Home » Eclipse Projects » Remote Application Platform (RAP) » CCombo in CellEditor can not be set "not editable" any longer(BUG in RAP 1.3 M7?)
Re: CCombo in CellEditor can not be set "not editable" any longer [message #532762 is a reply to message #532754] |
Tue, 11 May 2010 07:31 |
Rüdiger Herrmann Messages: 581 Registered: July 2009 |
I can't reproduce what you describe. However, if you have a snippet that
reproduces the issue, please feel free to file a bugzilla.
Rüdiger
On 11.05.2010 09:17, Bassspieler wrote:
> Hi!
> I had just fine working code, that prevented a user to type text in a
> combobox, that is inside a table (table with comboboxEditingSupport).
> Since the integration of RAP 1.3M7 the code gets still compiled, but on
> runtime, when a user clicks a combobox there is a javascript error Could
> not evaluate javascript response:
> Ungültiges Argument.
> My code was: ((CCombo)
> getCellEditor(null).getControl()).setEditable(false); that I placed in
> the constructor of my EditingSupport-Class. All other methods of the
> CCombo seem to work, but "setEditable()".
> Best regards,
> Bassspieler
Re: CCombo in CellEditor can not be set "not editable" any longer [message #533061 is a reply to message #532754] |
Wed, 12 May 2010 07:09 |
Niels Lippke Messages: 71 Registered: December 2009 |
Member |
I also encounter a problem with the ComboBoxCellEditor. I removed the
try-catch-block in Request.js and started my application in Debug mode to
see where the exception originates. And my IE stopped in FocusIndicator.js
where it tries to apply negative values to a <div> tag, because it does not
get the boundings right. The FocusIndicator for ComboBoxes is new in M7.
The ugly part is: Whenever I try to write a snippet to reproduce this
behaviour... it works, correctly.
Regards, Niels
"Bassspieler" <kempus@web.de> schrieb im Newsbeitrag
news:hsb09s$ca7$1@build.eclipse.org...
> Hi!
> getCellEditor(null).getControl()).setEditable(false); that I placed in the
> constructor of my EditingSupport-Class. All other methods of the CCombo
> Best regards,
> Bassspieler
Re: CCombo in CellEditor can not be set "not editable" any longer [message #533077 is a reply to message #533061] |
Wed, 12 May 2010 08:03 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Niels,
your finding related to FocusIndicator helps a lot. Please file a
bigzilla about this issue to keep track on it.
Best,
Ivan
On 05/12/2010 10:09 AM, Niels Lippke wrote:
> to see where the exception originates. And my IE stopped in
> FocusIndicator.js where it tries to apply negative values to a <div>
> tag, because it does not get the boundings right. The FocusIndicator
> Regards, Niels
>> Hi!
>> on runtime, when a user clicks a combobox there is a javascript error
>> Could not evaluate javascript response:
>> in the constructor of my EditingSupport-Class. All other methods of
>> the CCombo seem to work, but "setEditable()".
>> Best regards,
>> Bassspieler
Re: CCombo in CellEditor can not be set "not editable" any longer [message #533094 is a reply to message #533061] |
Wed, 12 May 2010 08:33 |
Hi all,
bug filled:
312544: [CCombo] Read-only ComboBoxCellEditor throws javascript error in IE
https://bugs.eclipse.org/bugs/show_bug.cgi?id=312544
I can reproduce it in IE with controls demo.
Best,
Ivan
> Regards, Niels
>> Hi!
>> Best regards,
>> Bassspieler
Re: CCombo in CellEditor can not be set "not editable" any longer [message #533100 is a reply to message #533077] |
Wed, 12 May 2010 08:53 |
Member |
Bug #312549
Thanks, Niels
"Ivan Furnadjiev" <ivan@eclipsesource.com> schrieb im Newsbeitrag
news:hsdnc5$i1b$1@build.eclipse.org...
> Hi Niels,
> your finding related to FocusIndicator helps a lot. Please file a bigzilla
> Best,
> Ivan
>> Hi,
>> FocusIndicator.js where it tries to apply negative values to a <div> tag,
>> because it does not get the boundings right. The FocusIndicator for
>> Regards, Niels
>>> Hi!
>>> Best regards,
>>> Bassspieler
Current Time: Sat Jul 27 17:14:11 GMT 2024
Powered by FUDForum. Page generated in 0.03713 seconds
