Re: DSL toolkit book - problem when running tranformations [message #525229 is a reply to message #525228] |
Mon, 11 January 2010 01:57 |
Martin Baez Messages: 12 Registered: July 2009 |
Anybody has a clue about the problem I have with the sample code? , I
try to describe them better:
1_ When I run the "Export to cvs" tranformation I get this error:
EvaluationException : No Definition 'mindmap2csv::Main for mindmap::Map'
found!
[23,67] on line 1 'EXPAND mindmap2csv::Main FOR
model.typeSelect(mindmap::Map).first()'
2_ When I try to run the "transform to requirements" transformation I
get this one:
Cannot find imported module
'/org.eclipse.amalgam.examples.dnc.TransformDnc2Java.transfo rmationId'
What am I missing?. am I the only one with these problems? :(
thanks
colo
Colo wrote:
> I am developing a dsl toolkit and trying to give support for running
> some atl, qvto and xpand tranformations programatically.
> I am a bit lost when trying to understand how invokations must be done
> and found some problems when running the transformations:
> 1) The m2t tranformation(TransformMindmap2Csv class) was not running
> beacuse the code is commented, I uncommented the code and used the
> org.eclipse.emf.mwe plugins in order to compile the uncommented code,
> but when I try to export a mindmap diagram to cvs nothing happens, after
> some debug I found this issue reported for the WorkflowRunner
> [ERROR]: Class not found: 'org.eclipse.xpand2.Generator'
> What bundle am I missing?, I understood that the dsl sample must be used
> with the ganymede version, but what version of xpand should I use?
> 2) I cannot run the transformations(mindmap to requirementes for
> example) because the wizard reported this error:
> "Cannot find imported module
> '/org.eclipse.amalgam.examples.dnc.TransformDnc2Java.transfo rmationId' "
> Any clue?, by the way the book is great!!
> thanks in advance
> colo
Re: DSL toolkit book - problem when running tranformations [message #587257 is a reply to message #525228] |
found!
get this one:
thanks
colo
> thanks in advance
> colo
FUDForum. Page generated in 0.04292 seconds
