Re: Graph generators [message #563578 is a reply to message #563381] |
Wed, 28 April 2010 20:44 |
Stefan Edlund Messages: 127 Registered: July 2009 Location: IBM |
To try and answer Matthias questions:
- It would be a nice feature if one could visualize the lattice graph in the map view without running a scenario.
Yes, this is a limitation. The way the map works right now is that will only display the polygons that has labels matching the ones specified in the drop downs. So if you select a disease model and then a population, it will only display regions having disease model labels matching the population.
- in my specific case (generating a graph using the standard values of the wizard: 10 by 10 grid) the map view displayed only a straight line, maybe you can give me a hint what to consider.
Hmmm, I have not seen that behavior before. You might want to double check that your graph was created correctly. In the Project Explorer, open your model, then open the graph and then Nodes. You should have a list like "LAT_SQR_0_0, LAT_SQR_0_1 etc.". If you still can't get it to work can you zip up your STEM project and send to me so I can take a look?
- when one has performed changes on e.g. a model and then right click on the model, there is no option that says "save"
That looks like a limitation in the Eclipse RCP. Save is available using Ctrl+S or under the File menu
- the right-click option "rename" is not working properly, at least I wasn't able to save the changes.
Rename is a new feature and it is possible that there are still bugs. I assume you used the popup menu function with the option that has an image like "A->B" next to it? What is the problem you're experiencing? Can you open a defect? It is possible we still have defects in this part of the code.
/ Stefan
Matthias
FUDForum. Page generated in 0.04344 seconds
