Home » Modeling » GMF (Graphical Modeling Framework) » style properties not accepted
style properties not accepted [message #50567] Tue, 19 September 2006 03:56 Go to next message
I've added some style information to my figures - like font and
background color. Now the user input changing the style in the final
diagram will not accepted any more. Can I enable this again plus
providing default values via the gen model ?
Thanks in advance
Sven
Re: style properties not accepted [message #50764 is a reply to message #50567] Tue, 19 September 2006 07:11 Go to previous messageGo to next message
It was intentionally done this way -- if toolsmith sets the node to be blue,
user (by default) should not be able to change it to be red.
To change it at the generation step you can go to the genmodel Viewmap for
the problem node, find child StyleAttribute and manually change
FixedFont/FixedForeground etc properties. Though, I am not sure that it will
be preserved on regeneration. Please feel free to submit reconciler issue in
this case.
Michael
"sven krause" <no.spam@public-files.de> wrote in message
news:eeo7s9$4e2$1@utils.eclipse.org...
> I've added some style information to my figures - like font and background
> color. Now the user input changing the style in the final diagram will not
> accepted any more. Can I enable this again plus providing default values
> via the gen model ?
> Thanks in advance
> Sven
Re: style properties not accepted [message #50848 is a reply to message #50764] Tue, 19 September 2006 07:50 Go to previous messageGo to next message
Thanks Michael,
is there a template I can cache globally that defines the value of those
fixed attributes? So I can go an turn it off for my project instead of
patching the gemfgen model multiple times.
Sven
Michael Golubev schrieb:
> this case.
> Regards,
> Michael
>> Hi,
>> via the gen model ?
>> Thanks in advance
>> Sven
Re: style properties not accepted [message #50988 is a reply to message #50848] Tue, 19 September 2006 08:19 Go to previous messageGo to next message
I believe that it is enough to replace lines 33-34 in the
templates/providers/ViewFactory.javajet that actually contains:
boolean fixedForeground = styleAttributes != null &&
styleAttributes.isFixedForeground();
boolean fixedFont = styleAttributes != null &&
styleAttributes.isFixedFont();
with
boolean fixedForeground = false;
boolean fixedFont = false;
Michael
news:eeolh9$1hn$1@utils.eclipse.org...
> Thanks Michael,
> Sven
>> Hi,
>> blue, user (by default) should not be able to change it to be red.
>> for the problem node, find child StyleAttribute and manually change
>> will be preserved on regeneration. Please feel free to submit reconciler
>> issue in this case.
>> Regards,
>> Michael
>>> Hi,
>>> Thanks in advance
>>> Sven
Re: style properties not accepted [message #51016 is a reply to message #50848] Tue, 19 September 2006 08:26 Go to previous messageGo to next message
Nope, however, the logic that prevents font/color editing when there's value
set in the .gmfgraph should be changed soon to allow explicitly specify
whether you just want an initial value or 'never modify' one.
Artem
> Thanks Michael,
> Sven
>> Hi,
>> issue in this case.
>> Regards,
>> Michael
>>> Hi,
>>> Thanks in advance
>>> Sven
Re: style properties not accepted [message #51671 is a reply to message #50988] Wed, 20 September 2006 04:02 Go to previous message
Hi Michael,
sorry - it does not help. The user may now change the style attributes,
but they are not applied to the figures. Either on patching the template
(I've seen the line "add(NotationFactory.eINSTANCE.createFillStyle());"
within the code) not manually setting the FixedForeground to false
within the gmfgen model. So it looks to me that listing the style is not
sufficient to the gmf runtime. Is there an edit policy somewhere that
controls the style settings ?
Sven
> with
> Regards,
> Michael
>> Thanks Michael,
>> Sven
>>> Hi,
>>> issue in this case.
>>> Regards,
>>> Michael
>>>> Hi,
>>>> Thanks in advance
>>>> Sven
Previous Topic:tree layout
Next Topic:Extending create-action of node from palette.
Current Time: Thu Sep 18 18:01:04 EDT 2025
Powered by FUDForum. Page generated in 0.17333 seconds
