Home » Eclipse Projects » Remote Application Platform (RAP) » tab key
tab key [message #515575] Fri, 19 February 2010 07:40 Go to next message
Hello Everybody,
Does anybody know if RAP intercepts the Tab-key event at javascript
side? Where to look at if it does?
I have a flash content, and when I press Tab - the focus goes away from
it. It happens only in Chrome. Provided that the "seamlesstabbing" was
set to false in flash params.
If I run the same content without RAP - the focus doesn't go out of the
flash content.
Dmitry
Re: tab key [message #515907 is a reply to message #515575] Mon, 22 February 2010 03:14 Go to previous messageGo to next message
Hi Dmitry,
if your flash content is wrapped in a custom widget (client side
javascript widget), you can add a "keypress" listener to it and stop the
propagation of the event if the "Tab" key is pressed.
HTH,
Ivan
On 2/19/2010 2:40 PM, Dmitry Pryadkin wrote:
> Hello Everybody,
> from it. It happens only in Chrome. Provided that the
> "seamlesstabbing" was set to false in flash params.
> the flash content.
> Dmitry
Re: tab key [message #517162 is a reply to message #515907] Fri, 26 February 2010 07:24 Go to previous message
Hello Ivan,
I've found out a solution. I hook to
org.eclipse.rwt.AsyncKeyEventUtil.prototype.intercept and
org.eclipse.rwt.SyncKeyEventUtil.prototype.intercept - these handlers
are first places where the filtering starts.
Dmitry
Ivan Furnadjiev wrote:
> Hi Dmitry,
> HTH,
> Ivan
>> Hello Everybody,
>> the flash content.
>> Thanks,
>> Dmitry
Previous Topic:[Upload] Upload widget after latest update
Next Topic:View PDF, CHM files within a RAP Application
Current Time: Sun Oct 26 03:18:48 EDT 2025
Powered by FUDForum. Page generated in 0.03822 seconds
