Home » Archived » XML Schema Definition (XSD) » Ecore XML schema mapping
Ecore XML schema mapping [message #57448] |
Fri, 11 February 2005 11:10 |
Originally posted by: r.schlesener.gmx.net
Hy, just a short question I can't find in the docs.
Where is the mapping between Ecore models and XML schema done?
How could I map attributes in Ecore on XML Elements in place of XML
Attributes?
Re: Ecore XML schema mapping [message #57473 is a reply to message #57448] |
Fri, 11 February 2005 11:57 |
--------------040803040404020304060801
Ralf,
I assume you found this document:
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/overviews/XMLSchemaToEcoreMapping.pdf
The same EAnnotations that are used when mapping XSD to Ecore (which is
done by org.eclipse.xsd.ecore.XSDEcoreBuilder in the org.eclipse.xsd
plugins) can be used to mark up any Ecore model to direct how its
instances will be serialized as XML (by the reflective
serialization/deserialization code in org.eclipse.emf.ecore.xmi).
> Attributes?
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Ralf,<br>
<br>
I assume you found this document:<br>
<blockquote><a
href=" http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/overviews/XMLSchemaToEcoreMapping.pdf"> http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/overviews/XMLSchemaToEcoreMapping.pdf</a><br>
</blockquote>
serialization/deserialization code in org.eclipse.emf.ecore.xmi).<br>
<br>
<br>
<blockquote cite="midcui3qs$cq8$1@www.eclipse.org" type="cite">Hy, just
<br>
<br>
<br>
<br>
Attributes? <br>
</blockquote>
<br>
</body>
</html>
--------------040803040404020304060801--
Re: Ecore XML schema mapping [message #57498 is a reply to message #57473] |
Fri, 11 February 2005 12:48 |
Ed,
does that mean I need to add the EAnnotations to a specific Ecore model?
I would like to change the general mapping for any model.
What is the XMI.xsd file, that is generated in the workspace by Eclipse
used for?
Ed Merks wrote:
> Ralf,
>> Attributes?
Re: Ecore XML schema mapping [message #57524 is a reply to message #57498] |
Fri, 11 February 2005 13:30 |
--------------090009060202060905000306
Ralf,
Yes, to specialize the serialization and deserialization of instances
you either need to mark up the model to direct the code in
org.eclipse.emf.ecore.xmi to behave differently or you need to
specialize the code to behave differently, in general.
The generated XMI.xsd and all the generated .xsd files for that matter,
are not used for anything. They are generated for you to use directly
for whatever purpose requires a schema that *approximates *the grammar
for instances.
> Ed,
> Eclipse used for?
> Ed Merks wrote:
>> Ralf,
>> is done by org.eclipse.xsd.ecore.XSDEcoreBuilder in the
>> org.eclipse.xsd plugins) can be used to mark up any Ecore model to
>> direct how its instances will be serialized as XML (by the reflective
>>> Attributes?
<html>
<head>
</head>
Ralf,<br>
<br>
specialize the code to behave differently, in general.<br>
<br>
Re: Ecore XML schema mapping [message #57548 is a reply to message #57524] |
Fri, 11 February 2005 14:17 |
Ed,
reading the javadoc it looks like I need to change getXMLRepresentation()
in XMLInfoImpl, to map Ecore attributes to XML elements. Is that the right
spot?
Ed Merks wrote:
> Ralf,
> for instances.
>> Ed,
>> Eclipse used for?
>> Ed Merks wrote:
>>> Ralf,
>>>> Attributes?
Re: Ecore XML schema mapping [message #57572 is a reply to message #57548] |
Fri, 11 February 2005 14:41 |
Ralf,
Yes.
> Ed,
> getXMLRepresentation() in XMLInfoImpl, to map Ecore attributes to XML
> elements. Is that the right spot?
> Ed Merks wrote:
>> Ralf,
>> matter, are not used for anything. They are generated for you to
>> use directly for whatever purpose requires a schema that
>> *approximates *the grammar for instances.
>>> Ed,
>>> model?
>>> Eclipse used for?
>>> Ed Merks wrote:
>>>> Ralf,
>>>> (which is done by org.eclipse.xsd.ecore.XSDEcoreBuilder in the
>>>> reflective serialization/deserialization code in
>>>>> XML Attributes?
Re: Ecore XML schema mapping [message #57595 is a reply to message #57572] |
Fri, 11 February 2005 15:03 |
Ed,
thanks for your help, I will try that.
Ralf
Ed Merks wrote:
> Ralf,
> Yes.
>> Ed,
>> Ed Merks wrote:
>>> Ralf,
>>>> Ed,
>>>> model?
>>>> Eclipse used for?
>>>> Ed Merks wrote:
>>>>> Ralf,
>>>>>> XML Attributes?
Re: Ecore XML schema mapping [message #593812 is a reply to message #57448] |
Ed Merks Messages: 33218 Registered: July 2009 |
Ralf,
> Attributes?
<html>
<head>
<title></title>
</head>
Ralf,<br>
<br>
<blockquote><a
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
Attributes? <br>
</blockquote>
<br>
</body>
</html>
Ed Merks
Re: Ecore XML schema mapping [message #593837 is a reply to message #57473] |
Ed,
used for?
Ed Merks wrote:
> Ralf,
>> Attributes?
Re: Ecore XML schema mapping [message #593850 is a reply to message #57498] |
Ralf,
for instances.
> Ed,
> Eclipse used for?
> Ed Merks wrote:
>> Ralf,
>>> Attributes?
<html>
<head>
</head>
Ralf,<br>
<br>
<br>
Ed Merks
Re: Ecore XML schema mapping [message #593883 is a reply to message #57524] |
Ed,
spot?
Ed Merks wrote:
> Ralf,
> for instances.
>> Ed,
>> Eclipse used for?
>> Ed Merks wrote:
>>> Ralf,
>>>> Attributes?
Re: Ecore XML schema mapping [message #593906 is a reply to message #57548] |
Ralf,
Yes.
> Ed,
> Ed Merks wrote:
>> Ralf,
>>> Ed,
>>> model?
>>> Eclipse used for?
>>> Ed Merks wrote:
>>>> Ralf,
>>>>> XML Attributes?
Ed Merks
Re: Ecore XML schema mapping [message #593923 is a reply to message #57572] |
Ed,
Ralf
Ed Merks wrote:
> Ralf,
> Yes.
>> Ed,
>> Ed Merks wrote:
>>> Ralf,
>>>> Ed,
>>>> model?
>>>> Eclipse used for?
>>>> Ed Merks wrote:
>>>>> Ralf,
>>>>>> XML Attributes?
Current Time: Fri Sep 27 05:34:20 GMT 2024
Powered by FUDForum. Page generated in 0.04939 seconds
