Home » Archived » AM3 » UML22Measure build failure
UML22Measure build failure [message #563299] Sat, 15 November 2008 17:02
Jerome is currently offline JeromeFriend
Hi all,
I'm using the old AM3 distribution (0.2.0.200706221611) on Eclipse 3.4.1
(modeling tools included), EMF2.4.0 and ATL 2.0.1.
When running the build.xml ant script of the project "UML22Measure" taken
from the zoo, I receive the following error message:
BUILD FAILED
............\build.xml:28: Problem: failed to create task or type
am3.loadModel
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken
place.
In the build config the option "Run in the same JRE as the workspace" is
checked.
The AM3 plugin seems to be properly installed as I can open the AM3
perspective. Problem seems similar to Mark Melia's one.
Thank you for your help.
Previous Topic:Re: how to use KM3 generate a graphical editor for DSL?
Next Topic:AM3 ATL extractor/injector
Current Time: Wed Feb 05 08:40:38 GMT 2025
Powered by FUDForum. Page generated in 0.02660 seconds
