Locating the jar file. [message #505] |
Fri, 18 April 2003 12:51 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: Mark.home.com
HI folks,
I've an outdated rogue jar file in my system and I can't seem to
locate it. How can I retrieve the physical path location of the jar file
that contains my class from Code?
Mark.
Re: Locating the jar file. [message #556 is a reply to message #505] |
Fri, 18 April 2003 16:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: genadyb.inter.net.il
Try "java -verbose:class"
It will show where the classes are loaded from.
Genady
Mark wrote:
> HI folks,
> Mark.
Re: Locating the jar file. [message #578 is a reply to message #556] |
Fri, 18 April 2003 18:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mark.home.com
Thanks Genady,
But I'm running jboss and I daresay this would produce an enormous
amount of data. Surely there has to be some way of retrieving this kind of
information from the classloader.
Mark.
> Genady
> Mark wrote:
> > HI folks,
> > Thanks,
> > Mark.
Re: Locating the jar file. [message #602 is a reply to message #578] |
Fri, 18 April 2003 21:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I see you got an answer in eclipse.tools group.
Does it work? (I was not aware of that part of the Java API)
Genady
mark wrote:
> Thanks Genady,
> Mark.
>>Genady
>>Mark wrote:
>>>HI folks,
>>>Thanks,
>>>Mark.
FUDForum. Page generated in 0.03700 seconds
