Re: Problems after update to Eclipse 3.6 with GMF 2.3.0 [message #548872 is a reply to message #548128] |
Fri, 23 July 2010 11:04 |
Soeren Hansen Messages: 3 Registered: March 2010 |
Anthony Hunter wrote on Tue, 20 July 2010 13:50 | On 07/20/2010 04:36 AM, Soeren Hansen wrote:
> We have also had the problem with the new PolylineShape not showing in
> the diagram.
> We debugged the whole thing down to OS level and couldn't find anything
> wrong:
> - the PolylineShape is created and added inside the NodeEditpart
> - the oulineShape() method gets called
> - the PolylineShape has sensible bounds and points which should
> constitute a simple line
> - the background and foreground color of the shape are both actually
> black (while the parent node is mostly white)
> - all other other attributes like lineWidth and so on seem to have
> sensible values as well
> In short everything seems to be in order, the line just doesn't appear
> in the diagram.
> We reverted back to using Polylines for now by changing the .gmfgen
> using Operational QVT. However any update on this would be appreciated
> as our solution is obviously an unwanted hack.
> Regards,
> Soeren
Hi Soeren,
I assume you are referring to using org.eclipse.draw2d.PolylineShape right?
Cheers...
Anthony
Hi Anthony,
Yes, that's right.
Soeren
FUDForum. Page generated in 0.03697 seconds
