Home » Archived » Visual Editor (VE) » graphical database tool
graphical database tool [message #7356] Mon, 01 December 2003 19:19 Go to next message
Originally posted by: wade.eccentrichosting.net
I am wondering if there is an existing project that has been started to
bring a graphical sql generator to eclipse. One of the reasons that I
use to use VisualAge, WebObjects, and now Jbuilder Enterprise is for the
database tools that each IDE supplied. WebObjects EOModler and
Jbuilders DatabasePilot allows for extreamly rapid development of
database driven applications. All of these are based on JDBC and allow
for changing of the database source.
Is this something on the horizon for Eclipse?
Is it already a plugin in development?
Is it worthwile for my team to start development of such and application?
Would it have to be none jdbc based to be part of eclipse?
For $3,400 a license for jbuilder we would be more than happy to try and
bring this functionality to eclipse.
Sorry if I posted this in the wrong area. Please direct me to the
correct newsgroup if this post is located in the wrong section.
Wade Arnold
Re: graphical database tool [message #7483 is a reply to message #7356] Tue, 02 December 2003 04:44 Go to previous messageGo to next message
Originally posted by: scheglov_ke.nlmk.ru
Wade Arnold <wade@eccentrichosting.net> wrote:
I also miss database support in Eclipse/SWT.
However main question is not "Do we need it", but "What precise we need", i.e.
how this support should be implemented:
1. as in Borland's Delphi/CBuilder - thick wrapper around ResultSet with
classes TDataSet, TField, etc;
2. O/R mapping;
3. something else?
> Wade Arnold
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: graphical database tool [message #7495 is a reply to message #7356] Tue, 02 December 2003 09:00 Go to previous messageGo to next message
Originally posted by: dar.cs.huji.ac.il
Have you looked at DBEdit and JFaceDbc ?
David
> Wade Arnold
Re: graphical database tool [message #7970 is a reply to message #7495] Tue, 02 December 2003 21:18 Go to previous messageGo to next message
Originally posted by: jmordax.terra.es
You also can take a look at DB Visualizer. But it is not an Eclipse
plugin (which could be great).
Chemi.
P.S.: But this discussion is not related to VE so I think it should move
to Platform or more generic forums.
Re: graphical database tool [message #8569 is a reply to message #7970] Fri, 05 December 2003 20:57 Go to previous messageGo to next message
I found a plugin: http://jfacedbc.sourceforge.net/index.php
Re: graphical database tool [message #17092 is a reply to message #7356] Mon, 26 January 2004 18:33 Go to previous message
Originally posted by: placeMyNameHere.enterprise.hb.se
Don't know if you ever found something you were satisfied with, but check
out Clay:
http://www.azzurri.jp/en/software/clay
- arch
Re: graphical database tool [message #571470 is a reply to message #7356] Tue, 02 December 2003 04:44 Go to previous message
Konstantin Scheglov is currently offline Konstantin ScheglovFriend
2. O/R mapping;
3. something else?
> Wade Arnold
SY, Konstantin.
Konstantin Scheglov,
Google, Inc.
Re: graphical database tool [message #571505 is a reply to message #7356] Tue, 02 December 2003 09:00 Go to previous message
David Rabinowitz is currently offline David RabinowitzFriend
David
> Wade Arnold
Re: graphical database tool [message #571677 is a reply to message #7495] Tue, 02 December 2003 21:18 Go to previous message
Chemi is currently offline ChemiFriend
Chemi.
Re: graphical database tool [message #572498 is a reply to message #7970] Fri, 05 December 2003 20:57 Go to previous message
Re: graphical database tool [message #579641 is a reply to message #7356] Mon, 26 January 2004 18:33 Go to previous message
out Clay:
- arch
Previous Topic:Datagrid in VE
Next Topic:Partially solved the problem to show variables in the properties sheet.
Current Time: Mon Nov 11 10:32:29 GMT 2024
Powered by FUDForum. Page generated in 0.03598 seconds
