| Accessing Enum Literals from ETL [message #525350] |
Tue, 06 April 2010 01:22  |
Originally posted by: c.k.holmes.lboro.ac.uk
I am transforming an instance of metamodel A into metamodel B using ETL
under the control of Ant.
Metamodel A is auto-generated from the relevant XML schema, Metamodel B
is specified in a single Emfatic file and has the following structure:
@namespace (blah)
package Parent;
import "Stuff";
class Thing extends Stuff.Other {
attr String name = "";
@namespace (blah/Parent)
package Child {
class Foo {
attr BarType bar = "T";
enum BarType {
T = 0;
NT = 1;
I invoke the transformation 'Tx.etl' using
<property name="TargetFile" value="dirSpecForOutputFile"/>
<property name="TargetModelUri" value="aUrl"/>
<property name="TargetModel" value="Parent"/>
<epsilon.loadModel name="${TargetModel}" type="EMF">
<parameter name="modelFile" file="${TargetFile}"/>
<parameter name="metamodelUri" value="${TargetModelUri}"/>
<parameter name="readOnLoad" value="true"/>
<parameter name="storeOnDisposal" value="true"/>
</epsilon.loadModel>
<epsilon.etl src="${MyEtlFile}">
<model ref="${SourceName}" as="Source"/>
<model ref="${TargetModel}" as="Target"/>
</epsilon.etl>
From within the ETL file I can transform the source metamodel items
into (e.g.) instances of Thing and Foo via:
rule aRule1
transform itemIn : Source!SourceType1
to itemOut : Target!Thing {
itemOut.name := itemIn.name;
And
rule aRule2
transform itemIn : Source!SourceType2
to itemOut : Target!Foo {
Hence, I can access the classes within my metamodel structure via
Target!<myClass>. However, if I try to access the enumeration literals
of BarType in a similar fashion:
rule aNewRule2
itemOut.bar := itemIn.bar.transformInBarToOutBar();
operation String transformInBarToOutBar() {
if (self = 'T') {
return Target!BarType#T;
} else if (self = 'NT') {
return Target!BarType#NT;
} else {
throw 'Error';
Then it does not appear possible to access BarType via Target!BarType,
even though I can access Foo via Target!Foo and they're both in the same
namespace. ETL reports that it cannot find the enumeration literal
BarType#T. How should I access BarType such that I can assign the
relevant enumeration literal to the slot foo.bar?
Is there an error in my code or is this a bug in ETL?
Chris
| Re: Accessing Enum Literals from ETL [message #526043 is a reply to message #525354] |
Thu, 08 April 2010 11:06   |
Hi Dimitris,
I've created a simple example which demonstrates that, whilst access to
classes appears to work consistently from any package in the hierarchy,
one appears only to be able to access enumerations defined in the
outermost package only. Please let me know which of your e-mail
addresses you would like me to use.
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> At a first glance your code looks fine. Could you possibly put together
> a minimal running example that reproduces this so that I can have a
> closer look at this?
> Cheers,
> Dimitris
> On 06/04/2010 13:08, Chris Holmes wrote:
>> Hi,
>> @namespace (blah)
>> package Parent;
>> import "Stuff";
>> package Child {
>> class Foo {
>> enum BarType {
>> T = 0;
>> NT = 1;
>> </epsilon.etl>
>> rule aRule1
>> And
>> rule aRule2
>> rule aNewRule2
>> if (self = 'T') {
>> } else {
>> throw 'Error';
>> Regards
>> Chris
| Re: Accessing Enum Literals from ETL [message #526252 is a reply to message #526043] |
Fri, 09 April 2010 07:28  |
To summarize the offline discussion, this was a bug indeed
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=308627) and has now been
fixed in the SVN and in the latest interim release (0.8.8.201004091412).
Dimitris
On 08/04/2010 18:06, Chris Holmes wrote:
> Hi Dimitris,
> Best Wishes
> Chris
>> Hi Chris,
>> together a minimal running example that reproduces this so that I can
>> have a closer look at this?
>> Cheers,
>> Dimitris
>>> Hi,
>>> @namespace (blah)
>>> package Parent;
>>> import "Stuff";
>>> package Child {
>>> class Foo {
>>> enum BarType {
>>> T = 0;
>>> NT = 1;
>>> </epsilon.etl>
>>> rule aRule1
>>> And
>>> rule aRule2
>>> rule aNewRule2
>>> if (self = 'T') {
>>> } else {
>>> throw 'Error';
>>> Regards
>>> Chris
| Re: Accessing Enum Literals from ETL [message #588223 is a reply to message #526043] |
Dimitris
> Hi Dimitris,
> Best Wishes
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>>> Hi,
>>> @namespace (blah)
>>> package Parent;
>>> import "Stuff";
>>> package Child {
>>> class Foo {
>>> enum BarType {
>>> T = 0;
>>> NT = 1;
>>> </epsilon.etl>
>>> rule aRule1
>>> And
>>> rule aRule2
>>> rule aNewRule2
>>> if (self = 'T') {
>>> } else {
>>> throw 'Error';
>>> Regards
>>> Chris
FUDForum. Page generated in 0.05421 seconds
