Home » Eclipse Projects » Remote Application Platform (RAP) » RAP is not working with Galileo 3.5
RAP is not working with Galileo 3.5 [message #526436] Sun, 11 April 2010 01:41 Go to next message
lottalava  is currently offline lottalava Friend
Hello folks, iǘe just installed Galileo 3.5 and Eclipse RAP runtime ( in a different directory ), my problem is, i cannot run a simple Hello World exemple from eclipse!'
This is what i got from console output:
osgi> !SESSION 2010-04-10 22:41:19.917 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_13
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -dev file:/home/edson/workspace/.metadata/.plugins/org.eclipse.pd e.core/Blah/dev.properties -os linux -ws gtk -arch x86 -console -consolelog
!ENTRY Blah 4 0 2010-04-10 22:41:23.333
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui; bundle-version="0.0.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolverError(AbstractBundle.java:1312)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolutionFailureException(AbstractBundle.java:1296)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:319)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:369)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1068)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:554)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:461)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:246)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:442)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:337)
!ENTRY org.eclipse.rap.demo 4 0 2010-04-10 22:41:23.371
!MESSAGE
!STACK 0
!ENTRY org.eclipse.rap.ui 4 0 2010-04-10 22:41:24.396
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui.workbench; bundle-version="[1.3.0,2.0.0)"
!ENTRY org.eclipse.rap.demo.databinding 4 0 2010-04-10 22:41:26.856
!MESSAGE
!STACK 0
!ENTRY org.eclipse.rap.ui.views 4 0 2010-04-10 22:41:26.874
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui; bundle-version="[1.2.0,4.0.0)"
!ENTRY org.eclipse.rap.ui.workbench 4 0 2010-04-10 22:41:27.021
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.help; bundle-version="[3.5.0,4.0.0)"
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.089
!MESSAGE Bundle initial@reference:file:../../home/edson/workspace/Blah/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.094
!MESSAGE Bundle initial@reference :file:../eclipse-RAP/plugins/org.eclipse.rap.ui.views_1.3.0. 20100316-1859.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.096
!MESSAGE Bundle initial@reference :file:../eclipse-RAP/plugins/org.eclipse.rap.ui_1.3.0.201003 16-1859.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.099
!MESSAGE Bundle initial@reference :file:../eclipse-RAP/plugins/org.eclipse.rap.demo_1.3.0.2010 0316-1859.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.101
!MESSAGE Bundle initial@reference :file:../eclipse-RAP/plugins/org.eclipse.rap.demo.databindin g_1.3.0.20100316-1859.jar/ was not resolved.
!ENTRY org.eclipse.osgi 4 0 2010-04-10 22:41:27.103
!MESSAGE Bundle initial@reference :file:../eclipse-RAP/plugins/org.eclipse.rap.ui.workbench_1. 3.0.20100316-1859.jar/ was not resolved.
Re: RAP is not working with Galileo 3.5 [message #526449 is a reply to message #526436] Sun, 11 April 2010 08:30 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
did you set RAP as a target platform? Please post the result of osgi ss
command.
Best,
Ivan
> -consolelog
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> !MESSAGE !STACK 0
> !MESSAGE Bundle
> mailto:initial@reference:file:../../home/edson/workspace/Blah/ was not
> resolved.
> !MESSAGE Bundle mailto:initial@reference
Re: RAP is not working with Galileo 3.5 [message #526464 is a reply to message #526436] Sun, 11 April 2010 14:20 Go to previous messageGo to next message
Yes, i'm using eclipseRAP as runtime target!
I don't known that command, osgi ss, where can i execute it?
[Updated on: Sun, 11 April 2010 14:45]
Report message to a moderator
Re: RAP is not working with Galileo 3.5 [message #526472 is a reply to message #526464] Sun, 11 April 2010 15:15 Go to previous messageGo to next message
the ss command can be executed in osgi console. Type ss and press ENTER
in the console like this:
osgi> ss
Best,
Ivan
> I don't known that command, osgi ss, where can i executed?
Re: RAP is not working with Galileo 3.5 [message #526473 is a reply to message #526436] Sun, 11 April 2010 15:32 Go to previous messageGo to next message
Luis Carlos Moreira da Costa is currently offline Luis Carlos Moreira da CostaFriend
Member
Luís Carlos Moreira da Costa
Eclipse RAP, RCP, eRCP, GEF, EMF, GMF, OSGI, Spring-DM and Pentaho Developer
Regional Communities/Brazil
http://wiki.eclipse.org/Regional_Communities/Brazil
Re: RAP is not working with Galileo 3.5 [message #526501 is a reply to message #526472] Sun, 11 April 2010 23:45 Go to previous messageGo to next message
I made what you told me to do, here is what osgi wrote in console ( just to mention, i'm using RAP 1.3M6 ) :
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.6.0.v20100301
26 INSTALLED Blah_1.0.0.qualifier
33 ACTIVE org.eclipse.rap.ui.forms_1.3.0.20100316-1859
34 ACTIVE org.eclipse.core.databinding.observable_1.3.0.I20100310-1300
35 ACTIVE com.ibm.icu.base_4.2.1.v20100212
36 INSTALLED org.eclipse.rap.demo_1.3.0.20100316-1859
37 ACTIVE javax.servlet_2.5.0.v200910301333
38 ACTIVE org.eclipse.osgi.services_3.2.100.v20100108
39 ACTIVE org.eclipse.equinox.common_3.6.0.v20100222
40 ACTIVE org.eclipse.equinox.http.registry_1.1.0.v20100307
41 INSTALLED org.eclipse.rap.ui_1.3.0.20100316-1859
42 ACTIVE org.eclipse.core.expressions_3.4.200.v20100222
43 ACTIVE org.mortbay.jetty.server_6.1.15.v200905151201
44 ACTIVE org.eclipse.equinox.http.jetty_2.0.0.v20090520-1800
45 ACTIVE org.eclipse.rap.jface.databinding_1.3.0.20100316-1859
46 ACTIVE org.eclipse.core.commands_3.6.0.I20100122-0800
47 INSTALLED org.eclipse.rap.demo.databinding_1.3.0.20100316-1859
48 ACTIVE org.eclipse.equinox.preferences_3.3.0.v20100307
49 ACTIVE org.eclipse.core.jobs_3.5.0.v20100304
50 ACTIVE org.mortbay.jetty.util_6.1.15.v200905182336
51 ACTIVE org.eclipse.core.databinding.beans_1.2.100.I20100310-1300
52 INSTALLED org.eclipse.rap.ui.views_1.3.0.20100316-1859
53 RESOLVED org.eclipse.rap.rwt.q07_1.3.0.20100316-1859
Master=56
54 ACTIVE org.eclipse.equinox.registry_3.5.0.v20100301
55 ACTIVE org.eclipse.rap.jface_1.3.0.20100316-1859
56 ACTIVE org.eclipse.rap.rwt_1.3.0.20100316-1859
Fragments=53
57 ACTIVE org.eclipse.core.contenttype_3.4.100.v20100301
58 ACTIVE org.eclipse.equinox.http.servlet_1.1.0.v20100201
59 ACTIVE org.eclipse.core.runtime_3.6.0.v20091204
60 ACTIVE org.eclipse.core.databinding.property_1.3.0.I20100310-1300
61 INSTALLED org.eclipse.rap.ui.workbench_1.3.0.20100316-1859
62 ACTIVE org.eclipse.equinox.app_1.3.0.v20100304
63 ACTIVE org.eclipse.core.databinding_1.3.100.I20100310-1300
[Updated on: Sun, 11 April 2010 23:47]
Re: RAP is not working with Galileo 3.5 [message #526522 is a reply to message #526501] Mon, 12 April 2010 07:16 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
your org.eclipse.rap.ui bundle has not been started. Try a 'diag 41' or
start it manually 'start 41' to see what the problem is.
Ralf
lottalava wrote:
> I made what you told to do, here is what osgi wrote in console ( just to
> osgi> ss
> id State Bundle
> 34 ACTIVE
> Master=56
> Fragments=53
> 60 ACTIVE
Re: RAP is not working with Galileo 3.5 [message #526598 is a reply to message #526522] Mon, 12 April 2010 11:59 Go to previous messageGo to next message
Erdal Karaca is currently offline Erdal KaracaFriend
AFAIK, compiling/running against 3.5 will not work, since RAP (now) depends on the newest equinox which has this LocaleProvider thingy support added...
Re: RAP is not working with Galileo 3.5 [message #526607 is a reply to message #526598] Mon, 12 April 2010 12:10 Go to previous messageGo to next message
So, what i must do?
Fallback to Ganymede or download a new Equinox to use as a separated server?
Re: RAP is not working with Galileo 3.5 [message #526625 is a reply to message #526598] Mon, 12 April 2010 12:41 Go to previous messageGo to next message
Hi all,
Erdal, RAP is working with Galileo 3.5.
lottalava, try to resolve the startup problem of org.eclipse.rap.ui as
Ralf suggested.
Best,
Ivan
> support added...
Re: RAP is not working with Galileo 3.5 [message #526641 is a reply to message #526625] Mon, 12 April 2010 13:46 Go to previous messageGo to next message
I got Equinox-3.5.2-SDK, installed in eclipse, but nothing different happened, same error continue!
[Updated on: Mon, 12 April 2010 13:46]
Re: RAP is not working with Galileo 3.5 [message #526671 is a reply to message #526641] Mon, 12 April 2010 14:30 Go to previous messageGo to next message
lottalava,
what is the output of "diag 41" command (41 is the number of
org.eclipse.rap.ui plugin), please post it here. You can try to validate
all bundles dependencies form "Run Configurations..." dialog -> Bundles
tab -> Validate Bundles button too.
Is the validation successful? Are there any problems?
Best,
Ivan
> happened, it still the same error!
Re: RAP is not working with Galileo 3.5 [message #526784 is a reply to message #526671] Mon, 12 April 2010 21:56 Go to previous messageGo to next message
Hello, i made the diag 41 command, and that's what it prints:
osgi> diag 41
Cannot find bundle 41.
and here is my Run Configuration for Hello World project:
http://lh4.ggpht.com/_tp7KVvLd4mY/S8OWjV9z8UI/AAAAAAAAAGw/Zpa33zJ67TE/rap.jpeg
All selected bundles are 1.3.x, but what is required is 3.5.x, any idea?
[Updated on: Mon, 12 April 2010 21:58]
Re: RAP is not working with Galileo 3.5 [message #526787 is a reply to message #526436] Mon, 12 April 2010 22:09 Go to previous messageGo to next message
Hey dudes, i pressed Add required bundles and after Validate Bundles, then eclipse tells no errors detected!
Now RAP seems to be working pretty well as it was supposed to be!
http://lh5.ggpht.com/_tp7KVvLd4mY/S8OZs7gW7iI/AAAAAAAAAG4/HDJOfbn0aD8/rap2.jpeg
Thank you for your help!
Re: RAP is not working with Galileo 3.5 [message #799022 is a reply to message #526436] Wed, 15 February 2012 10:45 Go to previous messageGo to next message
David Casas is currently offline David CasasFriend
Member
Thanks for your help...Im a newbie in RAP and I had the same problem ^^
Re: RAP is not working with Galileo 3.5 [message #799084 is a reply to message #799022] Wed, 15 February 2012 12:24 Go to previous message
Hi David,
are you still using Galileo 3.5? Which version of RAP are you trying?
Please explain your steps how did you install the RAP tooling/runtime
and what you are trying to launch.
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Previous Topic:Composite.redraw() - Does it work or not?
Next Topic:Background disappears when opening a dialog
Current Time: Sat Dec 21 12:02:55 GMT 2024
Powered by FUDForum. Page generated in 0.04517 seconds
