Home » Eclipse Projects » Remote Application Platform (RAP) » Could someone check the RAP example, I guess there might be an error(When close PopupMenu, SWT.Disposed Exception is thrown.)
Could someone check the RAP example, I guess there might be an error [message #520137] Thu, 11 March 2010 04:47 Go to next message
This would happen in two Scenarios:
The example used is the first one on website:
http://www.eclipse.org/rap/demos.php
1. Add an Editor to the example -> Add a New MenuItem to show the Editor -> Run Example -> Execute the MenuItem; Exception is thrown.
I find the error is thrown in the method close() in MenuPopup.java. So I do "//close()", then run again. Works!
2. Add an Editor to the modified code as mentioned above, let the execution of the MenuItem to open a wizard, using wizard to open the Editor.
Can't solve. I guess it might happen in som place where wizard is closing. But I can't change the code.
Re: Could someone check the RAP example, I guess there might be an error [message #520417 is a reply to message #520137] Fri, 12 March 2010 00:26 Go to previous messageGo to next message
Hi Wayne,
without testing your scenario, you mention MenuPopup class, but I can't
find such a class in RAP from CVS HEAD. What RAP version are you using?
Best,
Ivan
> Editor -> Run Example -> Execute the MenuItem; Exception is thrown. I
> Editor. Can't solve. I guess it might happen in som place where wizard
Re: Could someone check the RAP example, I guess there might be an error [message #520426 is a reply to message #520417] Fri, 12 March 2010 00:50 Go to previous messageGo to next message
hi Wayne, hi Ivan,
the class MenuPopup was a design related one. We used this class to
provide a styled menu. Since we can style menus with rounded corners
and gradients this class was not longer needed. So, I removed the class
right after RAP 1.3 M5 and replaced the menu behaviour with the one
from the workbench.
@Wayne: your error should be goen with M6 or the latest version from HEAD.
Hope this helps.
Regards Holger
On 2010-03-12 11:13:37 +0100, Ivan Furnadjiev <ivan@eclipsesource.com> said:
> Hi Wayne,
> Best,
> Ivan
http://eclipsesource.com
http://twitter.com/eclipsesource
Re: Could someone check the RAP example, I guess there might be an error [message #520671 is a reply to message #520426] Sat, 13 March 2010 22:33 Go to previous message
Hi Holger, Ivan,
You're right, Holger. Now I changed to RAP 1.3M5, it worked.
Thanks alot, Holger and Ivan.
regards,
Wayne
Previous Topic:It seems a Bug when calling "WorkbenchPage.resetPerspective"
Next Topic:Implementing org.eclipse.swt.browser.BrowserFunction
Current Time: Wed Oct 29 21:15:14 EDT 2025
Powered by FUDForum. Page generated in 0.03905 seconds
