Home » Eclipse Projects » DTP » Generic JDBC Driver
Generic JDBC Driver [message #11758] Tue, 02 May 2006 18:10 Go to next message
Michael Woski is currently offline Michael WoskiFriend
I'm running eclipse 3.2 RC2 and the latest dtp 0.9.
The definition of a Generic JDBC Connection in the preferences works fine so
far. But when I try to connect to some database from the Data Explorer, I
can't see any of my defined connections. So far so good, being patient I
tried to create one manually. Works fine, unless I can't see my tables and
stuff.
After that I figured that in the Manage Configuration dialog the
Connectivity feature shows two errors:
Plug-in "org.eclipse.datatools.connectivity.dbdefinition.genericJDBC "
version "0.7.0.200602241" referenced by this feature is missing.
Plug-in "org.eclipse.datatools.connectivity.sqm.server.ui" version
"0.7.0.200603081" referenced by this feature is missing.
The funny thing is, both seem to be there.
I even tried a fresh eclipse configuration and a virgin workspace - to no
avail
Is that normal ???
Re: Generic JDBC Driver [message #11894 is a reply to message #11758] Wed, 03 May 2006 19:39 Go to previous messageGo to next message
Originally posted by: jograham.sybase.com
This problem with the connectivity feature has been noticed by others, but
we're having a hard time getting a reproduction on the development machines.
Anyway, that should not impact your usage of the generic JDBC connection
profile. I am able to make it work with, for example, Sybase ASA. Which
database are you trying to connect to?
John Graham
Eclipse Data Tools Platform PMC Chair
Staff Software Engineer
Sybase, Inc.
"M;chi" <woskimi@yahoo.de> wrote in message
news:e3878e$643$1@utils.eclipse.org...
> so
> stuff.
> avail
> Is that normal ???
Re: Generic JDBC Driver [message #12490 is a reply to message #11894] Thu, 04 May 2006 13:02 Go to previous messageGo to next message
OK, it was my fault; well not exactly, but somehow my db seemed to be
corrupt.
But still, I can't use the Connections defined under Preferences. Also, the
connection definition in both cases, the DB Explorer and the Preferences,
are not congruent - but could be!? Or am I wrong about that?
thx
John Graham wrote:
> machines. Anyway, that should not impact your usage of the generic JDBC
> connection profile. I am able to make it work with, for example, Sybase
> ASA. Which database are you trying to connect to?
> Regards,
> John Graham
> Sybase, Inc.
>> so
>> and stuff.
>> avail
>> Is that normal ???
Re: Generic JDBC Driver [message #12515 is a reply to message #11894] Thu, 04 May 2006 13:26 Go to previous messageGo to next message
Vladyslav Kosulin is currently offline Vladyslav KosulinFriend
I confirm the issue for the following environemnt:
Win XP Pro SP2 with all recent patches applied,
Fresh install of Eclipse SDK with DTP only:
eclipse-SDK-3.2RC2-win32
dtp-sdk_0.9RC3_N050306
with newly created workspace immediately reports the same issue.
Here are configuration details:
*** Date: Thu May 04 09:21:32 EDT 2006
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=I20060428-1315
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\java\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
fec_74
-clean
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1146748840278
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xmx1024m
-jar
C:\java\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\java\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_06\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_06\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_06
java.io.tmpdir=C:\DOCUME~1\kosulin\LOCALS~1\Temp\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32; C:\WINDOWS;c:\sybase\OCS-12_0\dll;c:\sybase\OCS-12_0\bin;c:\ sybase\ASEP;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System 32\Wbem;c:\sybase\SQLRemote\dll;C:\Program
Files\QuickTime\QTSystem\
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,java
x.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.row set.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bord er,javax.swing.colorchooser,javax.swing.event,javax.swing.fi lechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swin g.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,j avax.swing.table,javax.swing.text,javax.swing.text.html,java x.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tr ee,javax.swing.undo,javax.transaction,javax.transaction.xa,j avax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.pa rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax,javax.xml.transform.stream,javax.xml.validatio n,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_ 2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,o rg.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA .TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingC ontextExtPackage,org.omg.CosNaming.NamingContextPackage,org. omg.Dynamic,org.omg.DynamicAny
,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny. DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,or g.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInt erceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org. omg.PortableServer,org.omg.PortableServer.CurrentPackage,org .omg.PortableServer.POAManagerPackage,org.omg.PortableServer .POAPackage,org.omg.PortableServer.portable,org.omg.Portable Server.ServantLocatorPackage,org.omg.SendingContext,org.omg. stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom. events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sa x.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\java\eclipse\configuration\org.eclipse.o sgi\bundles
osgi.clean=true
osgi.configuration.area=file:/C:/java/eclipse/configuration/
osgi.framework=file:/c:/java/eclipse/plugins/org.eclipse.osg i_3.2.0.v20060426.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.0.v20060426
osgi.install.area=file:/C:/java/eclipse/
osgi.instance.area=file:/C:/Documents and Settings/kosulin/.workspace/
osgi.instance.area.default=file:/C:/Documents and Settings/kosulin/workspace/
osgi.logfile=C:\Documents and Settings\kosulin\.workspace\.metadata\.log
osgi.manifest.cache=C:\java\eclipse\configuration\org.eclips e.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\java\eclipse\plugins\org.eclipse.plat form_3.2.0.v20060427-2000\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\java\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\jre1.5.0_06\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_06\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_06\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_06\lib\charsets.jar;C:\Program Files\Java\jre1.5.0_06\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_06\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1251
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\java\eclipse
user.home=C:\Documents and Settings\kosulin
user.language=en
user.name=kosulin
user.timezone=America/New_York
user.variant=
*** Features:
org.eclipse.datatools.connectivity.feature (0.9.0.200605031) "Eclipse Data Tools
Platform Connectivity"
org.eclipse.datatools.connectivity.oda.designer.feature (0.9.0.200605031)
"Eclipse Data Tools Platform Connectivity Open Data Access (ODA) Designer"
org.eclipse.datatools.connectivity.oda.feature (0.9.0.200605031) "Eclipse Data
Tools Platform Connectivity Open Data Access (ODA)"
org.eclipse.datatools.modelbase.feature (0.9.0.200605031) "Eclipse Data Tools
Platform Model Base"
org.eclipse.datatools.sdk.feature (0.9.0.200605031) "Eclipse Data Tools Platform
SDK"
org.eclipse.datatools.sqldevtools.feature (0.9.0.200605031) "Eclipse Data Tools
Platform SQL Development Tools"
org.eclipse.jdt (3.2.0.v20060428-0010-F7snp1fW7B-a1TP) "Eclipse Java Development
Tools"
org.eclipse.jdt.source (3.2.0.v20060428-0010-F7snp1fW7B-a1TP) "Eclipse Java
Development Tools SDK"
org.eclipse.pde (3.2.0.v20060427-2000-6zXJJzJlY9-GOLG) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.2.0.v20060427-2000-6zXJJzJlY9-GOLG) "Eclipse Plug-in
Development Environment Developer Resources"
org.eclipse.platform (3.2.0.v20060427-2000-6XCZjLWsTFwIKIR) "Eclipse Platform"
org.eclipse.platform.source (3.2.0.v20060427-2000-6XCZjLWsTFwIKIR) "Eclipse
Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.0.v20060427-2000-RM8Ia5esKS-MzKJ) "Eclipse RCP"
org.eclipse.rcp.source (3.2.0.v20060427-2000-RM8Ia5esKS-MzKJ) "Eclipse RCP
org.eclipse.sdk (3.2.0.v20060404-FMJO1yT31vQtGjW) "Eclipse Project SDK"
*** Plug-in Registry:
com.ibm.icu (3.4.4.1) "International Components for Unicode for Java (ICU4J)"
[Active]
com.ibm.icu.source (3.4.4.1) "International Components for Unicode for Java
(ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.27) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.103.v20060426) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20060425) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.0.v20060426) "Ant UI" [Resolved]
org.eclipse.compare (3.2.0.v20060426) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060418) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060427-0800) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060426) "Eclipse Content Mechanism" [Active]
org.eclipse.core.expressions (3.2.0.v20060427-1600) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.2.0.v20060427-1600) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060411) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20051114) "Core File System for
Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060426) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.0.v20060426) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060426) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060426) "Core Resource Management
Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060426) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060426) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060426) "Authorization
Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.0.v20060426) "Eclipse
Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060426) "Core Variables" [Resolved]
org.eclipse.datatools.connectivity (0.9.0.200604141) "Data Tools Connectivity
Plug-in" [Resolved]
org.eclipse.datatools.connectivity.db.derby (0.9.0.200604051) "Derby Plug-in"
[Installed]
org.eclipse.datatools.connectivity.db.generic (0.7.0.200602241) "Generic DB
Connectivity Plug-in" [Resolved]
org.eclipse.datatools.connectivity.db.generic.ui (0.7.0.200602241) "Generic DB
UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.dbdefinition.db2.luw (0.7.0.200602241) "DB2
UDB Database Definition Plug-in" [Resolved]
org.eclipse.datatools.connectivity.dbdefinition.derby (0.7.0.200602241) "IBM
Cloudscape Database Definition" [Resolved]
org.eclipse.datatools.connectivity.dbdefinition.mysql (0.7.0.200602241)
"DBDefinition Generic JDBC Plug-in" [Resolved]
org.eclipse.datatools.connectivity.dbdefinition.oracle (0.7.0.200602241) "Oracle
org.eclipse.datatools.connectivity.dbdefinition.sybase (0.7.0.200602241) "Sybase
org.eclipse.datatools.connectivity.derby (0.9.0.200604051) "RDB Derby Plug-in"
[Installed]
org.eclipse.datatools.connectivity.derby.ui (0.9.0.200604051) "Derby UI Plug-in"
[Installed]
org.eclipse.datatools.connectivity.finfo (0.9.0.200605031) "Eclipse Data Tools
Platform Connectivity" [Resolved]
org.eclipse.datatools.connectivity.oda (3.0.1.200605021) "DTP Open Data Access"
[Resolved]
org.eclipse.datatools.connectivity.oda.consumer (3.0.1.200605021) "DTP ODA
Consumer Helper Component Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda.design (3.0.0.200604251) "DTP ODA Design
Session Model" [Installed]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.1.200604251) "DTP ODA
Designer UI Framework Plug-in" [Installed]
org.eclipse.datatools.connectivity.oda.designer.finfo (0.9.0.200605031) "Eclipse
Data Tools Platform Connectivity Open Data Access (ODA) Designer" [Resolved]
org.eclipse.datatools.connectivity.oda.finfo (0.9.0.200605031) "Eclipse Data
Tools Platform Connectivity Open Data Access (ODA)" [Resolved]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.0.200604141) "DTP ODA Flat
File Run-time Driver" [Resolved]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.0.200604241) "DTP ODA
Flat File Designer" [Installed]
org.eclipse.datatools.connectivity.oda.profile (3.0.0.200604141) "DTP ODA
Connection Profile Framework Plug-in" [Resolved]
org.eclipse.datatools.connectivity.sqm.core (0.9.0.200604051) "RDB Core" [Installed]
org.eclipse.datatools.connectivity.sqm.core.ui (0.7.0.200603071) "Core UI
plugin" [Installed]
org.eclipse.datatools.connectivity.sqm.server.ui (0.7.0.2006003081) "Server
Explorer plugin" [Installed]
org.eclipse.datatools.connectivity.ui (0.9.0.200604141) "Data Tools Connectivity
org.eclipse.datatools.connectivity.ui.dse (0.7.0.200602241) "DTP Data Source
Explorer Plug-in" [Resolved]
org.eclipse.datatools.doc.isv (0.9.0.200604071) "Data Tools Documentation
Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (0.7.0.200602241) "DBDefinition
Model" [Installed]
org.eclipse.datatools.modelbase.derby (0.9.0.200604071) "Derby Plug-in" [Installed]
org.eclipse.datatools.modelbase.edit (0.7.0.200602241) "SQLModel Edit Plug-in"
[Installed]
org.eclipse.datatools.modelbase.finfo (0.9.0.200605031) "Eclipse Data Tools
Platform Model Base" [Resolved]
org.eclipse.datatools.modelbase.sql (0.7.0.200602241) "SQLModel Plug-in" [Installed]
org.eclipse.datatools.modelbase.sql.query (0.7.0.200602241) "SQL Query Model
Plugin" [Installed]
org.eclipse.datatools.modelbase.sql.xml.query (0.7.0.200602241) "SQL XML Query
Model Plugin" [Installed]
org.eclipse.datatools.sdk.finfo (0.9.0.200605031) "Eclipse Data Tools Platform
SDK" [Resolved]
org.eclipse.datatools.source (0.9.0.200605031) "Data Tools Platform Source Code"
[Resolved]
org.eclipse.datatools.sqltools.common.ui (0.9.0.200603301) "Eclipse Data Tools
Platform SQL Tools Common UI Plug-in" [Resolved]
org.eclipse.datatools.sqltools.db.derby (0.9.0.200603301) "Eclipse Data Tools
Platform Derby SQL Tools Plug-in" [Installed]
org.eclipse.datatools.sqltools.db.generic (0.9.0.200603301) "Generic Database
org.eclipse.datatools.sqltools.debugger.core (0.9.0.200603301) "Eclipse Data
Tools Platform SQL Debugger Framework" [Installed]
org.eclipse.datatools.sqltools.editor.core (0.9.0.200603301) "DTP SQL Editor
Core Plug-in" [Installed]
org.eclipse.datatools.sqltools.finfo (0.9.0.200605031) "Eclipse Data Tools
Platform SQL Development Tools" [Resolved]
org.eclipse.datatools.sqltools.parsers.sql (0.7.0.200602241) "SQL Parser Plugin"
[Installed]
org.eclipse.datatools.sqltools.parsers.sql.lexer (0.7.0.200602241) "Lexer
Plug-in" [Resolved]
org.eclipse.datatools.sqltools.parsers.sql.query (0.7.0.200602241) "SQL Query
Parser Plugin" [Installed]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (0.7.0.200602241) "SQL XML
Query Parser Plug-in" [Installed]
org.eclipse.datatools.sqltools.plan (0.9.0.200604101) "SQL Execution Plan View
org.eclipse.datatools.sqltools.result (0.9.0.200603301) "SQL Results View
Plug-in" [Resolved]
org.eclipse.datatools.sqltools.routineeditor (0.9.0.200603301) "DTP SQL Tools
Routine Editor Plug-in" [Installed]
org.eclipse.datatools.sqltools.sql (0.9.0.200603301) "Eclipse Data Tools
Platform SQL Core Plug-in" [Resolved]
org.eclipse.datatools.sqltools.sqleditor (0.9.0.200603301) "Eclipse Data Tools
Platform SQL Editor" [Installed]
org.eclipse.datatools.sqltools.sqlscrapbook (0.9.0.200603301) "Sqlscrapbook
org.eclipse.debug.core (3.2.0.v20060427) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.0.v20060427a) "Debug UI" [Active]
org.eclipse.equinox.common (3.2.0.v20060426) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.preferences (3.2.0.v20060426) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.2.0.v20060426) "Extension Registry Support" [Active]
org.eclipse.help (3.2.0.v20060426) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060417) "Help Application Server" [Resolved]
org.eclipse.help.base (3.2.0.v20060426) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060426b) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.0.v20060426) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.2.0.v20060427-2000) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.apt.core (3.2.0.v20060427-1620) "Java Annotation Processing
Core" [Resolved]
org.eclipse.jdt.apt.ui (3.2.0.v20060427-1620) "Java Annotation Processing UI"
[Resolved]
org.eclipse.jdt.core (3.2.0.v_661) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.0.0.v20060427-1600) "Java Code Manipulation
Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.0.v20060427) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.2.0.v20060426) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.2.0.v20060427-1600) "Eclipse JDT Plug-in Developer
Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060428-1300) "Eclipse Java Development User
Guide" [Resolved]
org.eclipse.jdt.junit (3.2.0.v20060428-1300) "Java Development Tools JUnit
support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.0.v20060427-1600) "Java Development Tools
JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.0.v20060427-1600) "Java Development Tools
JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.0.v20060426) "Java Development Tools Launching
Support" [Resolved]
Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.0.v20060428-1300) "Java Development Tools UI" [Active]
org.eclipse.jface (3.2.0.I20060427-0800) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060412-0800) "JFace Data Binding" [Resolved]
org.eclipse.jface.text (3.2.0.v20060427-1600) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.0.v20060427-1600) "Refactoring Core"
[Resolved]
org.eclipse.ltk.ui.refactoring (3.2.0.v20060427-1600) "Refactoring UI" [Resolved]
org.eclipse.osgi.services (3.1.100.v20060426) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.100.v20060426) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.2.0.v20060428-0010) "Eclipse Plug-in Development Environment"
[Resolved]
org.eclipse.pde.build (3.2.0.v20060426) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.2.0.v20060428-0010) "Plug-in Development Core" [Resolved]
org.eclipse.pde.doc.user (3.2.0.v20060428-0010) "Eclipse Plug-in Development
User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.2.0.v20060428-0010) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060427-0800) "Plug-in Development Environment
Runtime" [Resolved]
Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.0.v20060428-0010) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.2.0.v20060427-2000) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.0.v20060426) "Eclipse Platform Plug-in
Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.0.v20060426) "Eclipse Workbench User Guide"
[Resolved]
Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.2.0.v20060427-2000-6XCZjLWsTFwIKIR) "Eclipse Platform Plug-in Developer
org.eclipse.rcp (3.2.0.v20060428-0010) "Eclipse RCP" [Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.2.0.v20060427-2000-RM8Ia5esKS-MzKJ)
"Eclipse RCP Plug-in Developer Resources" [Resolved]
org.eclipse.sdk (3.2.0.v20060413-1200) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.0.v20060427-1600) "Search Support" [Resolved]
org.eclipse.swt (3.2.0.v3231c) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.0.v3231) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.2.0.I200604261810) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.0.I200604261810) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I200603291800) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200604261810) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.0.I200604281200) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.0.I200604281200) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060427-1600) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060417) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.0.I20060427-1600) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060417) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.0.v20060426a) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20060426) "Console" [Resolved]
org.eclipse.ui.editors (3.2.0.v20060428-1300) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.100.v20060425) "External Tools" [Active]
org.eclipse.ui.forms (3.2.0.v20060411) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.2.0.I20060427-1600) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.0.v20060425) "Welcome Framework" [Active]
org.eclipse.ui.intro.universal (3.2.0.v20060425b) "Universal Welcome" [Active]
org.eclipse.ui.navigator (3.2.0.I20060427-1200) "Common Navigator View" [Resolved]
org.eclipse.ui.navigator.resources (3.2.0.I20060427-0800) "Navigator Workbench
Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060412-0800) "R21 Presentation
Plug-in" [Resolved]
org.eclipse.ui.views (3.2.0.I20060413-1200) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.0.I20060427-0800) "Tabbed Properties
View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060412-0800) "Eclipse UI Win32 Enhancements"
[Resolved]
org.eclipse.ui.workbench (3.2.0.I20060427-1600) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060207-0800) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060427-1600) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.1.100.v20060428) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.1.100.v20060428) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.1.100.v20051205) "Install/Update Core for
Windows" [Resolved]
org.eclipse.update.scheduler (3.1.100.v20060428) "Automatic Updates Scheduler"
[Active]
org.eclipse.update.ui (3.1.100.v20060428) "Install/Update UI" [Active]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.junit4 (1.0.0) "JUnit Testing Framework Version 4" [Resolved]
system.bundle (3.2.0.v20060426) "OSGi System Bundle" [Active]
*** User Preferences:
#Thu May 04 09:21:32 EDT 2006
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=10
/instance/org.eclipse.ui/showIntro=false
@org.eclipse.ui=3.2.0.I20060427-1600
/instance/org.eclipse.ui.ide/platformState=1146748840928
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
@org.eclipse.core.resources=3.2.0.v20060426
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
@org.eclipse.ui.ide=3.2.0.I20060427-1600
@org.eclipse.jdt.ui=3.2.0.v20060428-1300
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Doc uments and
Settings\\kosulin\\.workspace
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
file_export_version=3.0
*** Current Install Configuration:
Install configuration:
Last changed on May 4, 2006
Location: file:/C:/java/eclipse/configuration/org.eclipse.update/platf orm.xml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.platform, Version: null
ID: org.eclipse.datatools.connectivity.oda.designer.finfo, Version: null
ID: org.eclipse.jdt, Version: null
ID: org.eclipse.datatools.modelbase.finfo, Version: null
ID: org.eclipse.jdt.source, Version: null
ID: org.eclipse.sdk, Version: null
ID: org.eclipse.pde.source, Version: null
ID: org.eclipse.rcp.source, Version: null
ID: org.eclipse.rcp, Version: null
ID: org.eclipse.platform.source, Version: null
ID: org.eclipse.datatools.sqltools.finfo, Version: null
ID: org.eclipse.pde, Version: null
ID: org.eclipse.datatools.sdk.finfo, Version: null
ID: org.eclipse.datatools.connectivity.oda.finfo, Version: null
ID: org.eclipse.datatools.connectivity.finfo, Version: null
Configured plug-ins:
file:/C:/java/eclipse/plugins/com.ibm.icu.source_3.4.4.1/
file:/C:/java/eclipse/plugins/com.ibm.icu_3.4.4.1.jar
file:/C:/java/eclipse/plugins/com.jcraft.jsch_0.1.27.jar
file:/C:/java/eclipse/plugins/org.apache.ant_1.6.5/
file:/C:/java/eclipse/plugins/org.apache.lucene_1.4.103.v200 60426/
file:/C:/java/eclipse/plugins/org.eclipse.ant.core_3.1.100.v 20060425.jar
file:/C:/java/eclipse/plugins/org.eclipse.ant.ui_3.2.0.v2006 0426.jar
file:/C:/java/eclipse/plugins/org.eclipse.compare_3.2.0.v200 60426.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.boot_3.1.100. v20060418.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.commands_3.2. 0.I20060427-0800.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.contenttype_3 .2.0.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.expressions_3 .2.0.v20060427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.filebuffers_3 .2.0.v20060427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.filesystem.wi n32.x86_1.0.0.v20051114.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.filesystem_1. 0.0.v20060411.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.jobs_3.2.0.v2 0060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.resources.com patibility_3.2.0.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.resources.win 32_3.2.0.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.resources_3.2 .0.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.runtime.compa tibility.auth_3.2.0.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.runtime.compa tibility.registry_3.2.0.v20060426/
file:/C:/java/eclipse/plugins/org.eclipse.core.runtime.compa tibility_3.1.100.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.runtime_3.2.0 .v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.core.variables_3.1 .100.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.db.derby_0.9.0.200604051.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.db.generic.ui_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.db.generic_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.dbdefinition.db2.luw_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.dbdefinition.derby_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.dbdefinition.genericJDBC_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.dbdefinition.oracle_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.dbdefinition.sybase_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.derby.ui_0.9.0.200604051.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.derby_0.9.0.200604051.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.finfo_0.9.0.200605031.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.oda.consumer_3.0.1.200605021.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.oda.design.ui_3.0.1.200604251.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.oda.designer.finfo_0.9.0.200605031.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.oda.design_3.0.0.200604251.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.oda.finfo_0.9.0.200605031.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.oda.flatfile.ui_3.0.0.200604241.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.oda.flatfile_3.0.0.200604141.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.oda.profile_3.0.0.200604141.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.oda_3.0.1.200605021.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.sqm.core.ui_0.7.0.200603071/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.sqm.core_0.9.0.200604051.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.sqm.server.ui_0.7.0.200603081/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.ui.dse_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity.ui_0.9.0.200604141/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.connecti vity_0.9.0.200604141/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.doc.isv_ 0.9.0.200605031.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.modelbas e.dbdefinition_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.modelbas e.derby_0.9.0.200604071.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.modelbas e.edit_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.modelbas e.finfo_0.9.0.200605031.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.modelbas e.sql.query_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.modelbas e.sql.xml.query_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.modelbas e.sql_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sdk.finf o_0.9.0.200605031.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.source_0 .9.0.200605031/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .common.ui_0.9.0.200603301.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .db.derby_0.9.0.200603301.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .db.generic_0.9.0.200603301.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .debugger.core_0.9.0.200603301.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .editor.core_0.9.0.200603301.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .finfo_0.9.0.200605031.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .parsers.sql.lexer_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .parsers.sql.query_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .parsers.sql.xml.query_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .parsers.sql_0.7.0.200602241/
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .plan_0.9.0.200604101.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .result_0.9.0.200603301.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .routineeditor_0.9.0.200603301.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .sqleditor_0.9.0.200603301.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .sqlscrapbook_0.9.0.200603301.jar
file:/C:/java/eclipse/plugins/org.eclipse.datatools.sqltools .sql_0.9.0.200603301.jar
file:/C:/java/eclipse/plugins/org.eclipse.debug.core_3.2.0.v 20060427.jar
file:/C:/java/eclipse/plugins/org.eclipse.debug.ui_3.2.0.v20 060427a.jar
file:/C:/java/eclipse/plugins/org.eclipse.equinox.common_3.2 .0.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.equinox.preference s_3.2.0.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.equinox.registry_3 .2.0.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.help.appserver_3.1 .100.v20060417.jar
file:/C:/java/eclipse/plugins/org.eclipse.help.base_3.2.0.v2 0060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.help.ui_3.2.0.v200 60426b.jar
file:/C:/java/eclipse/plugins/org.eclipse.help.webapp_3.2.0. v20060426/
file:/C:/java/eclipse/plugins/org.eclipse.help_3.2.0.v200604 26.jar
file:/C:/java/eclipse/plugins/org.eclipse.jdt.apt.core_3.2.0 .v20060427-1620.jar
file:/C:/java/eclipse/plugins/org.eclipse.jdt.apt.ui_3.2.0.v 20060427-1620.jar
file:/C:/java/eclipse/plugins/org.eclipse.jdt.core.manipulat ion_1.0.0.v20060427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.jdt.core_3.2.0.v_6 61.jar
file:/C:/java/eclipse/plugins/org.eclipse.jdt.debug.ui_3.2.0 .v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.jdt.debug_3.2.0.v2 0060427/
file:/C:/java/eclipse/plugins/org.eclipse.jdt.doc.isv_3.2.0. v20060427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.jdt.doc.user_3.2.0 .v20060428-1300.jar
file:/C:/java/eclipse/plugins/org.eclipse.jdt.junit.runtime_ 3.2.0.v20060427-1600/
file:/C:/java/eclipse/plugins/org.eclipse.jdt.junit4.runtime _1.0.0.v20060427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.jdt.junit_3.2.0.v2 0060428-1300/
file:/C:/java/eclipse/plugins/org.eclipse.jdt.launching_3.2. 0.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.jdt.source_3.2.0.v 20060428-0010-F7snp1fW7B-a1TP/
file:/C:/java/eclipse/plugins/org.eclipse.jdt.ui_3.2.0.v2006 0428-1300.jar
file:/C:/java/eclipse/plugins/org.eclipse.jdt_3.2.0.v2006042 7-2000.jar
file:/C:/java/eclipse/plugins/org.eclipse.jface.databinding_ 1.0.0.I20060412-0800.jar
file:/C:/java/eclipse/plugins/org.eclipse.jface.text_3.2.0.v 20060427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.jface_3.2.0.I20060 427-0800.jar
file:/C:/java/eclipse/plugins/org.eclipse.ltk.core.refactori ng_3.2.0.v20060427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.ltk.ui.refactoring _3.2.0.v20060427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.osgi.services_3.1. 100.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.osgi.util_3.1.100. v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.osgi_3.2.0.v200604 26.jar
file:/C:/java/eclipse/plugins/org.eclipse.pde.build_3.2.0.v2 0060426/
file:/C:/java/eclipse/plugins/org.eclipse.pde.core_3.2.0.v20 060428-0010.jar
file:/C:/java/eclipse/plugins/org.eclipse.pde.doc.user_3.2.0 .v20060428-0010.jar
file:/C:/java/eclipse/plugins/org.eclipse.pde.junit.runtime_ 3.2.0.v20060428-0010.jar
file:/C:/java/eclipse/plugins/org.eclipse.pde.runtime_3.2.0. v20060427-0800.jar
file:/C:/java/eclipse/plugins/org.eclipse.pde.source_3.2.0.v 20060427-2000-6zXJJzJlY9-GOLG/
file:/C:/java/eclipse/plugins/org.eclipse.pde.ui_3.2.0.v2006 0428-0010.jar
file:/C:/java/eclipse/plugins/org.eclipse.pde_3.2.0.v2006042 8-0010.jar
file:/C:/java/eclipse/plugins/org.eclipse.platform.doc.isv_3 .2.0.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.platform.doc.user_ 3.2.0.v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.platform.source.wi n32.win32.x86_3.2.0.v20060427-2000-6XCZjLWsTFwIKIR/
file:/C:/java/eclipse/plugins/org.eclipse.platform.source_3. 2.0.v20060427-2000-6XCZjLWsTFwIKIR/
file:/C:/java/eclipse/plugins/org.eclipse.platform_3.2.0.v20 060427-2000/
file:/C:/java/eclipse/plugins/org.eclipse.rcp.source.win32.w in32.x86_3.2.0.v20060427-2000-RM8Ia5esKS-MzKJ/
file:/C:/java/eclipse/plugins/org.eclipse.rcp.source_3.2.0.v 20060427-2000-RM8Ia5esKS-MzKJ/
file:/C:/java/eclipse/plugins/org.eclipse.rcp_3.2.0.v2006042 8-0010.jar
file:/C:/java/eclipse/plugins/org.eclipse.sdk_3.2.0.v2006041 3-1200/
file:/C:/java/eclipse/plugins/org.eclipse.search_3.2.0.v2006 0427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.swt.win32.win32.x8 6_3.2.0.v3231.jar
file:/C:/java/eclipse/plugins/org.eclipse.swt_3.2.0.v3231c.j ar
file:/C:/java/eclipse/plugins/org.eclipse.team.core_3.2.0.I2 00604261810.jar
file:/C:/java/eclipse/plugins/org.eclipse.team.cvs.core_3.2. 0.I200604261810.jar
file:/C:/java/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.2. 0.I200604261810.jar
file:/C:/java/eclipse/plugins/org.eclipse.team.cvs.ssh_3.2.0 .I200603291800.jar
file:/C:/java/eclipse/plugins/org.eclipse.team.cvs.ui_3.2.0. I200604281200.jar
file:/C:/java/eclipse/plugins/org.eclipse.team.ui_3.2.0.I200 604281200.jar
file:/C:/java/eclipse/plugins/org.eclipse.text_3.2.0.v200604 27-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.tomcat_4.1.130.v20 060417/
file:/C:/java/eclipse/plugins/org.eclipse.ui.browser_3.2.0.v 20060417.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.cheatsheets_3.2 .0.v20060426a.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.console_3.1.100 .v20060426.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.editors_3.2.0.v 20060428-1300.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.externaltools_3 .1.100.v20060425.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.forms_3.2.0.v20 060411.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.ide_3.2.0.I2006 0427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.intro.universal _3.2.0.v20060425b/
file:/C:/java/eclipse/plugins/org.eclipse.ui.intro_3.2.0.v20 060425.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.navigator.resou rces_3.2.0.I20060427-0800.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.navigator_3.2.0 .I20060427-1200.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.presentations.r 21_3.2.0.I20060412-0800.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.views.propertie s.tabbed_3.2.0.I20060427-0800.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.views_3.2.0.I20 060413-1200.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.win32_3.2.0.I20 060412-0800.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.workbench.compa tibility_3.2.0.I20060207-0800/
file:/C:/java/eclipse/plugins/org.eclipse.ui.workbench.texte ditor_3.2.0.v20060427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui.workbench_3.2.0 .I20060427-1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.ui_3.2.0.I20060427 -1600.jar
file:/C:/java/eclipse/plugins/org.eclipse.update.configurato r_3.1.100.v20060428.jar
file:/C:/java/eclipse/plugins/org.eclipse.update.core.win32_ 3.1.100.v20051205.jar
file:/C:/java/eclipse/plugins/org.eclipse.update.core_3.1.10 0.v20060428.jar
file:/C:/java/eclipse/plugins/org.eclipse.update.scheduler_3 .1.100.v20060428.jar
file:/C:/java/eclipse/plugins/org.eclipse.update.ui_3.1.100. v20060428.jar
file:/C:/java/eclipse/plugins/org.junit4_1.0.0/
file:/C:/java/eclipse/plugins/org.junit_3.8.1/
Re: Generic JDBC Driver [message #12607 is a reply to message #12515] Fri, 05 May 2006 21:58 Go to previous messageGo to next message
Hi Vladyslav:
Thanks for the information. I fixed the feature problem you confirm below.
Turns out that one version and one plug-in ID were not matching. In the DTP
0.9RC3 5/5 build this is fixed.
John Graham
"Vladyslav Kosulin" <kosulin@yahoo.com> wrote in message
news:e3cvd3$3ev$1@utils.eclipse.org...
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> fec_74
> -clean
> -vm
> -jar
> eof=eof
> file.separator=\
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.clean=true
> osgi.nl=en_US
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=
> sun.desktop=windows
> user.country=US
> user.language=en
> user.name=kosulin
> user.variant=
> *** Features:
> Tools Platform Connectivity"
> Data Tools Platform Connectivity Open Data Access (ODA)"
> Tools Platform Model Base"
> Platform SDK"
> Tools Platform SQL Development Tools"
> Development Tools"
> Java Development Tools SDK"
> Plug-in Development Environment Developer Resources"
> Platform"
> "Eclipse Platform Plug-in Developer Resources"
> (ICU4J)" [Active]
> Java (ICU4J) source plug-in" [Resolved]
> [Active]
> [Active]
> [Active]
> [Resolved]
> for Windows" [Resolved]
> [Active]
> Management Win32 Fragment" [Resolved]
> Plug-in Compatibility" [Active]
> "Authorization Compatibility Plug-in" [Active]
> DB Connectivity Plug-in" [Resolved]
> "Generic DB UI Plug-in" [Resolved]
> "DB2 UDB Database Definition Plug-in" [Resolved]
> "IBM Cloudscape Database Definition" [Resolved]
> "Oracle Database Definition Plug-in" [Resolved]
> "Sybase Database Definition Plug-in" [Resolved]
> Tools Platform Connectivity" [Resolved]
> Access" [Resolved]
> Design Session Model" [Installed]
> ODA Designer UI Framework Plug-in" [Installed]
> [Resolved]
> Data Tools Platform Connectivity Open Data Access (ODA)" [Resolved]
> Flat File Run-time Driver" [Resolved]
> ODA Flat File Designer" [Installed]
> [Installed]
> plugin" [Installed]
> "Server Explorer plugin" [Installed]
> Connectivity UI Plug-in" [Resolved]
> Source Explorer Plug-in" [Resolved]
> Plug-in" [Resolved]
> "DBDefinition Model" [Installed]
> [Installed]
> Tools Platform Model Base" [Resolved]
> [Installed]
> Query Model Plugin" [Installed]
> Platform SDK" [Resolved]
> Code" [Resolved]
> Tools Platform SQL Tools Common UI Plug-in" [Resolved]
> Tools Platform Derby SQL Tools Plug-in" [Installed]
> Database Plug-in" [Installed]
> Data Tools Platform SQL Debugger Framework" [Installed]
> Editor Core Plug-in" [Installed]
> Plugin" [Installed]
> Plug-in" [Resolved]
> Query Parser Plugin" [Installed]
> "SQL XML Query Parser Plug-in" [Installed]
> View Plug-in" [Installed]
> Plug-in" [Resolved]
> Tools Routine Editor Plug-in" [Installed]
> Tools Platform SQL Editor" [Installed]
> "Sqlscrapbook Plug-in" [Installed]
> [Active]
> Mechanism" [Active]
> Support" [Active]
> [Resolved]
> [Resolved]
> Processing Core" [Resolved]
> UI" [Resolved]
> Manipulation Functionality" [Resolved]
> support" [Resolved]
> Tools JUnit runtime support" [Resolved]
> Tools JUnit4 runtime support" [Resolved]
> Launching Support" [Resolved]
> Java Development Tools SDK" [Resolved]
> [Active]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Environment" [Resolved]
> Build Support" [Resolved]
> [Resolved]
> Development User Guide" [Resolved]
> Test" [Resolved]
> Environment Runtime" [Resolved]
> Plug-in Development Environment Developer Resources" [Resolved]
> [Resolved]
> Guide" [Resolved]
> "Eclipse Platform Plug-in Developer Resources" [Resolved]
> (3.2.0.v20060427-2000-RM8Ia5esKS-MzKJ) "Eclipse RCP Plug-in Developer
> Windows" [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> [Active]
> [Resolved]
> Workbench Components" [Resolved]
> Plug-in" [Resolved]
> Properties View" [Resolved]
> Enhancements" [Resolved]
> Framework" [Active]
> Windows" [Resolved]
> Scheduler" [Active]
> Location:
> Configured sites:
> platform:/base/
Re: Generic JDBC Driver [message #12650 is a reply to message #12490] Fri, 05 May 2006 22:05 Go to previous messageGo to next message
In the preferences you define a template which can then be used in any
number of connection profile definitions. In the connection profile
definition, you can change values from the template, so this is how you can
get different values in each place. The idea of the template is to allow you
to set basic information, which you can then use as-is or specialize in each
connection profile (for example, changing the port number, user
name/password...).
Not sure why you are having problems connecting -- what database and version
are you trying to connect with?
John Graham
news:e3ctv2$ohq$1@utils.eclipse.org...
> corrupt.
> the
> thx
> John Graham wrote:
>> Hi,
>> but
>> Regards,
>> John Graham
>> Sybase, Inc.
>>> fine
>>> so
>>> I
>>> and stuff.
>>> no
>>> avail
>>> Is that normal ???
Re: Generic JDBC Driver [message #12735 is a reply to message #12650] Sat, 06 May 2006 05:09 Go to previous messageGo to next message
Hi John,
not being able to connect is an old hat. There were corrupt tables in my db,
and it now works just fine again.
But what you describe with the templates is exactly what does _not_ work; at
least with the Generic JDBC Drivers I've defined. There are just no such
templates nowhere to see in the Data Explorer.
thx
John Graham wrote:
> can get different values in each place. The idea of the template is to
> allow you to set basic information, which you can then use as-is or
> specialize in each connection profile (for example, changing the port
> number, user name/password...).
> version are you trying to connect with?
> Regards,
> John Graham
>> corrupt.
>> the
>> thx
>> John Graham wrote:
>>> Hi,
>>> but
>>> Regards,
>>> John Graham
>>> Sybase, Inc.
>>>> fine
>>>> so
>>>> I
>>>> I tried to create one manually. Works fine, unless I can't see my
>>>> tables and stuff.
>>>> no
>>>> avail
>>>> Is that normal ???
Re: Generic JDBC Driver [message #13563 is a reply to message #12735] Tue, 09 May 2006 13:54 Go to previous messageGo to next message
This might be related to the following bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=140280
Which locale is your machine using?
John Graham
news:e3hb00$77u$1@utils.eclipse.org...
> Hi John,
> db,
> at
> thx
> John Graham wrote:
>> Hi,
>> Regards,
>> John Graham
>>> corrupt.
>>> the
>>> Preferences,
>>> thx
>>> John Graham wrote:
>>>> Hi,
>>>> but
>>>> Regards,
>>>> John Graham
>>>> Sybase, Inc.
>>>>> fine
>>>>> so
>>>>> Explorer,
>>>>> I
>>>>> tables and stuff.
>>>>> no
>>>>> avail
>>>>> Is that normal ???
Re: Generic JDBC Driver [message #13800 is a reply to message #13563] Thu, 11 May 2006 09:58 Go to previous message
I use en_GB and UTF-8
John Graham wrote:
> Regards,
> John Graham
>> Hi John,
>> db,
>> at
>> thx
>> John Graham wrote:
>>> Hi,
>>> Regards,
>>> John Graham
>>>> corrupt.
>>>> the
>>>> Preferences,
>>>> thx
>>>> John Graham wrote:
>>>>> Hi,
>>>>> but
>>>>> JDBC connection profile. I am able to make it work with, for example,
>>>>> Sybase ASA. Which database are you trying to connect to?
>>>>> Regards,
>>>>> John Graham
>>>>> Sybase, Inc.
>>>>>> fine
>>>>>> so
>>>>>> Explorer,
>>>>>> I
>>>>>> patient I tried to create one manually. Works fine, unless I can't
>>>>>> see my tables and stuff.
>>>>>> to no
>>>>>> avail
>>>>>> Is that normal ???
Re: Generic JDBC Driver [message #573441 is a reply to message #11758] Wed, 03 May 2006 19:39 Go to previous message
John Graham is currently offline John GrahamFriend
John Graham
Sybase, Inc.
> so
> stuff.
> avail
> Is that normal ???
Re: Generic JDBC Driver [message #573522 is a reply to message #11894] Thu, 04 May 2006 13:02 Go to previous message
corrupt.
thx
John Graham wrote:
> Regards,
> John Graham
> Sybase, Inc.
>> so
>> and stuff.
>> avail
>> Is that normal ???
Re: Generic JDBC Driver [message #573554 is a reply to message #11894] Thu, 04 May 2006 13:26 Go to previous message
win32
-ws
win32
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
fec_74
-clean
-vm
-jar
eof=eof
file.separator=\
line.separator=
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.clean=true
osgi.nl=en_US
osgi.os=win32
osgi.ws=win32
path.separator=;
sun.cpu.isalist=
sun.desktop=windows
user.country=US
user.language=en
user.name=kosulin
user.variant=
*** Features:
SDK"
Tools"
[Active]
Windows" [Resolved]
Plug-in" [Resolved]
[Installed]
[Installed]
[Installed]
[Resolved]
plugin" [Installed]
Plug-in" [Resolved]
Model" [Installed]
[Installed]
Plugin" [Installed]
SDK" [Resolved]
[Resolved]
[Installed]
Plug-in" [Resolved]
Plug-in" [Resolved]
Mechanism" [Active]
Core" [Resolved]
[Resolved]
Guide" [Resolved]
Guide" [Resolved]
support" [Resolved]
Support" [Resolved]
[Resolved]
[Resolved]
Support" [Resolved]
[Resolved]
Runtime" [Resolved]
[Resolved]
Windows" [Resolved]
Plug-in" [Resolved]
View" [Resolved]
[Resolved]
Framework" [Active]
Windows" [Resolved]
[Active]
Configured sites:
platform:/base/
Re: Generic JDBC Driver [message #573695 is a reply to message #12515] Fri, 05 May 2006 21:58 Go to previous message
Hi Vladyslav:
John Graham
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> fec_74
> -clean
> -vm
> -jar
> eof=eof
> file.separator=\
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.clean=true
> osgi.nl=en_US
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=
> sun.desktop=windows
> user.country=US
> user.language=en
> user.name=kosulin
> user.variant=
> *** Features:
> Platform SDK"
> Development Tools"
> Platform"
> (ICU4J)" [Active]
> [Active]
> [Active]
> [Active]
> [Resolved]
> [Active]
> Access" [Resolved]
> [Resolved]
> [Installed]
> plugin" [Installed]
> Plug-in" [Resolved]
> [Installed]
> [Installed]
> Code" [Resolved]
> Plugin" [Installed]
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> [Active]
> Mechanism" [Active]
> Support" [Active]
> [Resolved]
> [Resolved]
> UI" [Resolved]
> support" [Resolved]
> [Active]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Test" [Resolved]
> [Resolved]
> Guide" [Resolved]
> Windows" [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> [Active]
> [Resolved]
> Plug-in" [Resolved]
> Framework" [Active]
> Windows" [Resolved]
> Scheduler" [Active]
> Location:
> Configured sites:
> platform:/base/
Re: Generic JDBC Driver [message #573809 is a reply to message #12490] Fri, 05 May 2006 22:05 Go to previous message
name/password...).
John Graham
> corrupt.
> the
> thx
> John Graham wrote:
>> Hi,
>> but
>> Regards,
>> John Graham
>> Sybase, Inc.
>>> fine
>>> so
>>> I
>>> and stuff.
>>> no
>>> avail
>>> Is that normal ???
Re: Generic JDBC Driver [message #573921 is a reply to message #12650] Sat, 06 May 2006 05:09 Go to previous message
Hi John,
thx
John Graham wrote:
> Regards,
> John Graham
>> corrupt.
>> the
>> thx
>> John Graham wrote:
>>> Hi,
>>> but
>>> Regards,
>>> John Graham
>>> Sybase, Inc.
>>>> fine
>>>> so
>>>> I
>>>> tables and stuff.
>>>> no
>>>> avail
>>>> Is that normal ???
Re: Generic JDBC Driver [message #574389 is a reply to message #12735] Tue, 09 May 2006 13:54 Go to previous message
John Graham
> Hi John,
> db,
> at
> thx
> John Graham wrote:
>> Hi,
>> Regards,
>> John Graham
>>> corrupt.
>>> the
>>> Preferences,
>>> thx
>>> John Graham wrote:
>>>> Hi,
>>>> but
>>>> Regards,
>>>> John Graham
>>>> Sybase, Inc.
>>>>> fine
>>>>> so
>>>>> Explorer,
>>>>> I
>>>>> tables and stuff.
>>>>> no
>>>>> avail
>>>>> Is that normal ???
Re: Generic JDBC Driver [message #574736 is a reply to message #13563] Thu, 11 May 2006 09:58 Go to previous message
John Graham wrote:
> Regards,
> John Graham
>> Hi John,
>> db,
>> at
>> thx
>> John Graham wrote:
>>> Hi,
>>> Regards,
>>> John Graham
>>>> corrupt.
>>>> the
>>>> Preferences,
>>>> thx
>>>> John Graham wrote:
>>>>> Hi,
>>>>> but
>>>>> Regards,
>>>>> John Graham
>>>>> Sybase, Inc.
>>>>>> fine
>>>>>> so
>>>>>> Explorer,
>>>>>> I
>>>>>> to no
>>>>>> avail
>>>>>> Is that normal ???
Previous Topic:Batch ddl generation?
Next Topic:No Tables etc under Schema, using jTDS driver with MS SQL Server
Current Time: Mon Dec 30 17:45:09 GMT 2024
Powered by FUDForum. Page generated in 0.05460 seconds
