Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] write all the imports of a class(getParametersOperations)
[Acceleo 3] write all the imports of a class [message #554861] Tue, 24 August 2010 10:49 Go to next message
I wanna write all the imports of a class, so I want to get all the classes included in the parameters of the operations.
I tried this:
[query public getParametersOperations(class : Class) : Sequence(T) =
class.getAllOperations().parameterableElements()->select(not oclIsKindOf(Class))/]
[template public importBlock(class : Class)]
// [protected ('for imports')]
[for (at : Parameter | class.getParametersOperations())]
import [packageDomain(class) + at.type.name /];
[/for]
// [/protected]
[/template]
but If the same class is in more than one parameter, I've got a repeated import.
I want to use this in more than one place...
How can I filter the correct classes? Or you know another way to do that?
THANK YOU!!
Re: [Acceleo 3] write all the imports of a class [message #554870 is a reply to message #554861] Tue, 24 August 2010 11:14 Go to previous messageGo to next message
The key in your problem here is to use asSet() which will transform your collection into a Set. Because a set cannot have a duplicate element, you just have to create a set of the name of the type and duplicates will be delete. I have created an Acceleo project to show you how you can do it. My example uses Ecore as a metamodel contrary to UML in your example but it doesn't matter for that problem.
http://a.imageshack.us/img529/9133/capturexb.png
You can see that there are two ways to do it, and it is exactly the same mechanism. With OCL you should use "myCollection->collect(a | a.doSomething())" but we also tolerate "myCollection.doSomething()". both operation will create a collection. Then you just have to use asSet() to suppress all duplicates.
Stephane Begaudeau, Obeo
Re: [Acceleo 3] write all the imports of a class [message #555354 is a reply to message #554870] Thu, 26 August 2010 08:10 Go to previous messageGo to next message
yeah, thats great. Thank you.
I tried this, but no luck...
[template public parametersOperations(class : Classifier)]
[let packDomain:String = packageDomain(class)]
[for (eOperation : Operation | class.getAllOperations())]
[for (name : String | eOperation.ownedParameter -> collect(param | param.type) -> collect (type | type.name) -> asSet())]
import [packDomain + '.' + name/];
[/for]
[/for]
// [/protected]
[/let]
[/template]
Maybe it's because I'm using Class and not EClass? How can I use EClass from a Class (class.oclAsType(EClass) --> error cast)?
Re: [Acceleo 3] write all the imports of a class [message #555927 is a reply to message #555354] Mon, 30 August 2010 05:22 Go to previous messageGo to next message
--------------070307080402080200060608
Hi Sergio,
With this, you still have duplicate entries? or the processing fails
before that?
I'd suggest you use this:
[for (typeName : String |
class.getAllOperations().ownedParameter.type.name->asSet())]
import [packageDomain(class) + '.' + typeName/];
[/for]
// [/protected]
[/template]
Laurent Goubet
Obeo
> [/for]
> [/for]
> // [/protected]
> [/let]
> [/template]
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------070307080402080200060608--
Re: [Acceleo 3] write all the imports of a class [message #636843 is a reply to message #555927] Wed, 03 November 2010 01:23 Go to previous message
Thank you!
Yes, the last one was right!
(I left the project in stand by until this month.)
Previous Topic:[Acceleo 3.1] protected block
Next Topic:[Acceleo] Problem getting Run as | Launch Acceleo
Current Time: Thu Oct 30 13:19:50 EDT 2025
Powered by FUDForum. Page generated in 0.03583 seconds
