Home » Eclipse Projects » JFace » Getting TableViewerColumns from TableViewer reference?
Re: Getting TableViewerColumns from TableViewer reference? [message #541947 is a reply to message #541725] |
Wed, 23 June 2010 10:38 |
Henno Vermeulen Messages: 126 Registered: July 2009 |
Thank you! Works like a charm:
* Utility method for getting the {@link TableViewerColumn}s in a
* {@link TableViewer}.
* <p>
* WARNING: this method uses internal jface implementation and may not work
* for future versions.
public static TableViewerColumn[] getTableViewerColumns(
TableViewer tableViewer) {
TableColumn[] columns = tableViewer.getTable().getColumns();
TableViewerColumn[] viewerColumns = new TableViewerColumn[columns.length];
for (int i = 0; i < columns.length; i++) {
TableColumn tableColumn = columns[i];
viewerColumns[i] = (TableViewerColumn) tableColumn
.getData(Policy.JFACE + ".columnViewer");
return viewerColumns;
[Updated on: Wed, 23 June 2010 10:56] Report message to a moderator
Re: Getting TableViewerColumns from TableViewer reference? [message #541949 is a reply to message #541947] |
Wed, 23 June 2010 10:43 |
For people who are interested, here I give the TableViewerBinder utility I came up with. I factored it out of Snippet032TableViewerColumnEditing and I also give my refactored version of this snippet here.
Note that I also fixed this bug in the snippet.
I also used ViewerSupport to simplify the code that binds the label provider.
package org.eclipse.jface.examples.databinding.snippets;
import org.eclipse.core.databinding.DataBindingContext;
import org.eclipse.core.databinding.beans.BeanProperties;
import org.eclipse.core.databinding.observable.list.IObservableList;
import org.eclipse.core.databinding.property.value.IValueProperty;
import org.eclipse.jface.databinding.swt.WidgetProperties;
import org.eclipse.jface.databinding.viewers.CellEditorProperties;
import org.eclipse.jface.databinding.viewers.ObservableValueEditingSupport;
import org.eclipse.jface.databinding.viewers.ViewerSupport;
import org.eclipse.jface.util.Policy;
import org.eclipse.jface.viewers.TableViewer;
import org.eclipse.jface.viewers.TableViewerColumn;
import org.eclipse.jface.viewers.TextCellEditor;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.TableColumn;
* Provides basic support for binding a {@link TableViewer} to a collection of
* model objects.
* @author Henno Vermeulen
public final class TableViewerBinder {
private DataBindingContext bindingContext;
public TableViewerBinder() {
this(new DataBindingContext());
public TableViewerBinder(DataBindingContext bindingContext) {
this.bindingContext = bindingContext;
public DataBindingContext getBindingContext() {
return bindingContext;
public void bind(TableViewer peopleViewer, IObservableList input,
String[] propertyNames) {
bindInputAndLabels(peopleViewer, input, propertyNames);
bindCellEditors(peopleViewer, propertyNames);
private void bindInputAndLabels(TableViewer peopleViewer,
IObservableList input, String[] propertyNames) {
// Note: for efficiency we can consider reusing BeanProperties
// .values inside bindCellEditors
ViewerSupport.bind(peopleViewer, input, BeanProperties
.values(propertyNames));
private void bindCellEditors(TableViewer tableViewer, String... properties) {
ColumnBinder binder = new ColumnBinder(bindingContext, tableViewer);
TableViewerColumn[] columns = getTableViewerColumns(tableViewer);
binder.bind(columns[i], properties[i]);
static class ColumnBinder {
private TableViewer tableViewer;
private IValueProperty cellEditorControlText;
private TextCellEditor cellEditor;
public ColumnBinder(DataBindingContext bindingContext,
this.tableViewer = tableViewer;
cellEditorControlText = CellEditorProperties.control().value(
WidgetProperties.text(SWT.Modify));
cellEditor = new TextCellEditor(tableViewer.getTable());
public void bind(TableViewerColumn columnName, String propertyName) {
columnName.setEditingSupport(ObservableValueEditingSupport.create(
tableViewer, bindingContext, cellEditor,
cellEditorControlText, BeanProperties.value(propertyName)));
* <p>
import java.beans.PropertyChangeListener;
import java.beans.PropertyChangeSupport;
import java.util.LinkedList;
import java.util.List;
import org.eclipse.core.databinding.beans.BeansObservables;
import org.eclipse.core.databinding.observable.Realm;
import org.eclipse.core.databinding.observable.list.WritableList;
import org.eclipse.core.databinding.observable.value.IObservableValue;
import org.eclipse.jface.databinding.swt.SWTObservables;
import org.eclipse.jface.databinding.viewers.ViewersObservables;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
* Demonstrates binding a TableViewer with multiple columns to a collection.
* <p>
* Based on Snippet032TableViewerColumnEditing. The logic for binding the
* {@link TableViewer} to the model has been factored into the
* {@link TableViewerBinder} class.
public class Snippet032TableViewerColumnEditingRefactored {
final Display display = new Display();
Realm.runWithDefault(SWTObservables.getRealm(display), new Runnable() {
public void run() {
ViewModel viewModel = new ViewModel();
Shell shell = new View(viewModel).createShell();
// The SWT event loop
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
// Minimal JavaBeans support
public static abstract class AbstractModelObject {
private PropertyChangeSupport propertyChangeSupport = new PropertyChangeSupport(
this);
public void addPropertyChangeListener(PropertyChangeListener listener) {
propertyChangeSupport.addPropertyChangeListener(listener);
public void addPropertyChangeListener(String propertyName,
propertyChangeSupport.addPropertyChangeListener(propertyName,
listener);
public void removePropertyChangeListener(PropertyChangeListener listener) {
propertyChangeSupport.removePropertyChangeListener(listener);
public void removePropertyChangeListener(String propertyName,
propertyChangeSupport.removePropertyChangeListener(propertyName,
listener);
protected void firePropertyChange(String propertyName, Object oldValue,
Object newValue) {
propertyChangeSupport.firePropertyChange(propertyName, oldValue,
newValue);
// The data model class. This is normally a persistent class of some sort.
static class Person extends AbstractModelObject {
public static final String[] propertyNames = new String[] { "name",
"firstName" };
// A property...
String name;
String firstName;
public Person(String firstName, String name) {
this.name = name;
this.firstName = firstName;
public String getName() {
return name;
public void setName(String name) {
firePropertyChange("name", this.name, this.name = name);
public String getFirstName() {
return firstName;
public void setFirstName(String firstName) {
firePropertyChange("firstName", this.firstName,
this.firstName = firstName);
// The View's model--the root of our Model graph for this particular GUI.
// Typically each View class has a corresponding ViewModel class.
// The ViewModel is responsible for getting the objects to edit from the
// data access tier. Since this snippet doesn't have any persistent objects
// ro retrieve, this ViewModel just instantiates a model object to edit.
static class ViewModel {
// The model to bind
private List people = new LinkedList();
people.add(new Person("Dave", "Orme"));
people.add(new Person("Gili", "Mendel"));
people.add(new Person("Joe", "Winchester"));
people.add(new Person("Boris", "Bokowski"));
people.add(new Person("Brad", "Reynolds"));
people.add(new Person("Matthew", "Hall"));
public List getPeople() {
return people;
// The GUI view
static class View {
private ViewModel viewModel;
private Table committers;
private Label selectedCommitterName;
private Label selectedCommitterFirstName;
public View(ViewModel viewModel) {
this.viewModel = viewModel;
public Shell createShell() {
// Build a UI
Display display = Display.getDefault();
Shell shell = new Shell(display);
shell.setLayout(new GridLayout(2, true));
TableViewer peopleViewer = createTableViewer(shell);
createDetailView(shell);
DataBindingContext bindingContext = new DataBindingContext();
WritableList input = new WritableList(viewModel.getPeople(),
Person.class);
new TableViewerBinder(bindingContext).bind(peopleViewer, input,
Person.propertyNames);
bindDetails(bindingContext, peopleViewer);
// Open and return the Shell
shell.setSize(250, 300);
shell.open();
return shell;
private TableViewer createTableViewer(Composite parent) {
committers = new Table(parent, SWT.BORDER | SWT.FULL_SELECTION);
committers.setLinesVisible(true);
committers.setHeaderVisible(true);
GridData layoutData = new GridData(SWT.FILL, SWT.FILL, true, true);
layoutData.horizontalSpan = 2;
committers.setLayoutData(layoutData);
// Since we're using a JFace Viewer, we do first wrap our Table...
TableViewer peopleViewer = new TableViewer(committers);
TableViewerColumn columnName = new TableViewerColumn(peopleViewer,
SWT.NONE);
columnName.getColumn().setText("Name");
columnName.getColumn().setWidth(100);
TableViewerColumn columnFirstName = new TableViewerColumn(
peopleViewer, SWT.NONE);
columnFirstName.getColumn().setText("FirstName");
columnFirstName.getColumn().setWidth(100);
return peopleViewer;
private void createDetailView(Composite parent) {
GridData fieldLayoutData = new GridData(SWT.FILL, SWT.BEGINNING,
true, false);
selectedCommitterName = new Label(parent, SWT.NONE);
selectedCommitterName.setLayoutData(fieldLayoutData);
selectedCommitterFirstName = new Label(parent, SWT.NONE);
selectedCommitterFirstName.setLayoutData(fieldLayoutData);
private void bindDetails(DataBindingContext bindingContext,
TableViewer peopleViewer) {
// bind selectedCommitter labels to the name and forname of the
// current selection
IObservableValue selection = ViewersObservables
.observeSingleSelection(peopleViewer);
bindingContext.bindValue(SWTObservables
.observeText(selectedCommitterName), BeansObservables
.observeDetailValue(selection, "name", String.class));
.observeText(selectedCommitterFirstName), BeansObservables
.observeDetailValue(selection, "firstName", String.class));
Current Time: Sun Sep 29 00:17:23 GMT 2024
Powered by FUDForum. Page generated in 0.05062 seconds
