Home » Modeling » M2T (model-to-text transformation) » Xpand workflows and parameters
Xpand workflows and parameters [message #517086] Fri, 26 February 2010 08:24 Go to next message
MaximeLecourt  is currently offline MaximeLecourt Friend
I read that topic, and the MWE documentation
http://www.eclipse.org/forums/index.php?t=msg&th=161471& amp; amp;start=0&
Still, some things are not clear to me.
I see you can declare Properties, which references to a property file, or defines a simple property.
but can you modify the workflow to add parameters to it's execution ?
By parameters, I mean adding options to the generation, defining if you generate all your code in the same file, or change the generated packages name, how many of them there are, and so on.
thanks
One day I shall master M2T, but that day has yet to come...
[Updated on: Fri, 26 February 2010 08:27]
Report message to a moderator
Re: Xpand workflows and parameters [message #517092 is a reply to message #517086] Fri, 26 February 2010 09:01 Go to previous messageGo to next message
Darius Jockel is currently offline Darius JockelFriend
Member
MaximeLecourt wrote on Fri, 26 February 2010 03:24
http://www.eclipse.org/forums/index.php?t=msg&th=161471& amp; amp; amp;start=0&
But can you modify the workflow to add parameters to it's execution ?
Please look at the chapter 'Controlling the Workflow' inside the MWE documentation.
You will see that you can define aspects (further documentation of aspects, please refer the Xpand documentation). With aspects you can 'redefine'
tempaltes or extensions (e.g. the extension providing the package name).
Also you can switch on/off components in your workflow using:
<workflow>
<property  file ="features.properties"/>
  <if cond="${feature}">
    <component name=".../>
  </if>
</workflow>
and a 'feature.properties'
feature=true
Darius
Re: Xpand workflows and parameters [message #517127 is a reply to message #517086] Fri, 26 February 2010 11:07 Go to previous messageGo to next message
Indeed.
Thank you
Re: Xpand workflows and parameters [message #518107 is a reply to message #517086] Wed, 03 March 2010 05:35 Go to previous message
Sven Efftinge is currently offline Sven EfftingeFriend
> http://www.eclipse.org/forums/index.php?t=msg&th=161471& amp;start=0&
You can simply pass parameters to a workflow, which will override any
local properties.
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Previous Topic:Unknown type... that seems to bo known
Next Topic:Help Eoposite to Xtext
Current Time: Sun Dec 22 06:10:25 GMT 2024
Powered by FUDForum. Page generated in 0.03382 seconds
