Re: Error: could not find Java Runtime Environment [message #555981 is a reply to message #555807] |
Mon, 30 August 2010 13:00 |
On 8/28/2010 4:39 PM, Tim Berneman wrote:
> I had the same exact problem with Win7+Eclipse3.6+JRE1.6 and it said it
> couldn't find java. The solution was to add the location of JRE to my
> path variable. To do this on Win7 follow the instructions below (may be
> similar for other Windows versions):
> Right-click "My Computer", select "Advanced system settings" on the
> left, Click on the "Environment Variables..." button in the System
> Properties dialog.
> In the Environment Variables dialog scroll through the System variables
> and click on the "Path" variable, click the "Edit..." button.
> In the Edit System Variable dialog click in the Variable value text box,
> scroll to the end of it, and then add a semi-colon ";" (to separate
> different paths) and then add the path to the JRE, in my case it was
> "C:\Program Files\Java\jre6\bin" which is the default location. Click
> the "OK" button, "OK" again, and "OK" one last time.
> Try running Eclipse now. That's all I had to do. Hope this helps others
> out there.
> Tim :o]
You should instead associate a JDK (not a mere JRE) with Eclipse via the
-vm option in eclipse.ini as the earlier respondent said. (I say this so
that subsequent readers of the thread may know the correct way of doing
this.)
FUDForum. Page generated in 0.05197 seconds
