Home » Archived » Visual Editor (VE) » Designtime : Swing Components do not show up
Designtime : Swing Components do not show up [message #52947] Sun, 01 August 2004 08:06 Go to next message
Originally posted by: wolfganglechnerPLEASE.NOSPAMgmx.at
First of all, thanks to the eclipse and ve community
for this great software.
But I experience a problem in designing visual components
derived from javax.swing.*
I'm able to create a VisualClass file but no frame does show
up in the designwindow. The source is ok; if I add visual
compnents the source changes and is correct.
Using awt instead the designwindow does update only
when changing the sourcecode. Dropping components onto
the frame does not.
Did I miss something? (class-paths or other properties to
set?) Anybody experienced something similar?
Setup :
WindowsXP
Eclipse 3.0 200406251208
VE M2
thanks in advance
wolf
Re: Designtime : Swing Components do not show up [message #52973 is a reply to message #52947] Sun, 01 August 2004 12:30 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
We've never seen something like that. Could you please attach you .log
portions that refer to jem and ve? There may be errors that would
explain this.
Thanks, Rich Kulp
Re: Designtime : Swing Components do not show up [message #52998 is a reply to message #52973] Sun, 01 August 2004 13:38 Go to previous messageGo to next message
hi
I created a new workspace (directory) then New->Project->JavaProject
and New->VisualClass-> derived from Swing Frame
The .log says that :
!SESSION Aug 01, 2004
19:34:33.670 ---------------------------------------------
eclipse.buildId=I200406251208
java.version=1.4.2_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
!ENTRY org.eclipse.ve.java.core 4 0 Aug 01, 2004 19:34:33.670
!MESSAGE Exception thrown.
!STACK 0
java.lang.ClassCastException
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.createJavaIns
tances(JavaSourceTranslator.java:704)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildComposit
ionModel(JavaSourceTranslator.java:773)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocumen
t(JavaSourceTranslator.java:880)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(Jav
aSourceTranslator.java:655)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.r
un(JavaVisualEditorPart.java:1413)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Thanks in advance
wolf
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:cej5ms$oie$1@eclipse.org...
> explain this.
> Thanks, Rich Kulp
Re: Designtime : Swing Components do not show up [message #53024 is a reply to message #52998] Sun, 01 August 2004 14:41 Go to previous messageGo to next message
What version of EMF are you using (should be 2.0.0 final release)?
Are you doing anything special with EMF, changing the resource factories
in any way?
Are there other non-standard Eclipse projects installed beside GEF, EMF,
and VE?
The class cast error on the given line should not occur if vanilla EMF
is installed. It is saying our resource that we use to model the class
is not an XMIResource, and that can't happen normally.
Thanks, Rich Kulp
Re: Designtime : Swing Components do not show up [message #53100 is a reply to message #53024] Mon, 02 August 2004 05:03 Go to previous message
Ok, I completly reinstalled eclipse, gef, emf and ve,
works (I believe I did not download GEF before)
thanks
wolf
news:cejdch$vvt$1@eclipse.org...
> in any way?
> and VE?
> Thanks, Rich Kulp
Re: Designtime : Swing Components do not show up [message #596262 is a reply to message #52947] Sun, 01 August 2004 12:30 Go to previous message
explain this.
Thanks, Rich Kulp
Re: Designtime : Swing Components do not show up [message #596272 is a reply to message #52973] Sun, 01 August 2004 13:38 Go to previous message
hi
!STACK 0
at
at
at
at
at
Thanks in advance
wolf
> explain this.
> Thanks, Rich Kulp
Re: Designtime : Swing Components do not show up [message #596280 is a reply to message #52998] Sun, 01 August 2004 14:41 Go to previous message
in any way?
and VE?
Thanks, Rich Kulp
Re: Designtime : Swing Components do not show up [message #596314 is a reply to message #53024] Mon, 02 August 2004 05:03 Go to previous message
thanks
wolf
> in any way?
> and VE?
> Thanks, Rich Kulp
Previous Topic:ToolTip for Tree in palette missing
Next Topic:VE Editor for Eclipse 3.0 Can't ser formdata
Current Time: Thu Oct 30 11:57:59 EDT 2025
Powered by FUDForum. Page generated in 0.09645 seconds
