Security [message #57208] |
Sun, 04 November 2007 15:33 |
Originally posted by: m.n.com
Does anyone have examples of implementing security in RAP?
Re: Security [message #57314 is a reply to message #57261] |
Sun, 04 November 2007 21:25 |
Originally posted by: eclipse-dev.volanakis.de
Hi Mark,
IMHO, the suggestion in this article is ill advised. The primary
intention of the capabilities / activities is to reveal UI elements as
the user becomes more proficient with an application. It can be used for
"security" but is very easy to bypass (for example by manually modifying
the plugin.xml files).
Anyway, if you want to go down this path you should check if rap
supports the org.eclipse.ui.activities extension point.
Just my 2 cents.
Elias
Mark wrote:
> Ok, I found the right keyword to search on. I found something here to
> help with "logon".
> I also found this -
> http://www.ibm.com/developerworks/library/os-ecl-rcpsec/inde x.html
Re: Security [message #57365 is a reply to message #57314] |
Mon, 05 November 2007 01:44 |
Elias,
Thanks for input. Do you have suggestions on how to implement
"Authorization" in RAP then? I have parts of the app that should
probably on be available based on roles.
As for modifying the plugin.xml, since it is on the server I doubt a
use could modify it. They could with a standard RCP app.
Elias Volanakis wrote:
> Hi Mark,
> Just my 2 cents.
> Regards,
> Elias
>> help with "logon".
>> I also found this -
Re: Security [message #57685 is a reply to message #57568] |
Mon, 05 November 2007 13:43 |
Originally posted by: fappel.innoopract.com
just to get it right - are we talking about something like a user
authenticates himself to an application using username/password and after
that he has access to certain functionalities that meets the grants of the
roles assigned to him? So different users would have access to different
aspects of the application (e.g. some perspectives would only be available
to users with the correct grants).
If so, the equinox security unfortunately doesn't solve the problem with
RAP. To put it simple the security mechanisms works on application scope,
which is not sufficient for RAP applications which have to deal with
different user authentications per session. Activities are currently not
supported within RAP and even if so, this would probably face the same
problem and as Elias already pointed out this is not what activities were
created for.
An overall concept that helps with the problems mentioned above doesn't
exist neighter in RCP nor in RAP. So at the time beeing this is something
application developers have to deal with on their own. Without having a
deeper look at it, I could imagine that RAP applications that are developed
to be deployed on standard JEE servers still could use JAAS like other
webapplications do.
Ciao
Frank
"Benjamin Muskalla" <bmuskalla@innoopract.com> schrieb im Newsbeitrag
news:fgmori$8sj$1@build.eclipse.org...
> Speaking about Security and JAAS, I think it's worth to take a look at the
> efforts of Equinox about security. See
> http://www.eclipse.org/equinox/incubator/security/
> Greets
> Benny
>> Have a look at eclipse Jaas. It's a project for implementing
>> authentication + authorisation based on jaas for eclipse.
>> I'm not sure if it could be used with rap, but it is easy to integrate
>> with rcp.
>> Markus
Re: Security [message #57833 is a reply to message #57365] |
Tue, 06 November 2007 02:50 |
Hi Mark,
a while ago I read an interesting print article about implementing a
custom authentication and authorization mechanism in an RCP App.
Unfortunately it is in German and not available on the net...
Berechtigungen in Rich Clients implementieren
Autorisierung in RCP-Anwendungen
Michael Buchholz
Eclipse Magazin, Vol 12 / III/2007
If I remember correctly (it has been a while) the spirit of the above
article was to have a central authorization manager (singleton; similar
to a security manager) and then to be "disciplined" to include calls to
that manager at the points where it matters; example
View.createControl() could return an empty UI when not authorized /
actions would check this in run() method etc. In the article they had
abstract classes that did that so that developers just had to subclass
those. Drawback of this approach is that it does not work very well when
you want to integrate 3rd-party views / actions / etc which you only
have in binary form.
Elias.
Mark wrote:
> Elias,
>> Hi Mark,
>> for "security" but is very easy to bypass (for example by manually
>> modifying the plugin.xml files).
>> Just my 2 cents.
>> Regards,
>> Elias
>>> to help with "logon".
>>> I also found this -
Re: Security [message #57981 is a reply to message #57833] |
Tue, 06 November 2007 15:55 |
Hi Elias,
Thanks for you input. And thanks to everyone else!
> Hi Mark,
> Michael Buchholz
> Regards,
> Elias.
> Mark wrote:
>> Elias,
>>> Hi Mark,
>>> as the user becomes more proficient with an application. It can be
>>> used for "security" but is very easy to bypass (for example by
>>> manually modifying the plugin.xml files).
>>> Just my 2 cents.
>>> Regards,
>>> Elias
>>>> I also found this -
Re: Security [message #64492 is a reply to message #57208] |
Tue, 04 December 2007 18:24 |
Originally posted by: just4lists.nospammail.net
We are using the OSGi User Admin service (org.eclipse.equinox.useradmin).
Joel Oliveira
"Mark" <m@n.com> escreveu na mensagem news:fgkoob$rtc$1@build.eclipse.org...
FUDForum. Page generated in 0.04628 seconds
