Problem debugging with attached source in 2.1 [message #53350] |
Mon, 09 June 2003 17:07 |
Originally posted by: norrie.quinn.tumbleweed.com
I can't debug a 3rd party jar with attached source. This worked before I
upgraded to Eclipse 2.1, but does not work for me with 2.1.
I go to Project/Properties/Java Build Path/Libraries and select an external
jar that I want to debug. I expand it, select the correct source attachment
location, and now the package explorer can locate the source for any
class/method in that jar. When I set a breakpoint on this source, the
breakpoint is hit and execution stops, but the Source Window has a red
"Source not found" message.
Any ideas what I might be doing wrong?
Norrie
Re: Problem debugging with attached source in 2.1 [message #53384 is a reply to message #53350] |
Mon, 09 June 2003 17:55 |
Originally posted by: Olivier_Thomann.ca.ibm.comNOSPAM
On Mon, 9 Jun 2003 10:07:14 -0700, "Norrie Quinn"
Can you open the source in the package explorer?
Olivier
Re: Problem debugging with attached source in 2.1 [message #54021 is a reply to message #53384] |
Wed, 11 June 2003 02:07 |
Yes.
"Olivier Thomann" <Olivier_Thomann@ca.ibm.comNOSPAM> wrote in message
news:8fi9evcin987uddo0qsnin438b6s9lor10@4ax.com...
external
Yes the package explorer work fine. The problem is only displaying the
source when a breakpoint is hit or when I step into or through the attached
code.
All other debugging is OK.
Norrie
> Olivier
FUDForum. Page generated in 0.03674 seconds
