Home » Eclipse Projects » Remote Application Platform (RAP) » Timing problems with BrowserFunctions
Timing problems with BrowserFunctions [message #543409] |
Tue, 29 June 2010 10:32 |
Philipp Leusmann Messages: 36 Registered: July 2009 |
Member |
currently I am experimenting with BrowserFunctions in our project and I
experience some strange timing issues with the function injection.
The problem is, when calling a BrowserFunction very early in the
lifecycle of the document of the browser, say for example, window.onload
calls a BrowserFunction, the function has not necessarily already been
injected, due to the waiting for the loaded window in
Browser.createFunction .
I already tried to register the actual function-registering as an
eventListener on the IFrame-load-event, but there still occurs the race
condition with window.onload of the document in the iframe. My guess is,
that Qooxdoo uses the same waiting-loop as Browser.createFunction to
fire the load-Event.
Are there any hints on how this problem can be resolved?
I think, the most pragmatic solution would be to wait in the
browser-document for all required BrowserFunctions to be registered, but
I kind of do not like this solution to always have to update a
BrowserFunction-registry.
Maybe it would be possible to have the Browser trigger a kind of
ready-Event into the iframe, when all functions are registered. Any
thoughts on how this would be possible?
Since I need a solution for the problem today, I'll probably will go
with one of the possible solutions above and will update this group on
how the final solution looks.
Still, additional hints would be very appreciated.
Philipp
Re: Timing problems with BrowserFunctions [message #544247 is a reply to message #543409] |
Fri, 02 July 2010 06:45 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Philipp,
I'm curious... Did you find a way to solve these timing issues? Can you
share with us your findings?
Best,
Ivan
On 06/29/2010 1:32 PM, Philipp Leusmann wrote:
> I experience some strange timing issues with the function injection.
> window.onload calls a BrowserFunction, the function has not
> necessarily already been injected, due to the waiting for the loaded
> window in Browser.createFunction .
> race condition with window.onload of the document in the iframe. My
> guess is, that Qooxdoo uses the same waiting-loop as
> Browser.createFunction to fire the load-Event.
> but I kind of do not like this solution to always have to update a
> Regards,
> Philipp
Re: Timing problems with BrowserFunctions [message #544957 is a reply to message #544247] |
Tue, 06 July 2010 08:35 |
Member |
Hi Ivan,
I went with the function-registration method described: I put the names
of all needed functions into an array and then in the window.onload,
loop until all functions are found (or until some timeout occurs) and
then run the actual onload-code.
This is obviously quite a hack and I hope i will find some time to add
an issue to bugzilla with some demo-code during the next few days.
This baby should be quite easy to reproduce.
Philipp
Am 02.07.2010 08:45, schrieb Ivan Furnadjiev:
> Hi Philipp,
> Best,
> Ivan
>> Hi,
>> Regards,
>> Philipp
Current Time: Sat Jul 27 12:29:01 GMT 2024
Powered by FUDForum. Page generated in 0.04222 seconds
