Home » Eclipse Projects » Rich Client Platform (RCP) » close perspective on switch
close perspective on switch [message #508260] Mon, 18 January 2010 07:58 Go to next message
Luca Ferrari is currently offline Luca FerrariFriend
is it possibile to close the current perspective when the user switches to another perspective?
Thanks.
Re: close perspective on switch [message #508347 is a reply to message #508260] Mon, 18 January 2010 13:58 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
You would probably have to complete your switch to the new perspective,
and then request the old perspective to close.
I'd try the command id = org.eclipse.ui.window.closePerspective ... it
takes a parameter with the perspective id =
org.eclipse.ui.window.closePerspective.perspectiveId
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: close perspective on switch [message #508441 is a reply to message #508260] Mon, 18 January 2010 20:05 Go to previous message
John Ormerod is currently offline John OrmerodFriend
Member
Hi Luca
if you want a more generalised solution, you could create a PerspectiveListener class - consider subclassing org.eclipse.ui.PerspectiveAdapter.
You can only have one of these and that's the first one to be defined. I do this in the WWAdvisor's postWindowOpen() method, something like:
IWorkbenchPage activePage = window.getActivePage(); activePage.getWorkbenchWindow().addPerspectiveListener(new RCPPerspectiveListener());
Regards, John
Previous Topic:No application id has been found
Next Topic:actionSetPartAssociations with a multipage editor
Current Time: Tue Jan 28 12:48:04 GMT 2025
Powered by FUDForum. Page generated in 0.03368 seconds
