Building DLL library with CDT [message #54375] |
Mon, 16 December 2002 22:13 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: alex.gestalt.com
I am trying to build a DLL library from a C code. I installed CygWin and
can compile and run the proverbial "Hello world" - just to get the feel
for it.
However, I do not have the makefile for building a DLL, nor have I been
able to find it by searching Google.
Does anyone have a working example that I could use?
On another note, I have not been able to run my hello.c program in debug
mode.
This is what I find in the log:
!ENTRY org.eclipse.cdt.launch 4 150 Dec 16, 2002 15:15:17.155
!MESSAGE Failed Launching CDI Debugger : Error initializing: Timedout
!STACK 0
org.eclipse.cdt.debug.core.cdi.CDIException: Error initializing: Timedout
at
org.eclipse.cdt.debug.mi.core.GDBDebugger.createLaunchSessio n(GDBDebugger.java:49)
What am I missing?
Any clues will be greatly appreciated.
Alex Molochnikov
Gestalt Corporation
Re: Building DLL library with CDT [message #54429 is a reply to message #54375] |
Tue, 17 December 2002 00:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
No real name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=jbrandmeyer%40earthlink.net) Messages: 4 Registered: July 2009 |
You should read the FAQ at www.mingw.org
It will answer most of your questions about DLL building. The MinGW and
Cygwin tools share the same back-end. (GCC), but unless you need/want a
POSIX emulation layer, MinGW is probably the better choice.
Make sure that the -g option is set in your build command (the gcc line, not
the make line) to build a debug version of your code.
HTH,
jb.
"Alex Molochnikov" <alex@gestalt.com> wrote in message
news:atlj5u$8lq$1@rogue.oti.com...
> for it.
> mode.
> !STACK 0
> at
va:49)
> What am I missing?
> Alex Molochnikov
> Gestalt Corporation
Re: Building DLL library with CDT [message #54568 is a reply to message #54429] |
Tue, 17 December 2002 23:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks. I installed MinGW and followed your advice. The DLL is built
allright, and I can execute my testcase, but debugging through Eclipse is
still a problem. I am getting different errors, depending on my Debug
settings.
When I select "GDB Debugger" in the Debugger tab of the Launch
Configurations window, and try to start the Debug, an attention panel pops
up: "Exception occurred while launching configuration. See log for more
information. Reason: failed launching CDI Debugger: No symbol table is
loaded. Use the "file" command."
And this is the log:
!ENTRY org.eclipse.debug.ui 4 120 Dec 17, 2002 16:06:18.359
!MESSAGE Error logged from Debug UI:
!STACK 1
org.eclipse.core.runtime.CoreException[150]:
org.eclipse.cdt.debug.mi.core.cdi.MI2CDIException: No symbol table is
at
org.eclipse.cdt.debug.mi.core.cdi.SourceManager.setAutoSolib (SourceManager.java:100)
at
org.eclipse.cdt.debug.mi.core.GDBDebugger.initializeLibrarie s(GDBDebugger.java:28)
at
org.eclipse.cdt.debug.mi.core.GDBDebugger.createLaunchSessio n(GDBDebugger.java:44)
at
org.eclipse.cdt.launch.internal.LocalCLaunchConfigurationDel egate.launch(LocalCLaunchConfigurationDelegate.java:84)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:136)
at
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationDialog$10.run(LaunchConfigurationDialog.java:2299)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:98)
!ENTRY org.eclipse.cdt.launch 4 150 Dec 17, 2002 16:06:18.359
!MESSAGE Failed Launching CDI Debugger : No symbol table is loaded. Use
the "file" command.
!STACK 0
at
at
at
at
at
at
at
I tried selecting "Cygwin GDB Debugger" option, but this does not work
either, bringing up the following attention panel: "The execution of
program is suspended because of error". The detail message is: "No
executable specified, use 'target exec'".
The log in this case is empty.
Interestingly enough, both times the gdb.exe process is launched - I can
see it in my Task Manager window.
Perhaps you or someone else knowledgeable in CDT/Debug interaction can
glimpse something peculiar in the above traceback that I fail to see. In
particular, what is this "file" command the Debugger is complaining about?
Alex Molochnikov
Gestalt Corporation
FUDForum. Page generated in 0.04375 seconds
