Re: Connection Anchor question in Logic Editor Example [message #50874 is a reply to message #50789] |
Tue, 24 December 2002 02:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: truenoto.yahoo.com
Look at the code for the LogicSubpart.
For incoming connections, it uses a HashTable.
For outgoing connections, it uses a Vector.
"Hal" <otaconss2@hotmail.com> wrote in message
news:au7fhd$d56$1@rogue.oti.com...
> Why I can't connect multiple incoming connections to OrGate, but I can
draw
> multiple outgoing connections from an OrGate?
> Everytime I connect a second connection to the OrGate, the first
connection
> pointing to the middle of the diagram. I think it is pointing to
(100,100),
> from a previous positing, that means it can't find a connection positing.
My
> question is why this happens when I try to connect a second connection?
This
> should not affect the first connection.
> I even try changing the logic example to use ChopBoxConnection Anchor
> instead of the FixedConnectionAnchor, same thing happens: one 1 incoming
> connection, but multiple outgoing connection.
> Thank you for any help.
Re: Connection Anchor question in Logic Editor Example [message #50957 is a reply to message #50789] |
Tue, 24 December 2002 16:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: hudsonr.us.eye-bee-em.com
This is a bug in the Command. It should prevent the operation.
Only one input is valid.
draw
connection
(100,100),
My
This
Re: Connection Anchor question in Logic Editor Example [message #51066 is a reply to message #50957] |
Wed, 25 December 2002 00:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
This is a bug in the Command in the logic editor example? or a bug in the
command in the GEF framework?
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:aua20s$gj2$1@rogue.oti.com...
> draw
> connection
> (100,100),
positing.
> My
> This
Re: Connection Anchor question in Logic Editor Example [message #51149 is a reply to message #51066] |
Thu, 26 December 2002 17:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
the logic example
"Takumi Fujiwara" <truenoto@yahoo.com> wrote in message
news:auav0m$q2a$1@rogue.oti.com...
> > draw
> > connection
> > (100,100),
> positing.
> > My
connection?
> > This
incoming
FUDForum. Page generated in 0.03649 seconds
