Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Library EXT Example (Live Validation)
Library EXT Example (Live Validation) [message #639] |
Wed, 02 November 2005 20:34 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: zx.us.ibm.com
How does live validation work with the example?
I enable it, and I'm assuming it should check whether the library has a
name set or not (it doesn't). No error comes up... I'm assuming when I
add a new book, an error should come up too addressing the no title issue.
Am I read live validation wrong?
~ Chris
Re: Library EXT Example (Live Validation) [message #654 is a reply to message #639] |
Thu, 03 November 2005 15:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Chris McGee![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=cbmcgee%40ca.ibm.com) Messages: 99 Registered: July 2009 |
Member |
Hi Chris,
To demonstrate live validation in the example, you first enable it on
the resource right-click->Validation->Enable Live Validation. To trigger
the element should have a name constraint, you take any library, writer
or book and create a change that would make the name empty or null when
it was not empty or null. This may involve given the element a name in
the properties view and then making the name empty.
The reason that live validation is not triggered when a new book is
added is that the title feature is never changed. I did not augment this
constraint to be triggered on the adding of new books and writers
because every time a new library element is added in the EMF generated
reflective editor, the name is empty and a validation error would be
produced. This could be quite annoying. :-)
Ideally, an application using the EXT library metamodel with this
constraint would implement some semantic procedures or specialized
commands that would provide a default name to each new library, writer
and book.
I hope this helps,
Chris McGee
> Cheers,
> ~ Chris
Re: Library EXT Example (Live Validation) [message #32018 is a reply to message #654] |
Wed, 19 April 2006 09:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: binhduong.cybersoft-vn.com
Hi Chris,
I have tried to enable the Live validation function and I got the
message "The chosen operation is not enabled.". After that the "Enable
Live Validation" menu item is disable.
I have tried the Batch validation function but I always get the
"Validation passed" message instead an error message as I expected
(Library's name must not empty).
Now I'm trying the "emft-validation-examples-1.0.0M6a.zip" package. Is
there any wrong with this example?
Binh
Chris McGee wrote:
> Hi Chris,
> and book.
> I hope this helps,
> Chris McGee
>> a name set or not (it doesn't). No error comes up... I'm assuming when
>> I add a new book, an error should come up too addressing the no title
>> issue.
>> Cheers,
>> ~ Chris
Re: Library EXT Example (Live Validation) [message #37797 is a reply to message #32018] |
Mon, 19 June 2006 01:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
A. Jibran Shidqie![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ajibrans%40yahoo.com) Messages: 26 Registered: July 2009 |
Hi Chris,
I've got the same problem like Binh, the Enable Live Validation menu item is
disable.
I've take a look into the code, and I found this code in the
selectionChanged method of EnableLiveValidationDelegate Class.
for (Iterator i = selectedEObjects.iterator(); i.hasNext();) {
Object o = i.next();
if (!(o instanceof Resource)) {
action.setEnabled(false);
} else if (resourceHasAdapter((Resource)o)) {
When the debugging process is running, I found that, the object inside the
selectedEObjects is not instanceOf Resource. Everytime the pop up menu of
the model is activated, this method will be invoked. Since the o is not
instanceof Resource, the action, the "Enable Live Validation" menu, always
disable.
Currently, I can run the batch validation of the example given, while live
validation mode can't.
Thank you
Jibran
"Binh DUONG" <binhduong@cybersoft-vn.com> wrote in message
news:e25031$lap$1@utils.eclipse.org...
> Hi Chris,
> I have tried to enable the Live validation function and I got the message
> "The chosen operation is not enabled.". After that the "Enable Live
> Cheers,
> Binh
> Chris McGee wrote:
>> Hi Chris,
>> To demonstrate live validation in the example, you first enable it on the
>> resource right-click->Validation->Enable Live Validation. To trigger the
>> element should have a name constraint, you take any library, writer or
>> book and create a change that would make the name empty or null when it
>> was not empty or null. This may involve given the element a name in the
>> The reason that live validation is not triggered when a new book is added
>> constraint to be triggered on the adding of new books and writers because
>> every time a new library element is added in the EMF generated reflective
>> editor, the name is empty and a validation error would be produced. This
>> and book.
>> I hope this helps,
>> Chris McGee
>>> issue.
>>> Cheers,
>>> ~ Chris
Re: Library EXT Example (Live Validation) [message #37864 is a reply to message #37797] |
Mon, 19 June 2006 15:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Vishy Ramaswamy![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=vramaswa%40ca.ibm.com) Messages: 30 Registered: July 2009 |
Member |
Hi Jibran,
The "Enable Live Validation" is currently enabled for toggling its state
only when the selection in the editor is the resource (the root of the
tree).
Select the root and then use the context menu to diable or enable live
validation.
Vishy
"A. Jibran Shidqie" <ajibrans@yahoo.com> wrote in message
news:e74uvl$akh$1@utils.eclipse.org...
> Hi Chris,
is
> disable.
> disable.
> Thank you
> Jibran
> > Hi Chris,
message
> > Cheers,
> > Binh
> > Chris McGee wrote:
> >> Hi Chris,
the
the
added
because
reflective
This
> >> and book.
> >> I hope this helps,
> >> Chris McGee
a
> >>> issue.
> >>> Cheers,
> >>> ~ Chris
Re: Library EXT Example (Live Validation) [message #38261 is a reply to message #37864] |
Wed, 21 June 2006 01:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Vishy,
You are correct. It's work now :)
Thank you very much.
Jibran
"Vishy Ramaswamy" <vramaswa@ca.ibm.com> wrote in message
news:e76hlp$pcv$1@utils.eclipse.org...
> Hi Jibran,
> tree).
> validation.
> Thanks
> Vishy
>> Hi Chris,
> is
>> disable.
>> the
>> always
>> disable.
>> live
>> Thank you
>> Jibran
>> > Hi Chris,
> message
>> > Cheers,
>> > Binh
>> > Chris McGee wrote:
>> >> Hi Chris,
> the
> the
>> >> it
>> >> the
> added
> because
> reflective
> This
>> >> and book.
>> >> I hope this helps,
>> >> Chris McGee
> a
>> >>> I
>> >>> issue.
>> >>> Cheers,
>> >>> ~ Chris
Re: Library EXT Example (Live Validation) [message #561046 is a reply to message #639] |
Thu, 03 November 2005 15:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
Hi Chris,
and book.
I hope this helps,
Chris McGee
> Cheers,
> ~ Chris
Re: Library EXT Example (Live Validation) [message #575456 is a reply to message #654] |
Wed, 19 April 2006 09:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Chris,
Binh
Chris McGee wrote:
> Hi Chris,
> and book.
> I hope this helps,
> Chris McGee
>> issue.
>> Cheers,
>> ~ Chris
Re: Library EXT Example (Live Validation) [message #580948 is a reply to message #32018] |
Mon, 19 June 2006 01:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Chris,
disable.
disable.
Thank you
Jibran
> Hi Chris,
> Cheers,
> Binh
> Chris McGee wrote:
>> Hi Chris,
>> and book.
>> I hope this helps,
>> Chris McGee
>>> issue.
>>> Cheers,
>>> ~ Chris
Re: Library EXT Example (Live Validation) [message #581000 is a reply to message #37797] |
Mon, 19 June 2006 15:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
Hi Jibran,
tree).
validation.
Vishy
> Hi Chris,
is
> disable.
> disable.
> Thank you
> Jibran
> > Hi Chris,
message
> > Cheers,
> > Binh
> > Chris McGee wrote:
> >> Hi Chris,
the
the
added
because
reflective
This
> >> and book.
> >> I hope this helps,
> >> Chris McGee
a
> >>> issue.
> >>> Cheers,
> >>> ~ Chris
Re: Library EXT Example (Live Validation) [message #581313 is a reply to message #37864] |
Hi Vishy,
Jibran
> Hi Jibran,
> tree).
> validation.
> Thanks
> Vishy
>> Hi Chris,
> is
>> disable.
>> the
>> always
>> disable.
>> live
>> Thank you
>> Jibran
>> > Hi Chris,
> message
>> > Cheers,
>> > Binh
>> > Chris McGee wrote:
>> >> Hi Chris,
> the
> the
>> >> it
>> >> the
> added
> because
> reflective
> This
>> >> and book.
>> >> I hope this helps,
>> >> Chris McGee
> a
>> >>> I
>> >>> issue.
>> >>> Cheers,
>> >>> ~ Chris
Current Time: Sat Jul 13 16:35:45 GMT 2024
Powered by FUDForum. Page generated in 0.05209 seconds
