Home » Archived » Buckminster » Buckminster does not see the cspec file it seems
Buckminster does not see the cspec file it seems [message #511880] Wed, 03 February 2010 10:10 Go to next message
Martin Taal is currently offline Martin TaalFriend
--------------010600070001020703000804
Some of the plugins I build use import packages. So to make sure that the plugins, exporting these packages, are there I
need to use a cspec file, is that indeed the best way?
I tried this but it seems that buckminster does not see the cspec file (see attachment).
I have a separate buckminster.releng project which contains the buckminster.properties and rmap (etc) files. This
buckminster.releng project is the main container of the features to build (is that wise?). I have placed the cspec file
(see attachment) in this project and I have also tried placing it in the feature being build. But it does not seem to be
picked up (the dependencies are not downloaded to the target platform, neither are there any resolving errors).
Should I put it somewhere else? Or is my format maybe wrong?
I am using buckminster 3.6 (downloaded it last week thursday).
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Content-Type: text/xml;
name="buckminster.cspec"
Content-Disposition: inline;
filename="buckminster.cspec"
<cs:cspec xmlns:cs="http://www.eclipse.org/buckminster/CSpec-1.0" name="org.eclipse.emf.teneo.hibernate" componentType="buckminster" version="1.0.0">
<cs:dependencies>
<cs:dependency name="com.mysql.jdbc" componentType="eclipse.feature"/>
<cs:dependency name="org.hibernate" componentType="eclipse.feature"/>
<cs:dependency name="org.hsqldb" componentType="eclipse.feature"/>
<cs:dependency name="javax.persistence" componentType="eclipse.feature"/>
<cs:dependency name="org.dom4j" componentType="eclipse.feature"/>
<cs:dependency name="org.apache.commons.logging" componentType="eclipse.feature"/>
</cs:dependencies>
</cs:cspec>
--------------010600070001020703000804--
Re: Buckminster does not see the cspec file it seems [message #511888 is a reply to message #511880] Wed, 03 February 2010 10:50 Go to previous message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Martin,
The cspec is only intended to be used when the meta-information cannot be derived in other ways. Buckminster
specifically will not look for a cspec if it finds a feature or a bundle since all information can be derived from other
artifacts (i.e. feature.xml, manifest.mf, etc.).
In some cases it is desirable to alter the information that can be derived. If that is what you want, then you should
use a cspec extension, i.e. a cspex file (with top element cspecExtension).
If your releng project is not a feature, then a 'buckminster.cspec' placed in the root folder should be read by
Buckminster. You need to make sure that the RMAP provider has declared 'buckminster' as one of its componentTypes.
The name in the cspec should normally be the same as the name of the project. The cspec you sent me has the name
"org.eclipse.emf.teneo.hibernate" which effectively names the component. It doesn't sound like the name of a releng
component. Perhaps that's the problem?
Thomas Hallgren
On 02/03/2010 11:10 AM, Martin Taal wrote:
> the plugins, exporting these packages, are there I need to use a cspec
> (see attachment).
> buckminster.properties and rmap (etc) files. This buckminster.releng
> I have placed the cspec file (see attachment) in this project and I have
> to be picked up (the dependencies are not downloaded to the target
Previous Topic:qualifier replacement not happening
Next Topic:Aggregator regenerate Maven2 Respoitory
Current Time: Wed Feb 05 16:05:37 GMT 2025
Powered by FUDForum. Page generated in 0.02658 seconds
