Re: How to change syntax highlighting colors (for XML & XSD) ? [message #510993 is a reply to message #510964] |
Fri, 29 January 2010 13:26 |
Ben wrote on Fri, 29 January 2010 05:36 | How can I change the current highlighting colors schema?
Window -> Preferences -> XML -> XML Files -> Editor -> Syntax Coloring
Ben wrote on Fri, 29 January 2010 05:36 | How can I export this new XML color schema and import it in another Eclipse installation?
Export:
1. File -> Export... -> General -> Preferences
2. Be sure 'Export all' is checked
3. choose a location and press 'Finish'
Import:
1. In your other workspace
2. File -> Import... -> General -> Preferences
3. Choose location from export
4. be sure box to 'Import all' is checked
5. Finish
Blue Skies,
~Ian
Ian Tewksbury
WTP JavaScript Tools
IBM Rational
“When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return.” ~Leonardo da Vinci
[Updated on: Fri, 29 January 2010 13:26] Report message to a moderator
Re: How to change syntax highlighting colors (for XML & XSD) ? [message #511479 is a reply to message #511439] |
Mon, 01 February 2010 16:57 |
On 2/1/2010 10:50 AM, Ben wrote:
> 1.) But where can I setup editor (monospaced) font?
On the Colors and Fonts preference page, under General/Appearance,
either with the Text Font or the Structured Text Editor Text Font. A
monospaced font should already be the default.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.04859 seconds
