Problem while creating GMF models from xsd. [message #536101] |
Thu, 27 May 2010 04:47 |
login Messages: 13 Registered: May 2010 |
Hi All,
I am new to GMF. I have been trying to understand the concept of generating Ecore model from xsd.
I generated a Ecore model from xsd and used the same ecore file to generate genmodel. gen model created successfully.
But when i tried generating the "gmfgen" model out of genmodel.
It throws an error.
I need to know the following :
1.)Does GMF supports a Ecore model generated out of xsd.
2) I tried using Eugenia to generate gmfgen and gmf diagram from sample .emf model it works fine.But when i tried generating the ecore from "xsd" .It has some issues.
Does any body know how to go about it?
I got this error
Method 'getContainmentReferences' not found (190:38)
at org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on(PointExecutor.java:190)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:67)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:37)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:123)
at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(E xecutorFactory.java:178)
at org.eclipse.epsilon.eol.execute.ForStatementExecutor.execute (ForStatementExecutor.java:44)
at org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te(StatementBlockExecutor.java:33)
at org.eclipse.epsilon.eol.EolModule.execute(EolModule.java:57)
at org.eclipse.epsilon.eugenia.EolTransformationActionDelegate. runImpl(EolTransformationActionDelegate.java:136)
at org.eclipse.epsilon.eugenia.EolTransformationActionDelegate$ 1.run(EolTransformationActionDelegate.java:65)
Thanks in advance,
[Updated on: Thu, 27 May 2010 04:50] Report message to a moderator
FUDForum. Page generated in 0.03192 seconds
