Re: Problems with deployin to war file to Tomcat 6.0 [message #532519 is a reply to message #532510] |
Mon, 10 May 2010 11:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Rüdiger,
The problem is Im getting the RAP STartup Page.. Its not loading my entrypoint (in my case test). Its just a blanck page the bridge seems to be working.. its just not loading my entry point.
hm. I've lost a machine.. literally _lost_. it responds to ping, it works completely, I just can't figure out where in my apartment it is.
Re: Problems with deployin to war file to Tomcat 6.0 [message #532750 is a reply to message #532519] |
Tue, 11 May 2010 06:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Rüdiger Herrmann![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ruediger.herrmann%40gmx.de) Messages: 581 Registered: July 2009 |
Martijn,
I can't help you without further information. Please, go along the
tutorial, double check everything, do check the things mentioned in the FAQ.
If you are still having problems, please post here with details
(exception, unresolved bundles, what exactly means "not loading my entry
point ", etc.).
Rüdiger
On 10.05.2010 13:27, Martijn Cremer wrote:
> Rüdiger,
Re: Problems with deployin to war file to Tomcat 6.0 [message #532863 is a reply to message #532750] |
Tue, 11 May 2010 12:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I found the problem I was single sourcing and there for had all the rap or rpc dependency set as optional then the validation trick for the feature that written in the in the FAQ. Wont work totaly my bad
FUDForum. Page generated in 0.03898 seconds
