Home » Eclipse Projects » Buckminster dev » Headless buckminster commands broken in 3.6?
Re: Headless buckminster commands broken in 3.6? [message #536436 is a reply to message #536407] |
Fri, 28 May 2010 08:53 |
Axel Guckelsberger Messages: 354 Registered: July 2009 |
Hi Thomas,
yes it is. In detail I installed the following headless features:
buckminster core, cvs, pde, subclipse.
For now I switched back to the headless version of 3.5 temporarily.
Axel
Thomas Hallgren wrote:
> Hi Alex,
> The setpref command is not included in the product. It is added by the
> o.e.buckminster.core feature. Is that feature installed?
> HTH,
> Thomas Hallgren
> On 05/27/2010 11:17 PM, Axel Guckelsberger wrote:
>> Hello,
>> it seems like the latest buckminster executable (obtained from the
>> http://download.eclipse.org/tools/buckminster/headless-3.6 update site)
>> does not understand the 'setpref' command, causing the Hudson job to
>> fail. Is this a bug or am I doing something wrong?
>> Regards,
>> Axel
Re: Headless buckminster commands broken in 3.6? [message #536462 is a reply to message #536436] |
Fri, 28 May 2010 11:32 |
Hi Axel,
I have no problems using 3.6. I just tried this:
[thhal@tada tmp]$ ../buildtools/director/director -r http://download.eclipse.org/tools/buckminster/headless-3.6 -p
Buckminster -d /home/thhal/tmp/buckminster -i org.eclipse.buckminster.cmdline.product -i
org.eclipse.buckminster.core.headless.feature.feature.group -roaming
Installing org.eclipse.buckminster.cmdline.product 1.2.0.r11425.
Installing org.eclipse.buckminster.core.headless.feature.feature.group 1.3.0.r11446.
Operation completed in 30095 ms.
[thhal@tada tmp]$ buckminster/buckminster setpref connectionRetryCount=2
connectionRetryCount set to the value '2'
What platform are you running on?
- thomas
On 05/28/2010 10:53 AM, Axel Guckelsberger wrote:
> Hi Thomas,
> Regards
> Axel
>> Hi Alex,
>> HTH,
>> Thomas Hallgren
>>> Hello,
>>> Regards,
>>> Axel
Re: Headless buckminster commands broken in 3.6? [message #536490 is a reply to message #536462] |
Fri, 28 May 2010 13:09 |
Hi Thomas,
I coped with reproducing your example and it worked. I try to explain the
difference and what went wrong before. I am running this on a Ubuntu
machine.
If one calls the director like you did in the snippet below everything works
well. In my earlier attempts I did it in several single steps like shown in
the wiki:
1. director/director -r
http://download.eclipse.org/tools/buckminster/headless-3.6 -p Buckminster -d
TestFolder -i org.eclipse.buckminster.cmdline.product
2. TestFolder/buckminster install core headless feature
3. TestFolder/buckminster install the other ones
The problem here is that the features installed by buckminster are placed in
TestFolder/TestFolder so at the end there are two different p2 repositories.
Maybe caused by using relative target folders at this place.
After I tried your version successfully I installed the pde headless feature
with buckminster. This time it went into the correct folders.
Thanks for your help
Axel
> Hi Axel,
> [http://download.eclipse.org/tools/buckminster/headless-3.6 -p
> 1.3.0.r11446. Operation completed in 30095 ms.
> - thomas
>> Hi Thomas,
>> Regards
>> Axel
>>> Hi Alex,
>>> HTH,
>>> Thomas Hallgren
>>>> Hello,
>>>> Regards,
>>>> Axel
Current Time: Fri Sep 27 00:31:06 GMT 2024
Powered by FUDForum. Page generated in 0.05443 seconds
