Home » Archived » B3 » B3 Aggregator + Helios Site
B3 Aggregator + Helios Site [message #535450] Sun, 23 May 2010 17:24 Go to next message
Michael Pellaton is currently offline Michael PellatonFriend
Hello
Obviously, B3 aggregator is used to assemble the Helios milestone site.
I try to mirror the entire Helios site using B3 aggregator and I often
run into problems during the validation phase.
Why can't I mirror the Helios site using the B3 aggregator but the
entire thing was created using the same program running the same
validations? How can the site be assembled successfully if there
are invalid constraints preventing the mirroring?
Besides that, I found that it is very temporal whether mirroring is
possible or not:
- today = validation error in the gmf.examples area
- Sat a week ago = validation error in the xtext area
- Tue a week ago = mirroring possible
- Sat 2 weeks ago = validation error in the modisco area
What's up?
Michael
Re: B3 Aggregator + Helios Site [message #535457 is a reply to message #535450] Sun, 23 May 2010 18:00 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
A very possible reason is that there are actual errors in the input.
Helios is a moving target, and as Dave Williams can testify there is
almost always some contributor that has some problem/conflict.
These issues are gradually solved until a release ready Helios site is
produced.
I don't know if good helios repos are kept somewhere.
- henrik
On 5/23/10 7:24 PM, Michael Pellaton wrote:
> Hello
> possible or not:
> What's up?
> Michael
Re: B3 Aggregator + Helios Site [message #535465 is a reply to message #535457] Sun, 23 May 2010 20:23 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
I think the main reason is that what you find at releases/helios is an aggregate that contains older versions along with
the new ones. The b3 aggregator creates a repository that is validated. The composite however, is several such
repositories. Put together, they no longer represent a 100% coherent repository.
- thomas
> produced.
> - henrik
>> Hello
>> possible or not:
>> What's up?
>> Michael
Re: B3 Aggregator + Helios Site [message #535469 is a reply to message #535465] Sun, 23 May 2010 21:04 Go to previous messageGo to next message
So, how should someone that wants to use Helios repo in their own
aggregation work around this issue?
- henrik
> aggregate that contains older versions along with the new ones. The b3
> however, is several such repositories. Put together, they no longer
> - thomas
>> produced.
>> - henrik
>>> Hello
>>> possible or not:
>>> What's up?
>>> Michael
Re: B3 Aggregator + Helios Site [message #535470 is a reply to message #535469] Sun, 23 May 2010 21:46 Go to previous messageGo to next message
Well, one solution is to use the p2 mirrorApplication, but that's not my
favourite solution as this seems to be more or less a wget for repos.
A cool feature for the b3 aggregator would be to mirror only the newest
artifacts without having to specify version constraints for each IU
(similar to the p2 install dialog where one can hide old versions).
Another help would be regex exclusions for IUs (e.g. exclude *javahl*
instead of 12 IUs containing javahl).
Michael
> - henrik
>> - thomas
>>> produced.
>>> - henrik
>>>> Hello
>>>> possible or not:
>>>> What's up?
>>>> Michael
Re: B3 Aggregator + Helios Site [message #535478 is a reply to message #535470] Mon, 24 May 2010 00:56 Go to previous messageGo to next message
Using filters is something that has been discussed - esp. "include only
latest". Not sure if an issue was logged for that...
- henrik
> Michael
>> - henrik
>>> - thomas
>>>> produced.
>>>> - henrik
>>>>> Hello
>>>>> possible or not:
>>>>> What's up?
>>>>> Michael
Re: B3 Aggregator + Helios Site [message #535489 is a reply to message #535470] Mon, 24 May 2010 03:28 Go to previous messageGo to next message
It already does this. I haven't seen the errors but my guess is that they relate to features that has been removed in
newer versions.
You can always try aggregating the latest contribution to the composite, i.e.
http://download.eclipse.org/releases/helios/201005210900
- thomas
Re: B3 Aggregator + Helios Site [message #535516 is a reply to message #535489] Mon, 24 May 2010 08:30 Go to previous messageGo to next message
> i.e.
When doing that, I get
java.lang.ClassCastException:
org.eclipse.equinox.internal.p2.metadata.InstallableUnit cannot be cast
to org.eclipse.equinox.p2.metadata.IInstallableUnitPatch
org.eclipse.core.runtime.CoreException: java.lang.ClassCastException:
at org.eclipse.b3.util.ExceptionUtils.fromMessage(ExceptionUtil s.java:53)
at org.eclipse.b3.util.ExceptionUtils.wrap(ExceptionUtils.java: 120)
at
org.eclipse.b3.aggregator.engine.RepositoryVerifier.run(Repo sitoryVerifier.java:271)
at
org.eclipse.b3.aggregator.engine.Builder.runRepositoryVerifi er(Builder.java:1109)
at org.eclipse.b3.aggregator.engine.Builder.run(Builder.java:62 1)
at
org.eclipse.b3.aggregator.presentation.AggregatorActionBarCo ntributor$BuildRepoAction$1.run(AggregatorActionBarContribut or.java:267)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.ClassCastException:
at
org.eclipse.b3.aggregator.engine.RepositoryVerifier.run(Repo sitoryVerifier.java:214)
... 4 more
I am using Eclipse SDK 3.6.RC2 + b3 aggregator 0.1.0.r01001
Michael
Re: B3 Aggregator + Helios Site [message #535547 is a reply to message #535516] Mon, 24 May 2010 12:15 Go to previous messageGo to next message
That sounds like a bug. Can you please try with the latest version
(unless that's what you have already) and if this problem is still
present, enter a bugzilla to Modeling/EMFT.b3/aggregator?
Thomas Hallgren
>> i.e.
> at
> at
> at
> at
> ... 4 more
> Michael
Re: B3 Aggregator + Helios Site [message #535557 is a reply to message #535547] Mon, 24 May 2010 12:58 Go to previous messageGo to next message
Hello
Done.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=314108
Michael
Re: B3 Aggregator + Helios Site [message #542006 is a reply to message #535450] Wed, 23 June 2010 13:57 Go to previous messageGo to next message
Lars Fischer is currently offline Lars FischerFriend
I tried to mirror the final helios p2 site with the b3 aggregator.
I created a .b3aggr file with one contribution, mapping the helios url:
Running this, I get this error:
Loading all repositories
Starting generation of composite repository
Adding child meta-data repository
Done. Took 0 seconds
Starting generation of verification feature
Starting generation of categories
Starting planner verification
Verifying config win32,win32,x86...
Verifying config win32,win32,x86_64...
Verifying config linux,gtk,x86...
Software being installed: all.contributed.content.feature.group 1.0.0
Missing requirement for filter properties ~= $0:
org.eclipse.ecf.core.featurepatch.feature.group 3.3.0.v20100615-1452
requires 'org.eclipse.ecf.core.featurepatch.feature.jar
[3.3.0.v20100615-1452]' but it could not be found
Cannot satisfy dependency: all.contributed.content.feature.group 1.0.0
depends on: org.eclipse.ecf.core.featurepatch.feature.group 0.0.0
Where is my mistake?
Lars
Re: B3 Aggregator + Helios Site [message #542058 is a reply to message #542006] Wed, 23 June 2010 16:30 Go to previous message
Filip Hrbek is currently offline Filip HrbekFriend
I created a bugzilla issue: https://bugs.eclipse.org/bugs/show_bug.cgi?id=317727
Filip
Lars Fischer wrote:
> Hello,
> Regards,
> Lars
Re: B3 Aggregator + Helios Site [message #608267 is a reply to message #535450] Sun, 23 May 2010 18:00 Go to previous message
produced.
- henrik
> Hello
> possible or not:
> What's up?
> Michael
Re: B3 Aggregator + Helios Site [message #608269 is a reply to message #535457] Sun, 23 May 2010 20:23 Go to previous message
- thomas
> produced.
> - henrik
>> Hello
>> possible or not:
>> What's up?
>> Michael
Re: B3 Aggregator + Helios Site [message #608271 is a reply to message #535465] Sun, 23 May 2010 21:04 Go to previous message
- henrik
> - thomas
>> produced.
>> - henrik
>>> Hello
>>> possible or not:
>>> What's up?
>>> Michael
Re: B3 Aggregator + Helios Site [message #608273 is a reply to message #535469] Sun, 23 May 2010 21:46 Go to previous message
Michael
> - henrik
>> - thomas
>>> produced.
>>> - henrik
>>>> Hello
>>>> possible or not:
>>>> What's up?
>>>> Michael
Re: B3 Aggregator + Helios Site [message #608274 is a reply to message #535470] Mon, 24 May 2010 00:56 Go to previous message
- henrik
> Michael
>> - henrik
>>> - thomas
>>>> produced.
>>>> - henrik
>>>>> Hello
>>>>> possible or not:
>>>>> What's up?
>>>>> Michael
Re: B3 Aggregator + Helios Site [message #608275 is a reply to message #535470] Mon, 24 May 2010 03:28 Go to previous message
newer versions.
- thomas
Re: B3 Aggregator + Helios Site [message #608277 is a reply to message #535489] Mon, 24 May 2010 08:30 Go to previous message
> i.e.
at
at
at
at
... 4 more
Michael
Re: B3 Aggregator + Helios Site [message #608278 is a reply to message #535516] Mon, 24 May 2010 12:15 Go to previous message
Thomas Hallgren
>> i.e.
> at
> at
> at
> at
> ... 4 more
> Michael
Re: B3 Aggregator + Helios Site [message #608280 is a reply to message #535547] Mon, 24 May 2010 12:58 Go to previous message
Hello
Done.
Michael
Re: B3 Aggregator + Helios Site [message #608565 is a reply to message #535450] Wed, 23 June 2010 13:57 Go to previous message
Lars
Re: B3 Aggregator + Helios Site [message #608567 is a reply to message #542006] Wed, 23 June 2010 16:30 Go to previous message
Filip
Lars Fischer wrote:
> Hello,
> Regards,
> Lars
Previous Topic:b3 status update
Next Topic:b3 - refactored engine boot
Current Time: Sat Dec 21 12:07:12 GMT 2024
Powered by FUDForum. Page generated in 0.08346 seconds
