Home » Language IDEs » ServerTools (WTP) » Call for WTP M2 Feedback
Re: Call for WTP M2 Feedback [message #55937 is a reply to message #55904] |
Tue, 14 December 2004 18:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: fredrik.sundberg.gmail.com
Arthur Ryman wrote:
> We are planning to release the WTP M2 milestone on Dec. 22 and would
> like to get your feedback on its readiness. Please test the latest
> builds and assess the functions that are advertised in our milestone
> plan for M2.[1] If you find problems, please open Bugzilla defects. Our
> M2 exit criteria is that the High priority items work. Thx.
> [1]
> http://eclipse.org/webtools/development/planning/milestone_p lan_1_0.html
> -- Arthur Ryman
How do we test it? Using the latest nightly of Eclipse 3.1 M4 or the M3
release?
Re: Call for WTP M2 Feedback [message #56040 is a reply to message #55986] |
Wed, 15 December 2004 02:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: varavamu.yahoo.com
hi David,
but if we test this with Eclipse M3 - how are you going to get feedback on
whether this works with M4? According to the milestone plan, the latest I-builds
should work with Eclipse M4, correct?
thanks,
Vijay
David Williams wrote:
> On Tue, 14 Dec 2004 22:31:34 +0000, snpe <snpe@snpe.co.yu> wrote:
> Wow ... feedback already :)
> Basically you should test most recent I-build, on Eclipse M3, and all
> the prereqs
> listed on build page.
> I've updated the milestone plan with some links to the component
> test plans and mini-test-tutorials. The tutorial in particular has
> the steps for getting things installed and running with server, etc.
> Milestone Plan:
> Example Test Tutorial:
> http://eclipse.org/webtools/testtutorials/M2/tutorial1/wtp-t utorial-I.html
> Hope this helps,
Re: Call for WTP M2 Feedback [message #56067 is a reply to message #56040] |
Wed, 15 December 2004 03:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Darin Swanson![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=Darin_Swanson%40us.ibm.com) Messages: 2386 Registered: July 2009 |
Eclipse M4 does not come out until at least the end of this week
Darins
"Vijay Aravamudhan" <varavamu@yahoo.com> wrote in message
news:cpo8vd$bvb$1@www.eclipse.org...
> hi David,
> I-builds should work with Eclipse M4, correct?
> thanks,
> Vijay
>> Basically you should test most recent I-build, on Eclipse M3, and all the
>> prereqs
>> Milestone Plan:
>> Hope this helps,
Re: Call for WTP M2 Feedback [message #56094 is a reply to message #55904] |
Wed, 15 December 2004 08:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Arthur,
Is there some kind of quick-start guide available (eg. how to start from
scratch, what are the project types, how do they fit together)?
I would classify myself as WTP beginner that organized his J2EE projects
in tha past in a complete different way than the WTP does. Whenever I
try something on the WTP I'm hit by "beginner" issues. For example, last
time I defined a Tomcat 5.5 server in the preferences and then invoked a
wizard to create a new web project (just for trying something). However,
I never got the server to pop up in the combo provided in the wizard,
until I discovered, that the wizard is expecting a J2EE server (not a
Tomcat server) although I just wanted to create a simple "web" project
with some servlets and JSPs etc.
Cu, Gunnar
Re: Call for WTP M2 Feedback [message #56147 is a reply to message #55986] |
Wed, 15 December 2004 23:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Haris Peco![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=snpe%40snpe.rs) Messages: 1072 Registered: July 2009 |
David,
Is there instructions for build from cvs - I can't download
all requierments every times - I build eclipse from cvs easy
emf,gef and vep isn't to big for download, but webtools and eclipse are big
problem for me is only : build webtools from cvs (i have webtools cvs tree)
> prereqs listed on build page.
> Milestone Plan:
> Hope this helps,
Re: Call for WTP M2 Feedback [message #56246 is a reply to message #55904] |
Thu, 16 December 2004 16:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: unknown.nodomain.com
are there any plans for relative simple installation? I find it complicated
to install 5-6 different components. For example when I download eclipse I
don't have to download the xml parser, tomcat, ant etc. separately.
Zsolt
"Arthur Ryman" <ryman@ca.ibm.com> schrieb im Newsbeitrag
news:cpmrdl$n8$1@www.eclipse.org...
> We are planning to release the WTP M2 milestone on Dec. 22 and would like
> to get your feedback on its readiness. Please test the latest builds and
> assess the functions that are advertised in our milestone plan for M2.[1]
> If you find problems, please open Bugzilla defects. Our M2 exit criteria
> [1]
> -- Arthur Ryman
Re: Call for WTP M2 Feedback [message #56308 is a reply to message #56261] |
Thu, 16 December 2004 17:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
That is the best solution I think.
Zsolt
> Eventually we will make use of Eclipse's update manager.
> We are still pretty early in development, and we know everyone giving it
> a try are on the "bleeding edge" ... so, thanks for the efforts.
Re: Call for WTP M2 Feedback [message #56690 is a reply to message #55904] |
Mon, 20 December 2004 07:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
The release seems to work fine but makes the UI somewhat unresponsive. I
guess a lot operations are executed in the UI thread. Example: save of a
simple web.xml takes 4 seconds. Save of a simple Java class takes up to
10 seconds. Same workspace but without WTP plugins runs much faster.
Cu, Gunnar
Re: Call for WTP M2 Feedback [message #56717 is a reply to message #56690] |
Mon, 20 December 2004 07:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Another example:
- Open the Server view
- right click on server
- select "Add or remove projects..."
=> takes 24 seconds till the dialog is open!
note that I only have two projects in the workspace (one from the WTP
tutorial any my own project). Only the WTP tutorial project contains a
Java class. The other project is a J2EE Web Project two but containes
only a directory "contribution" with a few zips and their extracted
content (around 1600 files).
Cu, Gunnar
Re: Call for WTP M2 Feedback [message #56823 is a reply to message #55904] |
Mon, 20 December 2004 16:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: daagar.gmail.com
With the current release (I20041218) with Eclipse 3.1M4 and the prereqs
listed, I'm no longer able to launch a Tomcat 5.0 server. I get 'failed to
publish' errors with a 'null' server config. With the WTP in such flux
because of the upcoming milestone and the very recent 3.1M4 release, I'm
not submitting a bugzilla bug yet, just wanted to point it out.
Re: Call for WTP M2 Feedback [message #56848 is a reply to message #56823] |
Mon, 20 December 2004 16:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Changing the server name to contain no spaces solved the issue (I
forgot that someone had already posted this issue). Everything else seems
to work slick.
Re: Call for WTP M2 Feedback [message #56956 is a reply to message #56848] |
Tue, 21 December 2004 10:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> to work slick.
I had the same errors, and by removing the spaces worked.
Re: Call for WTP M2 Feedback [message #57245 is a reply to message #56956] |
Wed, 22 December 2004 16:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: leetree1.yahoo.com
Srgjan Srepfler wrote:
> daagar wrote:
>>> prereqs listed, I'm no longer able to launch a Tomcat 5.0 server. I
>>> get 'failed to publish' errors with a 'null' server config. With the
>>> WTP in such flux because of the upcoming milestone and the very
>>> recent 3.1M4 release, I'm not submitting a bugzilla bug yet, just
>> seems to work slick.
Where do I get the downloads for this? I used to know :-) but forgot.
Re: Call for WTP M2 Feedback [message #57403 is a reply to message #55904] |
Thu, 23 December 2004 09:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: gael.billard.jwaretechnologies.com
There a setting for HTML editor to specify wether to use uppercase or
lowercase tag. Such settings should be shared (or make this setting
available) with other editor like JSP (html part).
> [1]
> -- Arthur Ryman
Current Time: Sat Aug 17 02:32:08 GMT 2024
Powered by FUDForum. Page generated in 0.04407 seconds
