Re: Variables view empty when usign xdebug [message #522636 is a reply to message #522596] |
Tue, 23 March 2010 12:35 |
Originally posted by: dkel50.hotremovemail.com
I have tried a straight PHP script on my setup
PDT 2.1sr2, windows xp, php5.3.2, xdebug 2.1beta2 and xdebug 2.1beta3
and I can see variables, so
what version of PDT are you using ?
could you create a simple script that recreates the proplem and generate
an xdebug log (xdebug_log="c:/xdebuglog.txt" in your ini file) and post
the info here ?
Dave Kelsey
On 23/03/10 10:07, stephanie_ehrling@web.de wrote:
> Hi everyone,
> I'm using xdebug and it's working so far. I can debug php scripts and
> step through the code. However the variables view in eclipse is always
> completely empty.
> I'm using XAMPP 1.7.2 with php 5.3.0 and the latest beta of xdebug
> (Xdebug 2.1.0beta3). When adding an expression to a variable, the value
> of the variable is displayed.
> Did anybody faced the same problem or has a hint what could be wrong?
> Thx in advance!!!!
Re: Variables view empty when usign xdebug [message #522665 is a reply to message #522659] |
Tue, 23 March 2010 14:26 |
Did you get a Child Count Error on PDT at all ? have a look in your
error log of PDT to see.
Do you have any expressions in your watch expressions view that invoke
functions or methods for example ?
does clearing your watch expressions, stopping and restarting pdt solve
the problem ?
Dave Kelsey
On 23/03/10 14:09, stephanie_ehrling@web.de wrote:
> I'm using PDT 2.1-SR2.
> I tried to debug this simple script:
> <?php
> $myvar = 5;
> echo $myvar;
> echo $mydoublevar = double($myvar);
> function double($x){
> return $x*2; }
> The output in the xdebug log file is:
> Log opened at 2010-03-23 14:01:23
> -> <init xmlns="urn:debugger_protocol_v1"
> xmlns:xdebug="http://xdebug.org/dbgp/xdebug"
> fileuri="file:///C:/workspace/hellodebugger/index.php" language="PHP"
> protocol_version="1.0" appid="6036" idekey="ECLIPSE_DBGP"><engine
> version="2.1.0rc1-dev"><![CDATA[Xdebug]]></engine><author ><![CDATA[Derick Rethans]]></author><url><![CDATA[http://xdebug.org]]></url><copyright><![CDATA[Copyright
> (c) 2002-2010 by Derick Rethans]]></copyright></init>
> <- feature_set -i 408 -n show_hidden -v 1
> -> <response xmlns="urn:debugger_protocol_v1"
> xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_set"
> transaction_id="408" feature="show_hidden" success="1"></response>
> <- feature_set -i 409 -n max_depth -v 5
> transaction_id="409" feature="max_depth" success="1"></response>
> <- feature_set -i 410 -n max_children -v 34
> transaction_id="410" feature="max_children" success="1"></response>
> <- feature_get -i 411 -n encoding
> xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_get"
> transaction_id="411" feature_name="encoding"
> supported="1"><![CDATA[iso-8859-1]]></response>
> <- feature_get -i 412 -n supports_async
> transaction_id="412" feature_name="supports_async"
> supported="1"><![CDATA[0]]></response>
> <- stdout -i 413 -c 1
> xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stdout"
> transaction_id="413" success="1"></response>
> <- stderr -i 414 -c 1
> xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stderr"
> transaction_id="414" success="0"></response>
> <- breakpoint_set -i 415 -t line -f
> file:///C:%5Cworkspace%5Chellodebugger%5Cindex.php -n 2
> xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="breakpoint_set"
> transaction_id="415" id="60360029"></response>
> <- breakpoint_set -i 416 -t line -f
> file:///C:%5Cworkspace%5Chellodebugger%5Cindex.php -n 4
> transaction_id="416" id="60360030"></response>
> <- breakpoint_set -i 417 -t line -f
> file:///C:%5Cworkspace%5Chellodebugger%5Cindex.php -n 5
> transaction_id="417" id="60360031"></response>
> <- step_into -i 418
> xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="step_into"
> transaction_id="418" status="break" reason="ok"><xdebug:message
> filename="file:///C:/workspace/hellodebugger/index.php"
> lineno="2"></xdebug:message></response>
> <- stack_get -i 419
> xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stack_get"
> transaction_id="419"><stack where="{main}" level="0" type="file"
> lineno="2"></stack></response>
> <- step_over -i 420
> xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="step_over"
> transaction_id="420" status="break" reason="ok"><xdebug:message
> lineno="4"></xdebug:message></response>
> <- stack_get -i 421
> transaction_id="421"><stack where="{main}" level="0" type="file"
> lineno="4"></stack></response>
> <- step_over -i 422
> -> <stream xmlns="urn:debugger_protocol_v1"
> xmlns:xdebug="http://xdebug.org/dbgp/xdebug" type="stdout"
> encoding="base64"><![CDATA[NQ==]]></stream>
> transaction_id="422" status="break" reason="ok"><xdebug:message
> lineno="5"></xdebug:message></response>
> <- stack_get -i 423
> transaction_id="423"><stack where="{main}" level="0" type="file"
> lineno="5"></stack></response>
> <- step_over -i 424
> encoding="base64"><![CDATA[MTA=]]></stream>
> transaction_id="424" status="break" reason="ok"><xdebug:message
> lineno="7"></xdebug:message></response>
> <- stack_get -i 425
> transaction_id="425"><stack where="{main}" level="0" type="file"
> lineno="7"></stack></response>
> <- step_over -i 426
> transaction_id="426" status="stopping" reason="ok"></response>
> <- stop -i 427
> xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="stop"
> transaction_id="427" status="stopped" reason="ok"></response>
> Log closed at 2010-03-23 14:01:32
> Any ideas?
FUDForum. Page generated in 0.05543 seconds
