Re: modifying client-side udc UI [message #481930 is a reply to message #481919] |
Mon, 24 August 2009 18:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Wayne Beaton![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=wayne.beaton%40eclipse-foundation.org) Messages: 554 Registered: December 2017 |
There is no support for overriding user acceptance of the terms of use.
This was an explicit design decision. So, the first -D parameter does
what you expect; the second parameter has no effect.
I recommend that you open a bug if you want to discuss the issue.
As part of the Helios release, we really want to refactor the code base
to make reuse of parts easier. There is also some effort underway to
merge the Mylyn Monitor code with the UDC. Your input into this effort
will be greatly appreciated.
Wayne
Frank Kurzawa wrote:
> We want to deploy udc capability into an internal rcp app. Since the
> application is for internal use only, there is no need to include the
> Terms of Use splash page, and we also want to remove the splash in which
> users choose to upload now, or later or not at all, etc.
> In our application's .ini file I have included the following entries to
> be passed as jvm args:
> -Dorg.eclipse.epp.usagedata.recording.ask=false
> -Dorg.eclipse.epp.usagedata.gathering.terms_accepted=true
> AFAICS, these two settings should result in avoiding both the Terms of
> Use and Whether To Upload splash pages, but they don't seem to have any
> effect at all.
> Is there some other setting that I haven't been able to discern yet?
> Thanks in advance,
> Frank
Re: modifying client-side udc UI [message #481951 is a reply to message #481930] |
Mon, 24 August 2009 19:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Frank Kurzawa![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=frank.kurzawa%40amd.com) Messages: 7 Registered: July 2009 |
Ouch.
It seems that even if a user of this UDC wanted to include a EULA in there
product, they would still have to replace
org.eclipse.epp.usagedata.gathering: There's no provision to substitute a
different EULA that doesn't refer to the eclipse foundation and the
specific ways that they will or will not use the information.
I'll open a bug.
Thanks Wayne,
Frank
> Wayne
>> effect at all.
>> Thanks in advance,
>> Frank
Re: modifying client-side udc UI [message #579652 is a reply to message #481919] |
Mon, 24 August 2009 18:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Wayne
> effect at all.
> Thanks in advance,
> Frank
Re: modifying client-side udc UI [message #579669 is a reply to message #481930] |
Ouch.
I'll open a bug.
Thanks Wayne,
Frank
> Wayne
>> effect at all.
>> Thanks in advance,
>> Frank
FUDForum. Page generated in 0.04198 seconds
