 2009-01-16
10:12:36.242
!MESSAGE Missing required bundle org.eclipse.ecf_1.2.0.
!MESSAGE Bundle update@plugins/org.test.util.dafretrieval_1.0.0.jar was
not resolved.
!SUBENTRY 2 org.test.util.dafretrieval 2 0 2009-01-16 10:12:36.242
!MESSAGE Missing imported package org.test.util.gen_0.0.0.
!MESSAGE Missing imported package org.test.util.servlet_0.0.0.
!MESSAGE Missing imported package org.test.util.xml_0.0.0.
!MESSAGE Bundle
update@plugins /org.eclipse.equinox.p2.artifact.repository_1.0.2.R34x_v2008 0808-1156.jar
was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.artifact.repository 2 0 2009-01-16
10:12:36.242
!MESSAGE Bundle update@plugins/org.test.structure.display.swt_1.0.0.jar
was not resolved.
!SUBENTRY 2 org.test.structure.display.swt 2 0 2009-01-16 10:12:36.242
!MESSAGE Bundle
update@plugins/org.eclipse.ecf.filetransfer_2.0.0.v20080611-1715.jar was
not resolved.
!SUBENTRY 2 org.eclipse.ecf.filetransfer 2 0 2009-01-16 10:12:36.242
!MESSAGE Bundle update@plugins/org.test.util.authhttptransport_1.0.0.jar
was not resolved.
!SUBENTRY 2 org.test.util.authhttptransport 2 0 2009-01-16 10:12:36.242
!MESSAGE Missing required bundle org.apache.commons.httpclient_0.0.0.
!MESSAGE Bundle update@plugins/org.test.structure.dafretrieval_1.0.0.jar
was not resolved.
!SUBENTRY 2 org.test.structure.dafretrieval 2 0 2009-01-16 10:12:36.242
!MESSAGE Missing required bundle org.test.util.servlet_1.0.0.
!ENTRY org.eclipse.osgi 2 0 2009-01-16 10:12:36.274
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-01-16 10:12:36.274
[9] was not resolved.
!SUBENTRY 2 org.test.testproduct.casprovider 2 0 2009-01-16 10:12:36.274
!MESSAGE Missing required bundle org.test.testproduct.core_0.0.1.
!MESSAGE Missing required bundle org.test.structure_1.0.0.
!MESSAGE Missing required bundle org.test.structure.display.swt_1.0.0.
!MESSAGE Missing required bundle org.test.util.graphics_0.0.1.
!MESSAGE Missing required bundle org.test.util.graphics.swt_1.0.0.
!MESSAGE Missing required bundle org.test.util.authhttptransport_1.0.0.
!MESSAGE Bundle update@plugins/org.test.testproduct.core_0.0.1.jar [10]
was not resolved.
!SUBENTRY 2 org.test.testproduct.core 2 0 2009-01-16 10:12:36.274
!MESSAGE Bundle update@plugins/org.test.testproduct.jmolviewer_0.0.1.jar
[12] was not resolved.
!SUBENTRY 2 org.test.testproduct.jmolviewer 2 0 2009-01-16 10:12:36.274
!MESSAGE Bundle
update@plugins/org.test.testproduct.localprovider_0.0.1.jar [13] was not
resolved.
!SUBENTRY 2 org.test.testproduct.localprovider 2 0 2009-01-16 10:12:36.274
!MESSAGE Bundle
update@plugins/org.test.testproduct.openastexviewer_0.0.1.jar [14] was not
resolved.
!SUBENTRY 2 org.test.testproduct.openastexviewer 2 0 2009-01-16
10:12:36.274
[15] was not resolved.
!SUBENTRY 2 org.test.testproduct.storage.dbms 2 0 2009-01-16 10:12:36.274
!MESSAGE Bundle
update@plugins/org.test.testproduct.storage.filesystem_0.0.1.jar [16] was
not resolved.
10:12:36.274
10:12:36.274
!MESSAGE Bundle
update@plugins/org.test.testproduct.storage.mysql_0.0.1.jar [17] was not
resolved.
!SUBENTRY 2 org.test.testproduct.storage.mysql 2 0 2009-01-16 10:12:36.274
!MESSAGE Missing required bundle org.test.testproduct.storage.dbms_0.0.1.
!MESSAGE Bundle update@plugins/org.test.testproduct_0.0.13.jar [18] was
not resolved.
!SUBENTRY 2 org.test.testproduct 2 0 2009-01-16 10:12:36.274
[21] was not resolved.
!SUBENTRY 2 org.test.structure.dafretrieval 2 0 2009-01-16 10:12:36.274
!MESSAGE Missing required bundle org.test.util.dafretrieval_1.0.0.
[22] was not resolved.
!SUBENTRY 2 org.test.structure.display.swt 2 0 2009-01-16 10:12:36.274
!MESSAGE Bundle update@plugins/org.test.structure_1.0.0.jar [23] was not
resolved.
!SUBENTRY 2 org.test.structure 2 0 2009-01-16 10:12:36.274
[24] was not resolved.
!SUBENTRY 2 org.test.util.authhttptransport 2 0 2009-01-16 10:12:36.274
!MESSAGE Bundle update@plugins/org.test.util.dafretrieval_1.0.0.jar [25]
was not resolved.
!SUBENTRY 2 org.test.util.dafretrieval 2 0 2009-01-16 10:12:36.274
!MESSAGE Missing imported package org.test.structure_0.0.0.
!MESSAGE Bundle update@plugins/org.test.util.graphics.swt_1.0.0.jar [26]
was not resolved.
!SUBENTRY 2 org.test.util.graphics.swt 2 0 2009-01-16 10:12:36.274
!MESSAGE Bundle update@plugins/org.test.util.graphics_0.0.1.jar [27] was
not resolved.
!SUBENTRY 2 org.test.util.graphics 2 0 2009-01-16 10:12:36.274
!MESSAGE Bundle
update@plugins/org.eclipse.ecf.filetransfer_2.0.0.v20080611-1715.jar [39]
was not resolved.
!SUBENTRY 2 org.eclipse.ecf.filetransfer 2 0 2009-01-16 10:12:36.274
!MESSAGE Bundle
[41] was not resolved.
10:12:36.274
10:12:36.274
!MESSAGE Missing required bundle org.eclipse.ecf.filetransfer_0.0.0.
!MESSAGE Bundle
[48] was not resolved.
10:12:36.274
10:12:36.274
!MESSAGE Bundle
update@plugins/org.eclipse.equinox.p2.director_1.0.2.v20080806-1619.jar
[50] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.director 2 0 2009-01-16 10:12:36.274
org.eclipse.equinox.internal.provisional.p2.engine_0.0.0.
org.eclipse.equinox.internal.provisional.p2.metadata.reposit ory_0.0.0.
org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository_0.0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.equinox.p2.engine_1.0.1.R34x_v20080827.jar [51]
was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-01-16 10:12:36.274
org.eclipse.equinox.internal.p2.metadata.repository_0.0.0.
org.eclipse.equinox.internal.p2.metadata.repository.io_0.0.0 .
org.eclipse.equinox.internal.provisional.p2.artifact.reposit ory_0.0.0.
!MESSAGE Bundle
update@plugins /org.eclipse.equinox.p2.exemplarysetup_1.0.0.v20080427-2136. jar
[52] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.exemplarysetup 2 0 2009-01-16
10:12:36.274
org.eclipse.equinox.internal.p2.director_0.0.0.
10:12:36.274
org.eclipse.equinox.internal.p2.engine_0.0.0.
10:12:36.274
org.eclipse.equinox.internal.p2.garbagecollector_0.0.0.
10:12:36.274
10:12:36.274
org.eclipse.equinox.internal.provisional.p2.director_0.0.0.
10:12:36.274
10:12:36.274
!MESSAGE Bundle
update@plugins /org.eclipse.equinox.p2.garbagecollector_1.0.1.R34x_v2008081 8.jar
[53] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.garbagecollector 2 0 2009-01-16
10:12:36.274
!MESSAGE Missing required bundle org.eclipse.equinox.p2.engine_0.0.0.
10:12:36.274
10:12:36.274
!MESSAGE Bundle
update@plugins /org.eclipse.equinox.p2.metadata.generator_1.0.1.R34x_v20080 819.jar
[55] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.metadata.generator 2 0 2009-01-16
10:12:36.274
org.eclipse.equinox.internal.p2.artifact.repository_0.0.0.
10:12:36.274
10:12:36.274
10:12:36.274
org.eclipse.equinox.internal.provisional.p2.artifact.reposit ory.processing_0.0.0.
10:12:36.274
!MESSAGE Bundle
[56] was not resolved.
10:12:36.274
10:12:36.274
!MESSAGE Missing required bundle org.eclipse.ecf.filetransfer_2.0.0.
!MESSAGE Bundle
update@plugins /org.eclipse.equinox.p2.touchpoint.eclipse_1.0.2.R34x_v20080 910.jar
[58] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.touchpoint.eclipse 2 0 2009-01-16
10:12:36.274
10:12:36.274
10:12:36.274
10:12:36.274
10:12:36.274
org.eclipse.equinox.internal.provisional.p2.metadata.generat or_0.0.0.
10:12:36.274
org.eclipse.equinox.internal.provisional.spi.p2.artifact.rep ository_0.0.0.
!MESSAGE Bundle
update@plugins /org.eclipse.equinox.p2.touchpoint.natives_1.0.0.v20080505-1 850.jar
[59] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.touchpoint.natives 2 0 2009-01-16
10:12:36.274
10:12:36.274
10:12:36.274
!MESSAGE Bundle
update@plugins/org.eclipse.equinox.p2.ui.sdk_1.0.1.R34x_v20080818.jar [60]
was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.ui.sdk 2 0 2009-01-16 10:12:36.274
org.eclipse.equinox.internal.provisional.p2.ui_0.0.0.
org.eclipse.equinox.internal.provisional.p2.ui.actions_0.0.0 .
org.eclipse.equinox.internal.provisional.p2.ui.dialogs_0.0.0 .
org.eclipse.equinox.internal.provisional.p2.ui.model_0.0.0.
org.eclipse.equinox.internal.provisional.p2.ui.operations_0. 0.0.
org.eclipse.equinox.internal.provisional.p2.ui.policy_0.0.0.
org.eclipse.equinox.internal.provisional.p2.ui.query_0.0.0.
org.eclipse.equinox.internal.provisional.p2.ui.viewers_0.0.0 .
org.eclipse.equinox.internal.provisional.p2.updatechecker_0. 0.0.
!MESSAGE Bundle
update@plugins/org.eclipse.equinox.p2.ui_1.0.1.R34x_v20080909.jar [61] was
not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.ui 2 0 2009-01-16 10:12:36.274
org.eclipse.equinox.internal.p2.rollback_0.0.0.
Re: Exported RCP application no longer starts [message #41152 is a reply to message #41121] |
Tue, 20 January 2009 14:37 |
Member |
I have uncovered some strangness, based upon the suggestions that Lars
made.
The jars for 2 of my included plugins where exported with simple
manifest.mf files instead of the complete version present in the project.
These are both simple plugins which contain a META-INF/manifest.mf file
instead of a plugin.xml. In both cases that I found, the exported jar
contains only the following 2 lines:
Manifest-Version: 1.0
Class-Path:
However, the manifest.mf file within the project contain complete plugin
information. The first of these in the project is
manifest.mf:
Bundle-ManifestVersion: 2
Bundle-Name: Utilities - Gen Plug-in
Bundle-SymbolicName: org.test.util.gen
Bundle-Version: 1.0.0
Bundle-Vendor: test
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Export-Package: org.test.util.gen,
org.test.util.gen.cmds,
org.test.util.gen.debugaids,
org.test.util.gen.fileutil,
org.test.util.gen.html,
org.test.gen.sm
Require-Bundle: org.test.rcp.logback;bundle-version="[0.9.8,1.0.0]"
The plugin projects both have the META-INF directory and manifest.mf files
selected for export in the build.properties file.
Does it seem reasonable that the missing info in the manifest would cause
the plugins not to be found as application start time? If so, any ideas
why the information is being lost on export, when other similar projects
are exported fine?
Thanks for any insight.
Rich
Rich Scott wrote:
> Lars,
> Thanks for the suggestions. I double checked and the "testProduct.product"
> file is selected for export in the build.xml as are the plugin.xml files
> for all of our plugins that are included in the product.Just to be clear,
> The .product file is located in a project which includes the feature.xml
> that defines the plugins required for the product. Each of the plugins is
> a separate eclipse project. The feature project selects the .product and
> feature.xml for export and each of the plugin projects selects either the
> plugin.xml or manifest.mf (if not plugin.xml).
> Any further thoughts?
> Thanks
> Rich
> Lars Vogel wrote:
>> Hi,
>> I believe you may not include the .product and / or the plugin.xml in
>> the export. Please check the build tab of your plugin if these files are
>> included.
>> Best regards, Lars
Re: Exported RCP application no longer starts [message #41215 is a reply to message #41152] |
Tue, 20 January 2009 18:06 |
Andrew Niefer Messages: 990 Registered: July 2009 |
Yes, the missing info in the manifest would definitely cause the bundle
to not be found at runtime.
The only problem I know of is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=260634. The cause is
having a second manifest in your java source folder, and it is this
manifest that ends up in the exported jar.
-Andrew
> made.
> project. These are both simple plugins which contain a
> META-INF/manifest.mf file instead of a plugin.xml. In both cases that I
> found, the exported jar contains only the following 2 lines:
> Class-Path:
> manifest.mf:
> Bundle-Vendor: test
> org.test.gen.sm
> files selected for export in the build.properties file.
> cause the plugins not to be found as application start time? If so, any
> ideas why the information is being lost on export, when other similar
> projects are exported fine?
> Rich
> Rich Scott wrote:
>> Lars,
>> "testProduct.product" file is selected for export in the build.xml as
>> are the plugin.xml files for all of our plugins that are included in
>> the product.Just to be clear, The .product file is located in a
>> project which includes the feature.xml that defines the plugins
>> required for the product. Each of the plugins is a separate eclipse
>> project. The feature project selects the .product and feature.xml for
>> export and each of the plugin projects selects either the plugin.xml
>> Thanks
>> Rich
>> Lars Vogel wrote:
>>> Hi,
>>> are included.
>>> Best regards, Lars
Re: Exported RCP application no longer starts [message #41245 is a reply to message #41215] |
Tue, 20 January 2009 18:51 |
Member |
Andrew,
That turns out to be exactly the problem. Both plugins had a META-INF
directory and manifest.mf in the source tree. Removing it fixed may
problems and everything is working.
Thanks for your help.
Rich
> -Andrew
>> made.
>> Class-Path:
>> manifest.mf:
>> Bundle-Vendor: test
>> org.test.gen.sm
>> Rich
>> Rich Scott wrote:
>>> Lars,
>>> Thanks
>>> Rich
>>> Lars Vogel wrote:
>>>> Hi,
>>>> are included.
>>>> Best regards, Lars
Re: Exported RCP application no longer starts [message #588480 is a reply to message #41121] |
Member |
made.
Class-Path:
manifest.mf:
Bundle-Vendor: test
org.test.gen.sm
are exported fine?
Rich
Rich Scott wrote:
> Lars,
> Thanks
> Rich
> Lars Vogel wrote:
>> Hi,
>> included.
>> Best regards, Lars
Re: Exported RCP application no longer starts [message #588499 is a reply to message #41152] |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=260634 The cause is
-Andrew
> made.
> Class-Path:
> manifest.mf:
> Bundle-Vendor: test
> org.test.gen.sm
> Rich
> Rich Scott wrote:
>> Lars,
>> Thanks
>> Rich
>> Lars Vogel wrote:
>>> Hi,
>>> are included.
>>> Best regards, Lars
Re: Exported RCP application no longer starts [message #588507 is a reply to message #41215] |
Member |
Andrew,
Rich
> -Andrew
>> made.
>> Class-Path:
>> manifest.mf:
>> Bundle-Vendor: test
>> org.test.gen.sm
>> Rich
>> Rich Scott wrote:
>>> Lars,
>>> Thanks
>>> Rich
>>> Lars Vogel wrote:
>>>> Hi,
>>>> are included.
>>>> Best regards, Lars
Current Time: Sat Oct 19 13:45:46 GMT 2024
Powered by FUDForum. Page generated in 0.04493 seconds
