Home » Modeling » M2T (model-to-text transformation) » Problems integrating
Problems integrating [message #558845] Tue, 14 September 2010 15:04 Go to next message
Philipp Zech is currently offline Philipp ZechFriend
Member
I'm currently moving a M2T generator, encapsulated inside an eclipse
plugin, from oAW4 to oAW5. So far, the renaming and everything else
worked fine, also the generator works fine, but only in a stand-alone
project in the workspace (by right-clicking on the mwe file and
selecting "Run as MWE workflow"). However, as soon as I export the
plugin and try to invoke the workflow from a delegated action (via
WorkflowRunner), nothing happens, in other words, I get custom debug
messages telling me that the generator starts generating, I get NO error
messages but also NO output. The funny thing is, using oAW4 everything
worked fine, but since I changed to oAW5, I get no output (and I only
changed the qualified names of the workflow components and inside the
..xpt files). So far, I don't have any more ideas why this happens, so I
try to get help from the news group, in hopes of somebody else already
faced a similar problem and maybe can provide me with a solution.
Thanks in advance!
Philipp
Re: Problems integrating generator into eclipse plugin [message #558846 is a reply to message #558845] Tue, 14 September 2010 15:11 Go to previous messageGo to next message
Member
On 09/14/2010 05:04 PM, Philipp Zech wrote:
> Thanks in advance!
> Cheers,
> Philipp
sorry, forgot to finish the subject entry...
Re: Problems integrating generator into eclipse plugin [message #558871 is a reply to message #558846] Tue, 14 September 2010 16:53 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
i cannot reproduce this using a trivial example. did you check the right place for the files to be generated?
~Christian
Twitter : @chrdietrich
Day Job: https://www.everest-systems.com
Re: Problems integrating generator into eclipse plugin [message #558877 is a reply to message #558871] Tue, 14 September 2010 17:16 Go to previous messageGo to next message
Member
On 09/14/2010 06:53 PM, Christian Dietrich wrote:
> ~Christian
Hi Christian,
yep, the place is correct, it is an eclipse project, where the uml file
is taken from a specific existing directory and also the outlet is
existent within the project where the UML file is taken from.
Philipp
Re: Problems integrating generator into eclipse plugin [message #558881 is a reply to message #558877] Tue, 14 September 2010 17:46 Go to previous messageGo to next message
here is what i do
public class EditorAction1Delegate implements IEditorActionDelegate {
	public void run(IAction action) {
		WorkflowRunner workflowRunner = new WorkflowRunner();
		workflowRunner.run("src/dummy/test.mwe", new NullProgressMonitor(), new HashMap<String, String>(), new HashMap());
	public void selectionChanged(IAction action, ISelection selection) {
		// TODO Auto-generated method stub
	public void setActiveEditor(IAction action, IEditorPart targetEditor) {
<workflow>
	<component class="org.eclipse.xpand2.Generator">
		<expand value="dummy::test::main FOR 'ccc'" />
		<outlet path="src-gen" />
	</component>
</workflow>
«DEFINE main FOR String»
«FILE "test.txt"»
«ENDFILE»
«ENDDEFINE»
the test.txt file is generated in a src-gen folder next to the eclipse exe as i expect it.
Does it work for you if you change your sample to something similar trivial? e.g. by adding this to your entry definition
«FILE "test.txt"»
«ENDFILE»
debugging FileHandleImpl may give you hints where the files are written to.
~Christian
[Updated on: Tue, 14 September 2010 18:09]
Report message to a moderator
Re: Problems integrating generator into eclipse plugin [message #558884 is a reply to message #558881] Tue, 14 September 2010 18:16 Go to previous messageGo to next message
Member
> «FILE "test.txt"»
> «ENDFILE»
> «ENDDEFINE»
Hi Christian,
first of all, thanks for your fast reply and help. However, I even can't
get your simple example running to generate some files. It compiles, I
get no errors, and unfortunately I also get no output. I've searched my
whole disk, but no "test.txt" file was found.
Btw, are there any known problems, if using Linux?
Philipp
Re: Problems integrating generator into eclipse plugin [message #558885 is a reply to message #558884] Tue, 14 September 2010 18:20 Go to previous messageGo to next message
hi
don't know of any linux problems - did you try to hardcode an absolte path to the outlet?
~Christian
Re: Problems integrating generator into eclipse plugin [message #558888 is a reply to message #558885] Tue, 14 September 2010 18:32 Go to previous messageGo to next message
Member
On 09/14/2010 08:20 PM, Christian Dietrich wrote:
> hi
> path to the outlet?
> ~Christian
even a hardcoded path does not work.
Philipp
Re: Problems integrating generator into eclipse plugin [message #558889 is a reply to message #558888] Tue, 14 September 2010 18:34 Go to previous messageGo to next message
Member
>> hi
>> path to the outlet?
>> ~Christian
> Philipp
Hi again,
however, if I'm invoking the workflow inside the project via "Run as..."
it works without any problems and the file is generated.
Philipp
Re: Problems integrating generator into eclipse plugin [message #558890 is a reply to message #558889] Tue, 14 September 2010 18:47 Go to previous messageGo to next message
strange
can you post the logging output you get?
can you post your workflow and the action code?
~Christian
[Updated on: Tue, 14 September 2010 18:49]
Re: Problems integrating generator into eclipse plugin [message #558895 is a reply to message #558890] Tue, 14 September 2010 19:03 Go to previous messageGo to next message
Member
On 09/14/2010 08:47 PM, Christian Dietrich wrote:
> strage
> ~Christian
I assume you're asking for the action code of my plugin, so here it goes:
package info.teststories.generator.plugin;
import info.teststories.generator.xpand.Teststory;
import java.io.File;
import java.io.IOException;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.resources.IResource;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.core.runtime.jobs.Job;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.StructuredSelection;
import org.eclipse.ui.IObjectActionDelegate;
import org.eclipse.ui.IWorkbenchPart;
import org.eclipse.ui.actions.ActionDelegate;
import org.eclipse.emf.mwe.core.WorkflowRunner;
import org.eclipse.emf.mwe.core.monitor.NullProgressMonitor;
* @author Philipp Zech (Philipp.Zech@uibk.ac.at)
* Delegated action to invoke the generator.
public class GenerateStoryAction extends ActionDelegate implements
IObjectActionDelegate {
private String UMLModel = "";
private String projectLocation = "";
private final String workflowFile =
"info/teststories/generator/workflow/workflow.mwe";
private IProject project = null;
public void setActivePart(IAction action, IWorkbenchPart targetPart) {
Job job = new Job("Generating Teststories") {
protected IStatus run(IProgressMonitor monitor) {
monitor
.beginTask("Generating test code and test artifacts...",
100);
Map<String, String> properties = new HashMap<String, String>();
Map<String, ?> slotMap = new HashMap<String, Object>();
// configure properties passed to the work-flow engine
properties.put("UMLModel", UMLModel);
properties.put("projectLocation", projectLocation);
monitor.worked(20);
// clear the adapters file
File adapters = new File(projectLocation + File.separator
+ ".adapters.list");
if (adapters.exists()) {
adapters.delete();
try {
adapters.createNewFile();
} catch (IOException e) {
e.printStackTrace();
monitor.worked(40);
WorkflowRunner runner = new WorkflowRunner();
runner.run(workflowFile, new NullProgressMonitor(), properties,
slotMap);
monitor.worked(95);
try {
project.refreshLocal(IProject.DEPTH_INFINITE,
monitor);
} catch (CoreException e) {
monitor.worked(100);
monitor.done();
return Status.OK_STATUS;
job.schedule();
StructuredSelection structuredSelection = (StructuredSelection) selection;
IResource resource = (IResource) structuredSelection.getFirstElement();
if (resource != null) {
UMLModel = resource.getName();
projectLocation = resource.getProject().getLocation().toOSString();
Teststory.setProjectLocation(projectLocation);
project = resource.getProject();
Concerning thelogging, the only output I get is the name of the UML file
selected (removed from the posted code above), I don't get any other log
messages, whether if I'm using log4j nor in the eclipse log itself,
which also seems a little strange to me.
Philipp
Re: Problems integrating generator into eclipse plugin [message #558898 is a reply to message #558895] Tue, 14 September 2010 19:31 Go to previous messageGo to next message
hi,
testing with a runtime app i get following in the logs of the host eclipse
14.09.2010 21:31:33 org.eclipse.emf.mwe.core.WorkflowRunner prepare
INFO: --------------------------------------------------------------------------------------
INFO: EMF Modeling Workflow Engine 1.0.0, Build v201008251122
INFO: (c) 2005-2009 openarchitectureware.org and contributors
INFO: running workflow: src/dummy/test.mwe
INFO:
14.09.2010 21:31:33 org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflowComponent checkConfigurationInternal
INFO: No meta models configured, using JavaBeans as default.
14.09.2010 21:31:33 org.eclipse.emf.mwe.core.container.CompositeComponent internalInvoke
INFO: Generator: generating 'dummy::test::main FOR 'ccc'' => D:/runtime-New_configuration/x/src
14.09.2010 21:31:33 org.eclipse.xpand2.Generator invokeInternal2
INFO: Written 1 files to outlet [default](D:/runtime-New_configuration/x/src)
14.09.2010 21:31:33 org.eclipse.emf.mwe.core.WorkflowRunner executeWorkflow
INFO: workflow completed in 16ms!
~Christian
Re: Problems integrating generator into eclipse plugin [message #558902 is a reply to message #558898] Tue, 14 September 2010 19:47 Go to previous messageGo to next message
Member
On 09/14/2010 09:31 PM, Christian Dietrich wrote:
> hi,
> INFO:
> INFO:
> INFO: 14.09.2010 21:31:33
> org.eclipse.xtend.expression.AbstractExpressionsUsingWorkflo wComponent
> 14.09.2010 21:31:33
> ~Christian
ok, now it becomes really strange. What I did was creating a new XPand
project with the wizard, adding your example and starting an instance of
eclipse. However, I don't get any log in the host eclipse. Do I have to
set up anything for that i get the log? I think I've got my wires
crossed...don't have any clue what to do.
Again, thanks for your help,
Philipp
Re: Problems integrating generator into eclipse plugin [message #558905 is a reply to message #558902] Tue, 14 September 2010 19:57 Go to previous messageGo to next message
hi,
no the logging should work out of the box.
here is my manifest
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Dummy
Bundle-SymbolicName: dummy;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-Activator: dummy.Activator
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.emf.mwe.core;bundle-version="1.0.0",
org.apache.commons.logging;bundle-version="1.0.4",
org.eclipse.xpand;bundle-version="1.0.1",
org.eclipse.xtend;bundle-version="1.0.1",
org.antlr.runtime;bundle-version="3.0.0",
org.eclipse.core.resources;bundle-version="3.6.0"
Bundle-ActivationPolicy: lazy
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
the runtime i start with host + workspace bundles.
btw: did you try to use the java debugger to get an idea what happens?
~Christian
Re: Problems integrating generator into eclipse plugin [message #558917 is a reply to message #558905] Tue, 14 September 2010 20:39 Go to previous messageGo to next message
Member
On 09/14/2010 09:57 PM, Christian Dietrich wrote:
> hi,
> here is my manifest
> Quote:
>> Bundle-Name: Dummy
> ~Christian
hi,
ok, first of all, I don't have Xtend and XPand in versions 1.0.1, only
1.0.0. If I try to update it, the update manager tells me there are no
updates available.
Second, I start the instance the same way like you.
And finally, I don't know if I'm debugging the wrong way, but the editor
in the debug view tells me all the time that it can't find the source of
the classes (WorkflowRunner and the like, which doesn't allow me to
change source attachments). Maybe my eclipse has some major problems.
I'm definitely confused.
philipp
Re: Problems integrating generator into eclipse plugin [message #558918 is a reply to message #558917] Tue, 14 September 2010 20:48 Go to previous messageGo to next message
i use the distro available from here: http://xtext.itemis.com/xtext-language-development-framework /language=en/23947/downloads
~Christian
Re: Problems integrating generator into eclipse plugin [message #558922 is a reply to message #558918] Tue, 14 September 2010 20:50 Go to previous messageGo to next message
Member
On 09/14/2010 10:48 PM, Christian Dietrich wrote:
> ~Christian
ok,
i'll try it with that one. thanks for the hint.
philipp
Re: Problems integrating generator into eclipse plugin [message #558930 is a reply to message #558922] Tue, 14 September 2010 22:25 Go to previous messageGo to next message
Member
>> Hi,
>> ~Christian
> ok,
> philipp
Hi Christian,
with the items distribution of eclipse, your simple example now works!
Also debugging now is possible, I haven't tested my project now, I'll do
it tomorrow, and I'll let you know whether it works or not. If it
doesn't I'll write a new post anyway.
Thanks so far for your help!
Philipp
Re: Problems integrating generator into eclipse plugin [message #558932 is a reply to message #558930] Tue, 14 September 2010 22:45 Go to previous messageGo to next message
Member
>>> Hi,
>>> ~Christian
>> ok,
>> philipp
> Hi Christian,
> Philipp
Hi again,
the logging still doesn't work.
Philipp
Re: Problems integrating generator into eclipse plugin [message #558950 is a reply to message #558932] Wed, 15 September 2010 06:36 Go to previous messageGo to next message
for the logging: i start my runtime app with -console -consoleLog
~Christian
Re: Problems integrating generator into eclipse plugin [message #558977 is a reply to message #558950] Wed, 15 September 2010 08:35 Go to previous messageGo to next message
Member
On 09/15/2010 08:36 AM, Christian Dietrich wrote:
> ~Christian
well i didn't use the "console" option so far, but I used the
"consoleLog". However, adding "console" to the program arguments does
not change anything.
Philipp
Re: Problems integrating generator into eclipse plugin [message #558978 is a reply to message #558977] Wed, 15 September 2010 08:38 Go to previous messageGo to next message
so the only possibility for further investigations is debugging.
~Christian
Re: Problems integrating generator into eclipse plugin [message #559037 is a reply to message #558978] Wed, 15 September 2010 11:50 Go to previous messageGo to next message
Member
On 09/15/2010 10:38 AM, Christian Dietrich wrote:
> ~Christian
Hi Christian,
now everything works fine, my code is generated without any errors.
After using the itemis distro I debugged my workflow and realized that
the line
<bean class="org.eclipse.xtend.typesystem.uml2.Setup"
standardUML2Setup="true"/>
caused the workflow to be interrrupted, as "Setup" could no be
instantiated, yet the plugin "org.eclipse.uml2.uml.resources" was on the
classpath.
By mentioning that, may I ask you, what exactly this line in the
workflow causes? So far I haven't found a clear explanation about what's
the effect of this instruction.
Again, thanks for your help and patience!
cheers,
Philipp
Re: Problems integrating generator into eclipse plugin [message #559060 is a reply to message #559037] Wed, 15 September 2010 13:25 Go to previous messageGo to next message
Member
>> Hi,
>> ~Christian
> Hi Christian,
> the line
> classpath.
> cheers,
> Philipp
Hi again,
now again sth strange happens. In an instance my generator works
smoothly, however as soon as I export the plugin, again nothing is
generated. How can this happen?
Philipp
Re: Problems integrating generator into eclipse plugin [message #559063 is a reply to message #559060] Wed, 15 September 2010 13:36 Go to previous messageGo to next message
make sure eveything is packaged with the plugin and the WorkflowRunner can find the file. maybe you have to set the plugin to be unpacked.
~Christian
[Updated on: Wed, 15 September 2010 13:42]
Re: Problems integrating generator into eclipse plugin [message #559085 is a reply to message #559063] Wed, 15 September 2010 14:31 Go to previous messageGo to next message
Member
On 09/15/2010 03:36 PM, Christian Dietrich wrote:
> can find the file.
> ~Christian
is it maybe because I'm not using the following line:
<!--bean class="org.eclipse.xtend.typesystem.uml2.Setup"
standardUML2Setup="true"/--> (or StandAloneSetup)?
Philipp
Re: Problems integrating generator into eclipse plugin [message #559088 is a reply to message #559085] Wed, 15 September 2010 15:01 Go to previous messageGo to next message
you have to use this to get uml model read correctly.
~Christian
Re: Problems integrating generator into eclipse plugin [message #559097 is a reply to message #559088] Wed, 15 September 2010 15:21 Go to previous messageGo to next message
Member
On 09/15/2010 05:01 PM, Christian Dietrich wrote:
> ~Christian
hm, with this line my generator always fails, however adding
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup"
platformUri="${projectLocation}/.."/>
works smoothly. I'm using MagicDraw exported diagrams.
Philipp
Re: Problems integrating generator into eclipse plugin [message #559098 is a reply to message #559097] Wed, 15 September 2010 15:23 Go to previous messageGo to next message
Member
>> Hi,
>> ~Christian
> Philipp
sorry, meant models...
Re: Problems integrating generator into eclipse plugin [message #559128 is a reply to message #559098] Wed, 15 September 2010 16:56 Go to previous messageGo to next message
so it fails when invoking via runs as mwe workflow too?
~Christian
Re: Problems integrating generator into eclipse plugin [message #559131 is a reply to message #559128] Wed, 15 September 2010 17:03 Go to previous messageGo to next message
Member
On 09/15/2010 06:56 PM, Christian Dietrich wrote:
> ~Christian
hi,
yep, it does.
Philipp
Re: Problems integrating generator into eclipse plugin [message #559139 is a reply to message #559131] Wed, 15 September 2010 17:59 Go to previous messageGo to next message
And what is the error message you get?
Re: Problems integrating generator into eclipse plugin [message #559143 is a reply to message #559139] Wed, 15 September 2010 18:14 Go to previous messageGo to next message
Member
[ERROR]: Error creating instance of type
'org.eclipse.xtend.typesystem.uml2.Setup' :
java.lang.IllegalStateException: Missing required plugin
'org.eclipse.uml2.uml.resources' in classpath.(Element: bean bean
class='org.eclipse.xtend.typesystem.uml2.Setup' in
info/teststories/generator/workflow/workflow.mwe:6; Reported by: -UNKNOWN-)
however, the plugin is on the classpath
Re: Problems integrating generator into eclipse plugin [message #559149 is a reply to message #559143] Wed, 15 September 2010 18:59 Go to previous messageGo to next message
i get this on windows too
i solved it by creating following fragment
Bundle-Name: Fragment
Bundle-SymbolicName: org.eclipse.uml2.uml.resources.fragment
Fragment-Host: org.eclipse.uml2.uml.resources;bundle-version="3.1.0"
Export-Package: metamodels
~Christian
Re: Problems integrating generator into eclipse plugin [message #559152 is a reply to message #559149] Wed, 15 September 2010 19:19 Go to previous messageGo to next message
Member
thanks, this also worked for me. However, it still only works in an
instance. As soon as I try to use the exported plugin (with the fragment
exported too) I still get no output nor any error messages. Everything
is packed properly, the workflow seems to be at the correct location,
but nothing happens.
Philipp
Re: Problems integrating generator into eclipse plugin [message #559155 is a reply to message #559152] Wed, 15 September 2010 19:24 Go to previous messageGo to next message
hi,
i ususally add a feature - add there the plugins - and set for the workflow plugin unpack = true
<feature
      id="test.feature"
      label="Feature"
      version="1.0.0.qualifier">
   <description url="http://www.example.com/description">
      [Enter Feature Description here.]
   </description>
   <copyright url="http://www.example.com/copyright">
      [Enter Copyright Description here.]
   </copyright>
   <license url="http://www.example.com/license">
      [Enter License Description here.]
   </license>
   <requires>
      <import plugin="org.eclipse.ui"/>
      <import plugin="org.eclipse.core.runtime"/>
      <import plugin="org.eclipse.emf.mwe.core" version="1.0.0" match="greaterOrEqual"/>
      <import plugin="org.eclipse.xpand" version="1.0.1" match="greaterOrEqual"/>
      <import plugin="org.eclipse.xtend" version="1.0.1" match="greaterOrEqual"/>
      <import plugin="org.antlr.runtime" version="3.0.0" match="greaterOrEqual"/>
      <import plugin="org.eclipse.core.resources" version="3.6.0" match="greaterOrEqual"/>
      <import plugin="org.eclipse.xtend.typesystem.uml2" version="1.0.1" match="greaterOrEqual"/>
      <import plugin="org.eclipse.xtend.typesystem.emf" version="1.0.1" match="greaterOrEqual"/>
      <import plugin="org.eclipse.emf.mwe.utils" version="1.0.0" match="greaterOrEqual"/>
      <import plugin="org.apache.commons.logging" version="1.1.1" match="greaterOrEqual"/>
      <import plugin="org.eclipse.emf.mwe.activities" version="1.0.0" match="greaterOrEqual"/>
      <import plugin="org.eclipse.uml2.uml.resources" version="3.1.0" match="greaterOrEqual"/>
   </requires>
   <plugin
         id="dummy"
         download-size="0"
         install-size="0"
         version="0.0.0"/>
   <plugin
         id="org.eclipse.uml2.uml.resources.fragment"
         download-size="0"
         install-size="0"
         version="0.0.0"
         fragment="true"
         unpack="false"/>
</feature>
~Christian
Re: Problems integrating generator into eclipse plugin [message #559162 is a reply to message #559155] Wed, 15 September 2010 19:40 Go to previous messageGo to next message
hi,
I uploaded my exported stuff here: http://drop.io/k50vvfh
note: you may have to refresh yourself - this is missing in my action
~Christian
Re: Problems integrating generator into eclipse plugin [message #559165 is a reply to message #559155] Wed, 15 September 2010 19:48 Go to previous messageGo to next message
Member
On 09/15/2010 09:24 PM, Christian Dietrich wrote:
> hi,
> <feature
> id="test.feature"
> label="Feature"
> </description>
> </copyright>
> </license>
> <requires>
> </requires>
> <plugin
> id="dummy"
> download-size="0"
> install-size="0"
> version="0.0.0"/>
> <plugin
> download-size="0"
> install-size="0"
> version="0.0.0"
> fragment="true"
> unpack="false"/>
> </feature>
> ~Christian
well, if this is the only way, ok. But it's quite strange as with oAW4
and Eclipse Galileo it all worked seamlessly with just exporting the
plugin and restarting eclipse. But I'll try it to way you suggest it.
Philipp
Re: Problems integrating generator into eclipse plugin [message #559166 is a reply to message #559162] Wed, 15 September 2010 19:49 Go to previous messageGo to next message
Member
On 09/15/2010 09:40 PM, Christian Dietrich wrote:
> hi,
> ~Christian
thanks for uploading!
Re: Problems integrating generator into eclipse plugin [message #559174 is a reply to message #559166] Wed, 15 September 2010 20:11 Go to previous messageGo to next message
Member
>> hi,
>> ~Christian
hm, I'm getting kinde really depressed, also with the feature
workaround, i don't get any generated files.
Philipp
Re: Problems integrating generator into eclipse plugin [message #559176 is a reply to message #559174] Wed, 15 September 2010 20:25 Go to previous messageGo to next message
- did you try my stufff that generates from uml::Classes?
(uml model created with eclipse)
- can you provide your stuff too?
- did you drop the stuff in the dropins folder?
~Christian
Re: Problems integrating generator into eclipse plugin [message #559177 is a reply to message #559176] Wed, 15 September 2010 20:29 Go to previous messageGo to next message
Member
> ~Christian
hi,
i'm just trying it with your stuff. i'll be back soon.
philipp
Re: Problems integrating generator into eclipse plugin [message #559402 is a reply to message #559177] Thu, 16 September 2010 14:10 Go to previous messageGo to next message
Member
>> ~Christian
> hi,
> philipp
Hi christian,
sorry for getting back so late, but I had some problems with my internet
and some stuff to do. I first must admit, that up to now I didn't test
your stuff, but I further investigated my project and I found out that
it leads to a quite curious error:
[ERROR](Element: EXPAND
info::teststories::generator::xpand::Teststory::Teststory FOR model;
Reported by: Generator(StoryGenerator): generating
'info::teststories::generator::xpand::Teststory::Teststory FOR model' =>
/home/c703443/workspace/senseTests/src/info/teststories/sut/ stories)
for the easy of checking I've uploaded my generator plugin and an
according model, which should produce a nearly empty java source file
(just some skeleton code, which will lead to errors on your machine, as
you're missing some libraries and other plugins) to drop.io:
http://drop.io/svbpspf
Maybe you can give me the final hint, why my exported plugin leads to
this error and the generator running inside an instance not. In the
meantime I'll try out your stuff.
Philipp
Re: Problems integrating generator into eclipse plugin [message #559408 is a reply to message #559402] Thu, 16 September 2010 14:36 Go to previous messageGo to next message
Member
>>> ~Christian
>> hi,
>> philipp
> Hi christian,
> Philipp
sorry, forgot the fragment:
http://drop.io/zqg2bs3
cheers,
philipp
Re: Problems integrating generator into eclipse plugin [message #559423 is a reply to message #559408] Thu, 16 September 2010 15:08 Go to previous messageGo to next message
can you provide something i can run out of the box?
~Christian
Re: Problems integrating generator into eclipse plugin [message #559430 is a reply to message #559423] Thu, 16 September 2010 15:20 Go to previous messageGo to next message
i did some debugging with the model you provided.
the problems is that all of the package stereotype checks fail => nothing is generated, not even in a runtime.
~Christian
Re: Problems integrating generator into eclipse plugin [message #559433 is a reply to message #559430] Thu, 16 September 2010 15:20 Go to previous messageGo to next message
Sorry forget my last message.
Re: Problems integrating generator into eclipse plugin [message #559434 is a reply to message #559433] Thu, 16 September 2010 15:23 Go to previous messageGo to next message
btw what is the output you expect?
~Christian
Re: Problems integrating generator into eclipse plugin [message #559439 is a reply to message #559434] Thu, 16 September 2010 15:33 Go to previous messageGo to next message
i digged a bit more and stumbled over this:
«DEFINE Teststories FOR uml::Package»
	«FOREACH (List[uml::Package])ownedElement AS teststory»
		«IF teststory.getAppliedStereotype("TTSProfile::Teststory") != null»
			«EXPAND Teststory FOR teststory»
		«ENDIF»
	«ENDFOREACH»
«ENDDEFINE»
but the Teststories package contains only an activity with stereotype Teststory but the template
«DEFINE Teststory FOR uml::Activity»
«ENDDEFINE»
is missing
~Christian
Re: Problems integrating generator into eclipse plugin [message #559617 is a reply to message #559439] Fri, 17 September 2010 11:51 Go to previous messageGo to next message
Member
On 09/16/2010 05:33 PM, Christian Dietrich wrote:
> Hi
> «ENDIF»
> «ENDFOREACH»
> «ENDDEFINE»
> «ENDDEFINE»
> is missing
> ~Christian
hi,
sorry, that's an error in the model. here's a fixed model:
http://drop.io/gm9lvhv BTW, I had the remove the rest of the code from
drop.io, as I was told to.
Philipp
Re: Problems integrating generator into eclipse plugin [message #559701 is a reply to message #559617] Fri, 17 September 2010 16:01 Go to previous messageGo to next message
i deleted you stuff too so a further investigation on your plugins make no sense
See you other topic for further hints
~Christian
Re: Problems integrating generator into eclipse plugin [message #649968 is a reply to message #559701] Fri, 21 January 2011 09:10 Go to previous messageGo to next message
Tom Brandenburg is currently offline Tom BrandenburgFriend
Member
I am getting the same error ([ERROR]: Error creating instance of type 'org.eclipse.xtend.typesystem.uml2.Setup' : java.lang.IllegalStateException: Missing required plugin 'org.eclipse.uml2.uml.resources' in classpath.(Element: bean bean class='org.eclipse.xtend.typesystem.uml2.Setup' in C:\test\main.mwe:12; Reported by: -UNKNOWN-))
Currently I run my plugin as an eclipse app and want to execute a workflow out of it. org.eclipse.uml2.uml.resources is definetely added to plugin's dependencies.
Test workflow file:
<?xml version="1.0"?>
<workflow>
    <!-- Set Mappings -->
    <bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" platformUri="..">
    </bean>
    <!-- Set Properties -->
    <property name="fileEncoding" value="ISO-8859-1"/>
    <!-- Set UML environment -->
    <bean class="org.eclipse.xtend.typesystem.uml2.Setup" standardUML2Setup="true" />
    <bean id="UMLMetaModel"
        class="org.eclipse.xtend.typesystem.uml2.UML2MetaModel">
    </bean>
</workflow>
I am only able to read the error message when I do Java debugging in WorkflowRunner.prepare(*) - the error message is added to the issues variable, which unfortunately is only a local variable of prepare(*)...The logger does not produce any output to any console/log file.
Has the problem above ever been solved? I am also quite helpless right now Confused
Thanks in advance and best regards
Tom
[Updated on: Fri, 21 January 2011 09:17]
Re: Problems integrating generator into eclipse plugin [message #650004 is a reply to message #649968] Fri, 21 January 2011 12:19 Go to previous message
Member
Ok, I already read the trick with the fragment for org.eclipse.uml2.uml.resources:
Bundle-Name: UML2 Resource Fragment
Bundle-SymbolicName: dev.test.uml2resources.fragment
Fragment-Host: org.eclipse.uml2.uml.resources;bundle-version="3.0.0"
Export-Package: libraries,metamodels,profiles
But somehow I tried it ineffectually and it didn't work. Now I tested it again and it works - at least for the execution as an eclipse app.
If I have problems with a deployed plugin I'll give a note.
Sry for asking and asking again Smile
Bye Tom =)
Previous Topic:[MWE] No logging and strange errors when workflow is run in a context of a plugin
Next Topic:[Acceleo 3l] Generate plugin
Current Time: Wed Jan 15 05:23:39 GMT 2025
Powered by FUDForum. Page generated in 0.10462 seconds
